I have downloaded and installed  Armbian Buster mainline based kernel 4.19.y  & Armbian Bionic mainline based kernel 4.19.y from https://www.armbian.com/nanopi-neo-air/
With both versions I have the same problem:
WiFi is not working at all !
Before the installation I was running the Friendlyarm factory image and had no problems with WiFi.
As I have no internet connection, I can not upload the ArmbianMonitor log.
Running this gives no errors.
root@nanopiair:~# armbianmonitor -v
Starting package integrity check. This might take some time. Be patient please..  .
It appears you don't have any corrupt files or packages!
Running:
root@nanopiair:~# nmcli
dummy0: unmanaged
        "dummy0"
        dummy, F6:6D:BD:D6:43:A9, sw, mtu 1500
lo: unmanaged
        "lo"
        loopback (unknown), 00:00:00:00:00:00, sw, mtu 65536
Use "nmcli device show" to get complete information about known devices and
"nmcli connection show" to get an overview on active connection profiles.
shows there is no wlan0 !
also this
root@nanopiair:~# ifconfig wlan0 up
wlan0: ERROR while getting interface flags: No such device
how can I start the device wlan0 ?
Thomas
Here  my log:
cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
    55  [    0.000011] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
    56  [    0.000028] Switching to timer-based delay loop, resolution 41ns
    57  [    0.000349] Console: colour dummy device 80x30
    58  [    0.000434] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
    59  [    0.000455] pid_max: default: 32768 minimum: 301
    60  [    0.000822] Security Framework initialized
    61  [    0.000842] AppArmor: AppArmor disabled by boot time parameter
    62  [    0.000976] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
    63  [    0.000992] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
    64  [    0.002552] CPU: Testing write buffer coherency: ok
    65  [    0.003308] CPU0: update cpu_capacity 1024
    66  [    0.003322] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    67  [    0.004374] Setting up static identity map for 0x40100000 - 0x40100054
    68  [    0.004647] rcu: Hierarchical SRCU implementation.
    69  [    0.006083] smp: Bringing up secondary CPUs ...
    70  [    0.017349] CPU1: update cpu_capacity 1024
    71  [    0.017361] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    72  [    0.028814] CPU2: update cpu_capacity 1024
    73  [    0.028825] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
    74  [    0.040154] CPU3: update cpu_capacity 1024
    75  [    0.040165] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
    76  [    0.040357] smp: Brought up 1 node, 4 CPUs
    77  [    0.040372] SMP: Total of 4 processors activated (192.00 BogoMIPS).
    78  [    0.040380] CPU: All CPU(s) started in HYP mode.
    79  [    0.040385] CPU: Virtualization extensions available.
    80  [    0.042476] devtmpfs: initialized
    81  [    0.056009] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
    82  [    0.056401] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    83  [    0.056428] futex hash table entries: 1024 (order: 4, 65536 bytes)
    84  [    0.065611] xor: measuring software checksum speed
    85  [    0.104252]    arm4regs  :   598.000 MB/sec
    86  [    0.144364]    8regs     :   356.000 MB/sec
    87  [    0.184498]    32regs    :   365.000 MB/sec
    88  [    0.224621]    neon      :   605.000 MB/sec
    89  [    0.224629] xor: using function: neon (605.000 MB/sec)
    90  [    0.224744] pinctrl core: initialized pinctrl subsystem
    91  [    0.226446] NET: Registered protocol family 16
    92  [    0.230901] DMA: preallocated 2048 KiB pool for atomic coherent allocations
    93  [    0.231823] audit: initializing netlink subsys (disabled)
    94  [    0.232185] audit: type=2000 audit(0.204:1): state=initialized audit_enabled=0 res=1
    95  [    0.233023] cpuidle: using governor ladder
    96  [    0.233084] cpuidle: using governor menu
    97  [    0.234129] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    98  [    0.234138] hw-breakpoint: maximum watchpoint size is 8 bytes.
    99  [    0.333340] raid6: int32x1  gen()    89 MB/s
   100  [    0.401747] raid6: int32x1  xor()    76 MB/s
   101  [    0.469844] raid6: int32x2  gen()   122 MB/s
   102  [    0.537973] raid6: int32x2  xor()    94 MB/s
   103  [    0.606149] raid6: int32x4  gen()   123 MB/s
   104  [    0.674360] raid6: int32x4  xor()    91 MB/s
   105  [    0.742965] raid6: int32x8  gen()   118 MB/s
   106  [    0.811064] raid6: int32x8  xor()    82 MB/s
   107  [    0.879189] raid6: neonx1   gen()   235 MB/s
   108  [    0.947396] raid6: neonx1   xor()   219 MB/s
   109  [    1.015800] raid6: neonx2   gen()   316 MB/s
   110  [    1.083959] raid6: neonx2   xor()   282 MB/s
   111  [    1.152220] raid6: neonx4   gen()   379 MB/s
   112  [    1.220520] raid6: neonx4   xor()   318 MB/s
   113  [    1.288854] raid6: neonx8   gen()   341 MB/s
   114  [    1.357003] raid6: neonx8   xor()   288 MB/s
   115  [    1.357012] raid6: using algorithm neonx4 gen() 379 MB/s
   116  [    1.357018] raid6: .... xor() 318 MB/s, rmw enabled
   117  [    1.357025] raid6: using neon recovery algorithm
   118  [    1.358899] cam500b-avdd: supplied by vcc3v3
   119  [    1.359375] cam500b-dovdd: supplied by vcc3v3
   120  [    1.359810] cam500b-dvdd: supplied by vcc3v3
   121  [    1.360923] SCSI subsystem initialized
   122  [    1.361404] libata version 3.00 loaded.
