محمد بسام Posted October 20, 2019 Posted October 20, 2019 how to make orange pi one connect to the internet by rj45 cable with using vnc viewer?
guidol Posted October 20, 2019 Posted October 20, 2019 why via vnc-viewer? then do want to connect on a vnc-server on the OPi One or on a vnc-server on another system? RJ45-Cable is Ethernet? Then you can configure the port via armbian-config or nmtui.
محمد بسام Posted October 20, 2019 Author Posted October 20, 2019 On 10/20/2019 at 3:37 PM, guidol said: why via vnc-viewer? then do want to connect on a vnc-server on the OPi One or on a vnc-server on another system? RJ45-Cable is Ethernet? Then you can configure the port via armbian-config or nmtui. Expand I want to play os on the computer no on the external screen ,yes i want to connect on a vnc-server on the OPI One the only way for that is connect the rj45 to the laptop & configure it to make a static IP for opi1 & connect it to "putty" then I can connect with vnc server
guidol Posted October 23, 2019 Posted October 23, 2019 what are the error-messages from the 3 command you did get via OPi FB-Group?: sudo apt update sudo apt upgrade -y sudo apt-get install linux-headers-$(uname -r) You wrote on FB they didnt work - what didnt work? Did you try to compile your driver after these commands?
محمد بسام Posted October 23, 2019 Author Posted October 23, 2019 Yes this result after On 10/23/2019 at 6:41 AM, guidol said: Did you try to compile your driver after these commands? Expand Yes this result after updating headers
محمد بسام Posted October 23, 2019 Author Posted October 23, 2019 After that I tried "make" command as shown & get this error i dont know why
liamnilsson Posted October 24, 2019 Posted October 24, 2019 Somebody with a similar problem suggested this. Fixed the problem for them https://www.howtogeek.com/howto/windows/adding-a-tcpip-route-to-the-windows-routing-table/ Hope it helps. Cheers!
