gufmar Posted September 6, 2019 Posted September 6, 2019 I try to build a customized image as described in https://docs.armbian.com/Developer-Guide_User-Configurations/#user-provided-image-customization-script and by using the template with the OpenMediaVault example https://github.com/armbian/build/blob/master/config/templates/customize-image.sh.template The goal is to build an image who auto-execute an initial setup script after being flashed and frist boot. The device has connected RGB-Leds and an OLED I2c Display on the GPIO pins. It should give color signals durring this initial setup, and then show system parameters (especially the DHCP-Address) on the oled screen *without* having a keyboard and HDMI-Display connected. It generally works but I have some questions: crontab @reboot execution only works when I first set a root password and remove the not_logged_in_yet file. The customize-image function then - overlays a precompiled dtb file - creates a shell script file with commands for execution after first boot - this script is marked as executable - and finaly added to crontab this last crontab command returns a "no crontab for root" in the build console, but is then added and also executed. (but only if I first chpasswd the root user) PrepareDevice() { echo root:1234 | chpasswd rm /root/.not_logged_in_yet # I2c tuned to 400kHz cp /tmp/overlay/boot/dtb/rockchip/rk3399-rockpi4b.dtb /boot/dtb/rockchip/rk3399-rockpi4b.dtb mkdir /initial-setup cat > /initial-setup/step1.sh <<- EOF #!/bin/bash # turn blue RGBLed on as a first sign of life cd /sys/class/gpio echo 154 > export cd gpio154 echo out > direction echo 1 > value # setup and configure the I2c OLED display apt-get --yes --force-yes install git git-core build-essential apt-get --yes --force-yes install python-dev python-pil python-smbus python-setuptools python-pip apt-get --yes --force-yes install i2c-tools libi2c-dev lm-sensors pip install psutil # blink as debug info echo 0 > value sleep 1s echo 1 > value # add the OLED script on every future reboot (crontab -u root -l; echo "@reboot python /root/OLEDisplay/sysinfo.py --display sh1106 --i2c-port 2 --rotate 2" ) | crontab -u root - # remove the initial setup on-boot execution crontab -u root -l | grep -v 'initial-setup/step1.sh' | crontab -u root - reboot EOF chmod +x /initial-setup/step1.sh echo "add crontab for step1" # execute the initial-setup shell script on first boot line="@reboot /initial-setup/step1.sh" (crontab -u root -l; echo "$line" ) | crontab -u root - } So far all ok. The device boots up and the blue led turns on as expected. But then for some (unknown) reason the apt install commands and crontab edits does not work as expected. It works when I connect a keyboard and HDMI display, log in as root and execute the `/initial-setup/step1.sh` The question is if there is a general better way or if someone can tell me how to set and remove the crontab scripts ?
Hijax Posted September 6, 2019 Posted September 6, 2019 Hi, My experiences with crontab @reboot is that I dropped that solution in favor of systemd services. To give you basic idea here comes a excerpt of code I put into the customize-image.sh script: cat <<EOT >|/usr/local/bin/usb3-memory-size.sh #!/bin/bash echo 1000 > /sys/module/usbcore/parameters/usbfs_memory_mb exit 0 EOT chmod +x /usr/local/bin/usb3-memory-size.sh cat <<EOT >|/lib/systemd/system/usb3-memory-size.service [Unit] Description=USB3 memory sizer Before=basic.target After=sysinit.target local-fs.target DefaultDependencies=no [Service] Type=oneshot RemainAfterExit=yes ExecStart=/bin/bash -c "/usr/local/bin/usb3-memory-size.sh" [Install] WantedBy=basic.target EOT systemctl enable usb3-memory-size.service It creates a new service that corrects the kernel setting for USB3 camera. This works perfectly fine. When such a service shall be triggered depends on your configuration. Look at the line of [Unit] section, explicitly before/after lines. For example you can force such a service to start after login prompt pops up. 1
gufmar Posted September 6, 2019 Author Posted September 6, 2019 10 hours ago, Hijax said: solution in favor of systemd services loving this Armbian forum and community. It works great! TYVM