   123  [    1.361777] usbcore: registered new interface driver usbfs
   124  [    1.361874] usbcore: registered new interface driver hub
   125  [    1.362010] usbcore: registered new device driver usb
   126  [    1.362362] media: Linux media interface: v0.10
   127  [    1.362419] videodev: Linux video capture interface: v2.00
   128  [    1.362643] pps_core: LinuxPPS API ver. 1 registered
   129  [    1.362651] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
   130  [    1.362682] PTP clock support registered
   131  [    1.365701] clocksource: Switched to clocksource arch_sys_counter
   132  [    1.580662] VFS: Disk quotas dquot_6.6.0
   133  [    1.580795] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
   134  [    1.596212] NET: Registered protocol family 2
   135  [    1.597498] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
   136  [    1.597548] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
   137  [    1.597643] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
   138  [    1.597873] TCP: Hash tables configured (established 4096 bind 4096)
   139  [    1.598071] UDP hash table entries: 256 (order: 1, 8192 bytes)
   140  [    1.598126] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
   141  [    1.598457] NET: Registered protocol family 1
   142  [    1.599478] RPC: Registered named UNIX socket transport module.
   143  [    1.599487] RPC: Registered udp transport module.
   144  [    1.599493] RPC: Registered tcp transport module.
   145  [    1.599500] RPC: Registered tcp NFSv4.1 backchannel transport module.
   146  [    1.599921] Trying to unpack rootfs image as initramfs...
   147  [    2.387514] Freeing initrd memory: 6592K
   148  [    2.390983] Initialise system trusted keyrings
   149  [    2.391377] workingset: timestamp_bits=14 max_order=17 bucket_order=3
   150  [    2.403030] zbud: loaded
   151  [    2.407406] NFS: Registering the id_resolver key type
   152  [    2.407446] Key type id_resolver registered
   153  [    2.407453] Key type id_legacy registered
   154  [    2.407476] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
   155  [    2.407484] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
   156  [    2.409585] JFS: nTxBlock = 3929, nTxLock = 31436
   157  [    2.417763] SGI XFS with ACLs, security attributes, realtime, no debug enabled
   158  [    2.432571] Key type asymmetric registered
   159  [    2.432589] Asymmetric key parser 'x509' registered
   160  [    2.432718] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
   161  [    2.432980] io scheduler noop registered
   162  [    2.432990] io scheduler deadline registered
   163  [    2.433344] io scheduler cfq registered (default)
   164  [    2.433355] io scheduler mq-deadline registered
   165  [    2.433363] io scheduler kyber registered
   166  [    2.433609] io scheduler bfq registered
   167  [    2.444809] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
   168  [    2.447875] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
   169  [    2.547351] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
   170  [    2.551648] console [ttyS0] disabled
   171  [    2.571903] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 40, base_baud = 1500000) is a U6_16550A
   172  [    2.571996] console [ttyS0] enabled
   173  [    2.593621] 1c28c00.serial: ttyS1 at MMIO 0x1c28c00 (irq = 41, base_baud = 1500000) is a U6_16550A
   174  [    2.604381] brd: module loaded
   175  [    2.615171] loop: module loaded
   176  [    2.619475] libphy: Fixed MDIO Bus: probed
   177  [    2.621747] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
   178  [    2.621756] ehci-platform: EHCI generic platform driver
   179  [    2.622118] ehci-platform 1c1a000.usb: EHCI Host Controller
   180  [    2.622167] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
   181  [    2.623607] ehci-platform 1c1a000.usb: irq 28, io mem 0x01c1a000
   182  [    2.637707] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
   183  [    2.638260] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
   184  [    2.638277] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   185  [    2.638288] usb usb1: Product: EHCI Host Controller
   186  [    2.638299] usb usb1: Manufacturer: Linux 4.19.64-sunxi ehci_hcd
   187  [    2.638311] usb usb1: SerialNumber: 1c1a000.usb
   188  [    2.639367] hub 1-0:1.0: USB hub found
   189  [    2.639470] hub 1-0:1.0: 1 port detected
   190  [    2.640488] ehci-platform 1c1b000.usb: EHCI Host Controller
   191  [    2.640534] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 2
   192  [    2.641002] ehci-platform 1c1b000.usb: irq 30, io mem 0x01c1b000
   193  [    2.653705] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
   194  [    2.654160] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
   195  [    2.654175] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   196  [    2.654187] usb usb2: Product: EHCI Host Controller
   197  [    2.654198] usb usb2: Manufacturer: Linux 4.19.64-sunxi ehci_hcd
   198  [    2.654209] usb usb2: SerialNumber: 1c1b000.usb
