I made a custom A20 board of which sch is very close to lime2 for a project (retrostone2) and I can't use USB0 as a classic USB port.
The three USB (0 1 2) are all connected to regular USB type A connectors. No OTG used. However I can't get the USB0 to work. USB1 and USB2 works without issue. But USB0 will not recognize keyboard/any peripheral. I think it's probably because of OTG detect pins.
I looked at the DTS, but I am having trouble understanding how OTG is emplemented there, how to unactivate it and just activate a classic USB port.
Any ideas?
13 minutes ago, PaddleStroke said:
Any ideas?
In the DTS, do you have any "dr_mode" ? If Yes, it must be set to "host" instead of "otg".
Also, make sure you have the +5V activated on this USB port.
1 hour ago, PaddleStroke said:
Tried and still NOK.
According to Lime2 schematic, there is USB0_DRV which is control the VBUS of USB0 using PA17 gpio.
Is there some kind of "usb0_vbus" entry in DTS and is the "gpio" parameter is pointing to the right PA17 ?
on my board I have not set the USB_DRV GPIO for any USB, they are always ON (enable pin of sy6280 pull up to 5V).
Also ID_detect is not connected either as I'm not using OTG. So none of these are connected :
&reg_usb0_vbus {
gpio = <&pio 2 17 GPIO_ACTIVE_HIGH>;
&usbphy {
usb0_id_det-gpios = <&pio 7 4 (GPIO_ACTIVE_HIGH | GPIO_PULL_UP)>; /* PH4 */
usb0_vbus_det-gpios = <&pio 7 5 (GPIO_ACTIVE_HIGH | GPIO_PULL_DOWN)>; /* PH5 */
Not sure if they should be removed from the DTS?
Also are you sure it's PA17? Because it's writen '&pio 2 17' I thought the first number was reference to the letter, like A = 0 B = 1 ... H = 7.
Do you know how those numbers 2 and 17 are used if not by letter-number index?
Most probably ...
Right ! It is a typo, it is PC17 ...
