mrdeniska1234 Posted September 7, 2019 Posted September 7, 2019 Armbianmonitor: http://ix.io/1UtU When connecting via a round connector, there is no power to SATA and USB, when connecting power to the USB-OTG, without disconnecting the round connector, power appears, when the power is turned off from the USB-OTG, the power on the ports does not disappear, while rebooting too. I tried to google, but to no avail Thank you in advance
Igor Posted September 7, 2019 Posted September 7, 2019 Update boot loader to latest version - armbian-config -> system -> install/update boot loader ... and try again. What kind of PSU are you using?
mrdeniska1234 Posted September 12, 2019 Author Posted September 12, 2019 I use PSU from my mi mix 2 phone, I also tried to power from power bank xiaomi on 20k mah, which supports fast charge. I will update this post after trying.
Igor Posted September 12, 2019 Posted September 12, 2019 I tried on my board and everything is O.K. (with latest image) It could be a hardware failure where software support can't help.
mrdeniska1234 Posted September 12, 2019 Author Posted September 12, 2019 please tell me what are the characteristics of your PSU? is it 5v 2a?
Igor Posted September 12, 2019 Posted September 12, 2019 5 minutes ago, mrdeniska1234 said: please tell me what are the characteristics of your PSU https://www.gwinstek.com/en-US/products/detail/GPE-X323 Mainly using fixed 5V / 5A output.
mrdeniska1234 Posted September 12, 2019 Author Posted September 12, 2019 On 9/7/2019 at 2:40 PM, Igor said: Update boot loader to latest version - armbian-config -> system -> install/update boot loader ... and try again. Trying this, nothing changed. apparently really not enough power. Thanks for the detailed answer!