   199  [    2.655110] hub 2-0:1.0: USB hub found
   200  [    2.655199] hub 2-0:1.0: 1 port detected
   201  [    2.656149] ehci-platform 1c1c000.usb: EHCI Host Controller
   202  [    2.656189] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 3
   203  [    2.656610] ehci-platform 1c1c000.usb: irq 32, io mem 0x01c1c000
   204  [    2.669733] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
   205  [    2.670178] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
   206  [    2.670193] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   207  [    2.670205] usb usb3: Product: EHCI Host Controller
   208  [    2.670216] usb usb3: Manufacturer: Linux 4.19.64-sunxi ehci_hcd
   209  [    2.670228] usb usb3: SerialNumber: 1c1c000.usb
   210  [    2.671071] hub 3-0:1.0: USB hub found
   211  [    2.671156] hub 3-0:1.0: 1 port detected
   212  [    2.672081] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
   213  [    2.672119] ohci-platform: OHCI generic platform driver
   214  [    2.672458] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
   215  [    2.672498] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 4
   216  [    2.672840] ohci-platform 1c1a400.usb: irq 29, io mem 0x01c1a400
   217  [    2.734166] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
   218  [    2.734181] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   219  [    2.734193] usb usb4: Product: Generic Platform OHCI controller
   220  [    2.734205] usb usb4: Manufacturer: Linux 4.19.64-sunxi ohci_hcd
   221  [    2.734216] usb usb4: SerialNumber: 1c1a400.usb
   222  [    2.735152] hub 4-0:1.0: USB hub found
   223  [    2.735239] hub 4-0:1.0: 1 port detected
   224  [    2.736164] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
   225  [    2.736204] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 5
   226  [    2.736557] ohci-platform 1c1b400.usb: irq 31, io mem 0x01c1b400
   227  [    2.798164] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
   228  [    2.798179] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   229  [    2.798191] usb usb5: Product: Generic Platform OHCI controller
   230  [    2.798203] usb usb5: Manufacturer: Linux 4.19.64-sunxi ohci_hcd
   231  [    2.798214] usb usb5: SerialNumber: 1c1b400.usb
   232  [    2.799078] hub 5-0:1.0: USB hub found
   233  [    2.799161] hub 5-0:1.0: 1 port detected
   234  [    2.800073] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
   235  [    2.800114] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 6
   236  [    2.800483] ohci-platform 1c1c400.usb: irq 33, io mem 0x01c1c400
   237  [    2.862173] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
   238  [    2.862188] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   239  [    2.862200] usb usb6: Product: Generic Platform OHCI controller
   240  [    2.862211] usb usb6: Manufacturer: Linux 4.19.64-sunxi ohci_hcd
   241  [    2.862222] usb usb6: SerialNumber: 1c1c400.usb
   242  [    2.863073] hub 6-0:1.0: USB hub found
   243  [    2.863156] hub 6-0:1.0: 1 port detected
   244  [    2.864944] usbcore: registered new interface driver usb-storage
   245  [    2.865519] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
   246  [    2.865624] usb_phy_generic usb_phy_generic.0.auto: Linked as a consumer to regulator.0
   247  [    2.867826] sun6i-rtc 1f00000.rtc: rtc core: registered rtc-sun6i as rtc0
   248  [    2.867839] sun6i-rtc 1f00000.rtc: RTC enabled
   249  [    2.868236] i2c /dev entries driver
   250  [    2.872117] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
   251  [    2.873836] sunxi-mmc 1c0f000.mmc: Linked as a consumer to regulator.2
   252  [    2.874797] sunxi-mmc 1c0f000.mmc: Got CD GPIO
   253  [    2.875202] ledtrig-cpu: registered to indicate activity on CPUs
   254  [    2.875334] hidraw: raw HID events driver (C) Jiri Kosina
   255  [    2.875567] usbcore: registered new interface driver usbhid
   256  [    2.875572] usbhid: USB HID core driver
   257  [    2.883394] Initializing XFRM netlink socket
   258  [    2.884666] NET: Registered protocol family 10
   259  [    2.897890] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
   260  [    2.898666] sunxi-mmc 1c10000.mmc: Linked as a consumer to regulator.2
   261  [    2.901135] sunxi-mmc 1c11000.mmc: Linked as a consumer to regulator.2
   262  [    2.926474] sunxi-mmc 1c11000.mmc: initialized, max. request size: 16384 KB
   263  [    2.933290] mmc0: host does not support reading read-only switch, assuming write-enable
   264  [    2.935406] mmc0: new high speed SDHC card at address 0007
   265  [    2.938042] mmcblk0: mmc0:0007 SD8GB 7.42 GiB
   266  [    2.940947]  mmcblk0: p1
   267  [    2.968779] Segment Routing with IPv6
   268  [    2.968959] NET: Registered protocol family 17
   269  [    2.969007] NET: Registered protocol family 15
   270  [    2.969110] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
   271  [    2.969194] 8021q: 802.1Q VLAN Support v1.8
   272  [    2.970246] rfkill_gpio rfkill_bt: sunxi-bt device registered.
