What are the proper steps to validating my armbian download?
orangepiplus2e; debian 10, buster;
I tried the following, but it did not work:
https://docs.armbian.com/User-Guide_Getting-Started/#how-to-check-download-authenticity
If you won't help me figure out why it is not working, can you tell me what the 'correct' sha256sum is for my download?
https://dl.armbian.com/orangepiplus2e/Debian_buster_next_desktop.7z
7z x Debian_buster_next_desktop.7z
You need to verify the image which is inside this 7z file. This is the content:
Armbian_5.93_Orangepiplus2e_Debian_buster_next_4.19.64_desktop.img
Armbian_5.93_Orangepiplus2e_Debian_buster_next_4.19.64_desktop.img.asc
sha256sum.sha
Is now obvious which SHA to use?
HI Igor.
I already know that the sha to use is the one that comes with the download. The problem is getting the one from the website to compare it against.
What is this for: 7z x Debian_buster_next_desktop.7z ??
Thanks.
22 minutes ago, qrty said:
What is this: 7z x Debian_buster_next_desktop.7z ??
It's a command to unpack .7z file on (Debian based) Linux (apt-get install gnupg p7zip) as written here:
and
https://docs.armbian.com/User-Guide_Getting-Started/#how-to-check-download-integrity
Just read closely. There is written how to do that on Windows and MAC.
You don't need to check compressed file. You have to check IMAGE authenticity -> .img file with the SHA or you can verify PGP signature of that file.
and
Thanks. I have no problem unpacking the download. The problem is getting started for authenticity. The command does not work, though someone stated that the 1st gpg is not correct on the site (link provided), that it is missing "Ox" at the end of it. I will try it now.
For the 2nd gpg command, "gpg --verify Armbian_5.18_Armada_Debian_jessie_3.10.94.img.asc", am I suppose to use this exactly as written or insert my debian name?
Command:
gpg --keyserver ha.pool.sks-keyservers.net --recv-key DF00FAF1C577104B50BF1D0093D6889F9F0E78D5
Response:
gpg: keybox '/root/.gnupg/pubring.kbx' created
gpg: key 93D6889F9F0E78D5: 2 signatures not checked due to missing keys
gpg: /root/.gnupg/trustdb.gpg: trustdb created
gpg: key 93D6889F9F0E78D5: public key "Igor Pecovnik <igor@armbian.com>" imported
gpg: no ultimately trusted keys found
gpg: Total number processed: 1
gpg:               imported: 1
Command:
gpg --verify Armbian_5.93_Orangepiplus2e_Debian_buster_next_4.19.64_desktop.img.asc
Response:
gpg: assuming signed data in 'Armbian_5.93_Orangepiplus2e_Debian_buster_next_4.19.64_desktop.img'
gpg: Signature made Mon 05 Aug 2019 06:40:03 PM CEST
gpg:                using RSA key DF00FAF1C577104B50BF1D0093D6889F9F0E78D5
gpg: checking the trustdb
gpg: marginals needed: 3  completes needed: 1  trust model: pgp
gpg: depth: 0  valid:   1  signed:   0  trust: 0-, 0q, 0n, 0m, 0f, 1u
gpg: Good signature from "Igor Pecovnik <igor@armbian.com>" [ultimate]
gpg:                 aka "Igor Pecovnik (Ljubljana, Slovenia) <igor.pecovnik@gmail.com>" [ultimate]
Is this the correct output? (you posted this)
gpg: keybox '/root/.gnupg/pubring.kbx' created gpg: key 93D6889F9F0E78D5: 2 signatures not checked due to missing keys gpg: /root/.gnupg/trustdb.gpg: trustdb created gpg: key 93D6889F9F0E78D5: public key "Igor Pecovnik <igor@armbian.com>" imported gpg: no ultimately trusted keys found gpg: Total number processed: 1 gpg: imported: 1