   273  [    2.970441] Key type dns_resolver registered
   274  [    2.971286] Registering SWP/SWPB emulation handler
   275  [    2.972347] registered taskstats version 1
   276  [    2.972356] Loading compiled-in X.509 certificates
   277  [    2.972518] zswap: loaded using pool lzo/zbud
   278  [    2.976154] Btrfs loaded, crc32c=crc32c-generic
   279  [    3.014504] Key type encrypted registered
   280  [    3.025915] mmc1: new DDR MMC card at address 0001
   281  [    3.028534] mmcblk1: mmc1:0001 8GTF4R 7.28 GiB
   282  [    3.030402] mmcblk1boot0: mmc1:0001 8GTF4R partition 1 4.00 MiB
   283  [    3.032195] mmcblk1boot1: mmc1:0001 8GTF4R partition 2 4.00 MiB
   284  [    3.033804] sun6i-rtc 1f00000.rtc: setting system clock to 2019-11-03 13:23:34 UTC (1572787414)
   285  [    3.034179] of_cfs_init
   286  [    3.034359] of_cfs_init: OK
   287  [    3.034639] vcc3v0: disabling
   288  [    3.034651] vcc5v0: disabling
   289  [    3.034660] cam500b-avdd: disabling
   290  [    3.034668] cam500b-dovdd: disabling
   291  [    3.034676] cam500b-dvdd: disabling
   292  [    3.036037]  mmcblk1: p1
   293  [    3.045580] Freeing unused kernel memory: 1024K
   294  [    3.062137] Run /init as init process
   295  [    4.259987] random: fast init done
   296  [    4.273570] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
   297  [    4.505819] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB
   298  [    5.580923] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
   299  [    6.472788] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
   300  [    6.474199] systemd[1]: Detected architecture arm.
   301  [    6.511078] systemd[1]: Set hostname to <nanopiair>.
   302  [    6.514132] systemd[1]: Failed to bump fs.file-max, ignoring: Invalid argument
   303  [    7.608252] random: systemd: uninitialized urandom read (16 bytes read)
   304  [    7.630729] random: systemd: uninitialized urandom read (16 bytes read)
   305  [    7.631366] systemd[1]: Listening on initctl Compatibility Named Pipe.
   306  [    7.646105] random: systemd: uninitialized urandom read (16 bytes read)
   307  [    7.646851] systemd[1]: Listening on udev Kernel Socket.
   308  [    7.666409] systemd[1]: Created slice system-serial\x2dgetty.slice.
   309  [    7.679483] systemd[1]: Listening on Journal Audit Socket.
   310  [    7.694546] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
   311  [    7.714011] systemd[1]: Reached target Swap.
   312  [    8.339190] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
   313  [    8.484373] cfg80211: Loading compiled-in X.509 certificates for regulatory database
   314  [    8.591951] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
   315  [    8.593870] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
   316  [    8.593889] platform regulatory.0: Falling back to syfs fallback for: regulatory.db
   317  [    8.776447] systemd-journald[223]: Received request to flush runtime journal from PID 1
   318  [    9.026506] g_serial gadget: Gadget Serial v2.4
   319  [    9.026528] g_serial gadget: g_serial ready
   320  [   10.151493] cfg80211: failed to load regulatory.db
   321  [   10.293464] zram: Added device: zram0
   322  [   10.297514] zram: Added device: zram1
   323  [   10.299035] zram: Added device: zram2
   324  [   10.374459] zram1: detected capacity change from 0 to 258052096
   325  [   10.516681] sun8i_ths 1c25000.thermal-sensor: no memory resources defined
   326  [   10.516726] sun8i_ths: probe of 1c25000.thermal-sensor failed with error -22
   327  [   10.566392] thermal thermal_zone0: failed to read out thermal zone (-110)
   328  [   10.624929] lima 1c40000.gpu: bus rate = 200000000
   329  [   10.624945] lima 1c40000.gpu: mod rate = 384000000
   330  [   10.634903] [TTM] Zone  kernel: Available graphics memory: 252002 kiB
   331  [   10.634918] [TTM] Initializing pool allocator
   332  [   10.635770] lima 1c40000.gpu: gp - mali400 version major 1 minor 1
   333  [   10.635819] lima 1c40000.gpu: pp0 - mali400 version major 1 minor 1
   334  [   10.635859] lima 1c40000.gpu: pp1 - mali400 version major 1 minor 1
   335  [   10.635894] lima 1c40000.gpu: l2 cache 64K, 4-way, 64byte cache line, 64bit external bus
   336  [   10.655541] [drm] Initialized lima 1.0.0 20170325 for 1c40000.gpu on minor 0
   337  [   11.506329] Adding 252000k swap on /dev/zram1.  Priority:5 extents:1 across:252000k SSFS
   338  [   11.629473] random: crng init done
   339  [   11.629491] random: 7 urandom warning(s) missed due to ratelimiting
   340  [   11.651908] zram0: detected capacity change from 0 to 52428800
   341  [   14.108771] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
   342
   343  ### armbian-release:
   344
   345  # PLEASE DO NOT EDIT THIS FILE
   346  BOARD=nanopiair
   347  BOARD_NAME="NanoPi Air"
   348  BOARDFAMILY=sun8i
   349  BUILD_REPOSITORY_URL=https://github.com/armbian/build
   350  BUILD_REPOSITORY_COMMIT=d8bfdf48
   351  VERSION=5.93
   352  LINUXFAMILY=sunxi
   353  BRANCH=next
   354  ARCH=arm
   355  IMAGE_TYPE=stable
   356  BOARD_TYPE=conf
   357  INITRD_ARCH=arm
   358  KERNEL_IMAGE_TYPE=zImage
   359
   360  ### boot environment:
   361
   362  verbosity=1
   363  logo=disabled
   364  console=serial
   365  disp_mode=1920x1080p60
   366  overlay_prefix=sun8i-h3
   367  overlays=usbhost1 usbhost2
   368  rootdev=UUID=35e2b40e-c54a-4387-9fda-d5b7bff9e053
   369  rootfstype=ext4
   370
   371
   372  ### lsusb:
   373
   374  Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
   375  Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
   376  Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
   377  Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
   378  Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
   379  Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
   380
   381  ### lscpu:
   382
   383  Architecture:        armv7l
   384  Byte Order:          Little Endian
   385  CPU(s):              4
   386  On-line CPU(s) list: 0-3
   387  Thread(s) per core:  1
   388  Core(s) per socket:  4
   389  Socket(s):           1
   390  Vendor ID:           ARM
   391  Model:               5
   392  Model name:          Cortex-A7
   393  Stepping:            r0p5
   394  CPU max MHz:         1368.0000
   395  CPU min MHz:         120.0000
   396  BogoMIPS:            136.80
   397  Flags:               half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
   398
   399  ### cpuinfo:
   400
   401  processor       : 0
   402  model name      : ARMv7 Processor rev 5 (v7l)
   403  BogoMIPS        : 136.80
   404  Features        : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
   405  CPU implementer : 0x41
   406  CPU architecture: 7
   407  CPU variant     : 0x0
   408  CPU part        : 0xc07
   409  CPU revision    : 5
   410
   411  processor       : 1
   412  model name      : ARMv7 Processor rev 5 (v7l)
   413  BogoMIPS        : 136.80
   414  Features        : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
   415  CPU implementer : 0x41
   416  CPU architecture: 7
   417  CPU variant     : 0x0
   418  CPU part        : 0xc07
   419  CPU revision    : 5
   420
   421  processor       : 2
   422  model name      : ARMv7 Processor rev 5 (v7l)
   423  BogoMIPS        : 136.80
   424  Features        : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
   425  CPU implementer : 0x41
   426  CPU architecture: 7
   427  CPU variant     : 0x0
   428  CPU part        : 0xc07
   429  CPU revision    : 5
   430
   431  processor       : 3
   432  model name      : ARMv7 Processor rev 5 (v7l)
   433  BogoMIPS        : 136.80
   434  Features        : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
   435  CPU implementer : 0x41
   436  CPU architecture: 7
   437  CPU variant     : 0x0
   438  CPU part        : 0xc07
   439  CPU revision    : 5
   440
   441  Hardware        : Allwinner sun8i Family
   442  Revision        : 0000
   443  Serial          : 02c0008140384e35
   444  Sun 03 Nov 2019 01:23:49 PM UTC | NanoPi Air | 5.93 | armhf | armv7l | 4.19.64-sunxi
   445
   446  ### meminfo:
   447
   448  MemTotal:         504004 kB
   449  MemFree:          400304 kB
   450  MemAvailable:     435156 kB
   451  Buffers:            7360 kB
   452  Cached:            25532 kB
   453  SwapCached:            0 kB
   454  Active:            27084 kB
   455  Inactive:          13452 kB
   456  Active(anon):       7752 kB
   457  Inactive(anon):     1848 kB
   458  Active(file):      19332 kB
   459  Inactive(file):    11604 kB
   460  Unevictable:           0 kB
   461  Mlocked:               0 kB
   462  HighTotal:             0 kB
   463  HighFree:              0 kB
   464  LowTotal:         504004 kB
   465  LowFree:          400304 kB
   466  SwapTotal:        252000 kB
   467  SwapFree:         252000 kB
   468  Dirty:                28 kB
   469  Writeback:             0 kB
   470  AnonPages:          7592 kB
   471  Mapped:             8204 kB
   472  Shmem:              1960 kB
   473  Slab:              36204 kB
   474  SReclaimable:      13920 kB
   475  SUnreclaim:        22284 kB
   476  KernelStack:         904 kB
   477  PageTables:          428 kB
   478  NFS_Unstable:          0 kB
   479  Bounce:                0 kB
   480  WritebackTmp:          0 kB
   481  CommitLimit:      504000 kB
   482  Committed_AS:      14632 kB
   483  VmallocTotal:     507904 kB
   484  VmallocUsed:           0 kB
   485  VmallocChunk:          0 kB
   486  Percpu:              528 kB
   487  CmaTotal:         131072 kB
   488  CmaFree:          128964 kB
   489
   490  ### virtual memory:
   491
   492  vm.admin_reserve_kbytes = 8192
   493  vm.block_dump = 0
   494  vm.compact_unevictable_allowed = 1
   495  vm.dirty_background_bytes = 0
   496  vm.dirty_background_ratio = 10
   497  vm.dirty_bytes = 0
   498  vm.dirty_expire_centisecs = 3000
   499  vm.dirty_ratio = 20
   500  vm.dirtytime_expire_seconds = 43200
   501  vm.dirty_writeback_centisecs = 500
   502  vm.drop_caches = 0
   503  vm.extfrag_threshold = 500
   504
   505  ### [resize2fs] 8GB media so leaving 2 percent spare area. Start resizing partition /dev/mmcblk0p1 now:
   506
   507  major minor  #blocks  name
   508
   509     1        0       4096 ram0
   510     1        1       4096 ram1
   511     1        2       4096 ram2
   512     1        3       4096 ram3
   513   179        0    7782400 mmcblk0
   514   179        1    1138688 mmcblk0p1
   515   179        8    7634944 mmcblk1
   516   179        9    7554496 mmcblk1p1
   517   254        0      51200 zram0
   518   254        1     252004 zram1
   519
   520  Executing fdisk, fsck and partprobe:
   521  vm.highmem_is_dirtyable = 0
   522  vm.laptop_mode = 0
   523  vm.legacy_va_layout = 0
   524  vm.lowmem_reserve_ratio = 32    0       0
   525
   526  Welcome to fdisk (util-linux 2.33.1).
   527  Changes will remain in memory only, until you decide to write them.
   528  Be careful before using the write command.
   529
   530
   531  Command (m for help): Selected partition 1
   532  Partition 1 has been deleted.
   533
   534  Command (m for help): Partition type
   535     p   primary (0 primary, 0 extended, 4 free)
   536     e   extended (container for logical partitions)
   537  Select (default p): Partition number (1-4, default 1): First sector (2048-15564799, default 2048): Last sector, +/-sectors or +/-size{K,M,G,T,P} (8192-15564799, default 15564799): vm.max_map_count = 65530
   538  vm.min_free_kbytes = 2417
   539
   540  Created a new partition 1 of type 'Linux' and of size 7.3 GiB.
   541  Partition #1 contains a ext4 signature.
   542
   543  Command (m for help): vm.mmap_min_addr = 4096
   544  vm.mmap_rnd_bits = 8
   545  vm.oom_dump_tasks = 1
   546  vm.oom_kill_allocating_task = 0
   547  vm.overcommit_kbytes = 0
   548  vm.overcommit_memory = 0
   549  vm.overcommit_ratio = 50
   550  vm.page-cluster = 0
   551  vm.panic_on_oom = 0
   552  vm.percpu_pagelist_fraction = 0
   553  vm.stat_interval = 1
   554  vm.swappiness = 100
   555  vm.user_reserve_kbytes = 15348
   556  vm.vfs_cache_pressure = 100
   557  vm.watermark_scale_factor = 10
   558
   559  ### ip addr:
   560
   561
   562  The partition table has been altered.
   563  Syncing disks.
   564
   565  1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
   566      link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
   567      inet XXX.XXX.0.1/8 scope host lo
   568         valid_lft forever preferred_lft forever
   569      inet6 ::1/128 scope host
   570         valid_lft forever preferred_lft forever
   571  2: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000
   572      link/ether fe:b8:20:15:65:b5 brd ff:ff:ff:ff:ff:ff
   573
   574  ### partitions:
   575
   576  major minor  #blocks  name
   577
   578   179        0    7782400 mmcblk0
   579   179        1    7622656 mmcblk0p1
   580   179        8    7634944 mmcblk1
   581   179        9    7554496 mmcblk1p1
   582   254        0      51200 zram0
   583   254        1     252004 zram1
   584
   585  ### df:
   586
   587  udev            179M     0  179M   0% /dev
   588  tmpfs            50M  2.0M   48M   4% /run
   589  /dev/mmcblk0p1  1.1G  901M  124M  88% /
   590  tmpfs           247M     0  247M   0% /dev/shm
   591  tmpfs           5.0M     0  5.0M   0% /run/lock
   592  tmpfs           247M     0  247M   0% /sys/fs/cgroup
   593  tmpfs           247M  4.0K  247M   1% /tmp
   594  /dev/zram0       49M  536K   45M   2% /var/log
   595
   596  ### lsblk:
   597
   598  NAME         FSTYPE   SIZE MOUNTPOINT UUID
   599  mmcblk0               7.4G
   600  └─mmcblk0p1  ext4     7.3G /          35e2b40e-c54a-4387-9fda-d5b7bff9e053
   601  mmcblk1               7.3G
   602  └─mmcblk1p1  ext4     7.2G            9dc442a5-d123-4804-979c-3701b5c60f71
   603  mmcblk1boot0            4M
   604  mmcblk1boot1            4M
   605  zram0                  50M /var/log
   606
   607  ### zramctl:
   608
   609  NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
   610  /dev/zram1 lzo         246.1M    4K   78B   12K       4 [SWAP]
   611  /dev/zram0 zstd           50M  620K   99K  416K       4 /var/log
   612
   613  ### mtab:
   614
   615  /dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
   616  /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
   617  /dev/zram0 /var/log ext4 rw,relatime,discard 0 0
   618  New partition table:
   619
   620  major minor  #blocks  name
   621
   622     1        0       4096 ram0
   623     1        1       4096 ram1
   624     1        2       4096 ram2
   625     1        3       4096 ram3
   626   179        0    7782400 mmcblk0
   627   179        1    7622656 mmcblk0p1
   628   179        8    7634944 mmcblk1
   629   179        9    7554496 mmcblk1p1
   630   254        0      51200 zram0
   631   254        1     252004 zram1
   632
   633  Now trying to resize ext4 filesystem on /dev/mmcblk0p1 to the limits:
   634
   635  resize2fs 1.44.5 (15-Dec-2018)
   636
   637  ### mmc1:0001 info:
   638
   639                manfid: 0x000015
   640                   cid: 15010038475446345206a25c475da5fb
   641                 fwrev: 0x0600000000000000
   642                   rca: 0x0001
   643                   csd: d02701320f5903fff6dbffef8e40400d
   644             life_time: 0x01 0x01
   645                   ocr: 0x00200000
   646                  type: MMC
   647  enhanced_area_offset: 18446744073709551594
   648                  date: 10/2018
   649                 hwrev: 0x0
   650                   prv: 0x6
   651                   dsr: 0x404
   652           ffu_capable: 1
   653                serial: 0xa25c475d
   654    raw_rpmb_size_mult: 0x4
   655            erase_size: 524288
   656          pre_eol_info: 0x01
   657           rel_sectors: 0x1
   658               cmdq_en: 0
   659                uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=8GTF4R MODALIAS=mmc:block
   660    enhanced_area_size: 4294967274
   661                 oemid: 0x0100
   662                   rev: 0x8
   663  preferred_erase_size: 4194304
   664                  name: 8GTF4R
   665
   666  ### mmc0:0007 info:
   667
   668                manfid: 0x000041
   669                   cid: 4134325344384742300005c6d500d259
   670                 fwrev: 0x0
   671                   rca: 0x0007
   672                   csd: 400e00325b5900003b5f7f800a400075
   673                   ocr: 0x00200000
   674                  type: SD
   675                  date: 02/2013
   676                 hwrev: 0x3
   677                   dsr: 0x404
   678                serial: 0x0005c6d5
   679            erase_size: 512
   680                uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SD8GB MODALIAS=mmc:block
   681                   ssr: 00000000030000000400900100aa1f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
   682                   scr: 0235800001000000
   683                 oemid: 0x3432
   684  preferred_erase_size: 4194304
   685                  name: SD8GB
   686
   687  ### Boot system health:
   688
   689  Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU  C.St.
   690  13:23:54: 1368MHz  0.86  47%  20%  17%   0%   9%   0% 40.8°C  0/15
   691  13:23:54: 1368MHz  0.86  36%   4%   0%   0%  31%   0% 40.4°C  0/15
   692  13:23:55: 1368MHz  0.86  25%   4%   0%   1%  19%   0% 40.8°C  0/15
   693  13:23:55: 1368MHz  0.86  30%   4%   0%   1%  23%   0% 40.1°C  0/15
   694  13:23:56: 1368MHz  0.86  30%   5%   0%   1%  23%   0% 40.4°C  0/15
   695  Filesystem at /dev/mmcblk0p1 is mounted on /; on-line resizing required
   696  old_desc_blocks = 1, new_desc_blocks = 1
   697  The filesystem on /dev/mmcblk0p1 is now 1905664 (4k) blocks long.
   698
   699
   700  ### [resize2fs] Start resizing ext4 partition /dev/mmcblk0p1 now
   701
   702  resize2fs 1.44.5 (15-Dec-2018)
   703  The filesystem is already 1905664 (4k) blocks long.  Nothing to do!
   704
   705
   706  ### quick iozone test: 4      191      220     3375     6089     5100      219
   707
   708  ### [firstrun] Recreated SSH keys (entropy: 2229 2362)
   709
   710  ### Activated 1 lzo zram swap devices with 246 MB each
   711
   712  ### Activated Armbian ramlog partition with zstd compression
   713
   714  Sun 03 Nov 2019 01:26:07 PM UTC | NanoPi Air | 5.93 | armhf | armv7l | 4.19.64-sunxi
   715
   716  ### dmesg:
   717
   718  [    0.000000] Booting Linux on physical CPU 0x0
   719  [    0.000000] Linux version 4.19.64-sunxi (root@nightly) (gcc version 7.4.1 20181213 [linaro-7.4-2019.02 revision 56ec6f6b99cc167ff0c2f8e1a2eed33b1edc85d4] (Linaro GCC 7.4-2019.02)) #5.93 SMP Mon Aug 5 18:05:36 CEST 2019
   720  [    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d
   721  [    0.000000] CPU: div instructions available: patching division code
   722  [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
   723  [    0.000000] OF: fdt: Machine model: FriendlyARM NanoPi NEO Air
   724  [    0.000000] Memory policy: Data cache writealloc
   725  [    0.000000] cma: Reserved 128 MiB at 0x57c00000
   726  [    0.000000] On node 0 totalpages: 131072
   727  [    0.000000]   Normal zone: 1152 pages used for memmap
   728  [    0.000000]   Normal zone: 0 pages reserved
   729  [    0.000000]   Normal zone: 131072 pages, LIFO batch:31
   730  [    0.000000] psci: probing for conduit method from DT.
   731  [    0.000000] psci: Using PSCI v0.1 Function IDs from DT
   732  [    0.000000] random: get_random_bytes called from start_kernel+0x8d/0x3c2 with crng_init=0
   733  [    0.000000] percpu: Embedded 18 pages/cpu s41548 r8192 d23988 u73728
   734  [    0.000000] pcpu-alloc: s41548 r8192 d23988 u73728 alloc=18*4096
   735  [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
   736  [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 129920
   737  [    0.000000] Kernel command line: root=UUID=35e2b40e-c54a-4387-9fda-d5b7bff9e053 rootwait rootfstype=ext4 console=ttyS0,115200 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 loglevel=1 ubootpart=33db2c12-01 ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1
   738  [    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
   739  [    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
   740  [    0.000000] allocated 524288 bytes of page_ext
   741  [    0.000000] Memory: 365316K/524288K available (9216K kernel code, 1004K rwdata, 2580K rodata, 1024K init, 331K bss, 27900K reserved, 131072K cma-reserved, 0K highmem)
   742  [    0.000000] Virtual kernel memory layout:
   743                     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
   744                     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
   745                     vmalloc : 0xe0800000 - 0xff800000   ( 496 MB)
   746                     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
   747                     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
   748                     modules : 0xbf800000 - 0xbfe00000   (   6 MB)
   749                       .text : 0x(ptrval) - 0x(ptrval)   (10208 kB)
   750                       .init : 0x(ptrval) - 0x(ptrval)   (1024 kB)
   751                       .data : 0x(ptrval) - 0x(ptrval)   (1005 kB)
   752                        .bss : 0x(ptrval) - 0x(ptrval)   ( 332 kB)
   753  [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
   754  [    0.000000] ftrace: allocating 40003 entries in 79 pages
   755  [    0.000000] rcu: Hierarchical RCU implementation.
   756  [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
   757  [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
   758  [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
   759  [    0.000000] GIC: Using split EOI/Deactivate mode
   760  [    0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
   761  [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
   762  [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
   763  [    0.000011] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
   764  [    0.000028] Switching to timer-based delay loop, resolution 41ns
   765  [    0.000347] Console: colour dummy device 80x30
   766  [    0.000429] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
   767  [    0.000449] pid_max: default: 32768 minimum: 301
   768  [    0.000815] Security Framework initialized
   769  [    0.000836] AppArmor: AppArmor disabled by boot time parameter
   770  [    0.000970] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
   771  [    0.000986] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
   772  [    0.002539] CPU: Testing write buffer coherency: ok
   773  [    0.003289] CPU0: update cpu_capacity 1024
   774  [    0.003301] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
   775  [    0.004360] Setting up static identity map for 0x40100000 - 0x40100054
   776  [    0.004637] rcu: Hierarchical SRCU implementation.
   777  [    0.006066] smp: Bringing up secondary CPUs ...
   778  [    0.017327] CPU1: update cpu_capacity 1024
   779  [    0.017339] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
   780  [    0.028787] CPU2: update cpu_capacity 1024
   781  [    0.028798] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
   782  [    0.040138] CPU3: update cpu_capacity 1024
   783  [    0.040149] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
   784  [    0.040337] smp: Brought up 1 node, 4 CPUs
   785  [    0.040352] SMP: Total of 4 processors activated (192.00 BogoMIPS).
   786  [    0.040359] CPU: All CPU(s) started in HYP mode.
   787  [    0.040364] CPU: Virtualization extensions available.
   788  [    0.042458] devtmpfs: initialized
   789  [    0.055996] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
   790  [    0.056391] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
   791  [    0.056417] futex hash table entries: 1024 (order: 4, 65536 bytes)
   792  [    0.065607] xor: measuring software checksum speed
   793  [    0.104250]    arm4regs  :   598.000 MB/sec
   794  [    0.144363]    8regs     :   356.000 MB/sec
   795  [    0.184499]    32regs    :   365.000 MB/sec
   796  [    0.224622]    neon      :   605.000 MB/sec
   797  [    0.224631] xor: using function: neon (605.000 MB/sec)
   798  [    0.224741] pinctrl core: initialized pinctrl subsystem
   799  [    0.226453] NET: Registered protocol family 16
   800  [    0.230885] DMA: preallocated 2048 KiB pool for atomic coherent allocations
   801  [    0.231805] audit: initializing netlink subsys (disabled)
   802  [    0.232171] audit: type=2000 audit(0.204:1): state=initialized audit_enabled=0 res=1
   803  [    0.233010] cpuidle: using governor ladder
   804  [    0.233071] cpuidle: using governor menu
   805  [    0.234119] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
   806  [    0.234129] hw-breakpoint: maximum watchpoint size is 8 bytes.
   807  [    0.333316] raid6: int32x1  gen()    89 MB/s
   808  [    0.401703] raid6: int32x1  xor()    76 MB/s
   809  [    0.469828] raid6: int32x2  gen()   122 MB/s
   810  [    0.537942] raid6: int32x2  xor()    94 MB/s
   811  [    0.606138] raid6: int32x4  gen()   123 MB/s
   812  [    0.674361] raid6: int32x4  xor()    91 MB/s
   813  [    0.742958] raid6: int32x8  gen()   118 MB/s
   814  [    0.811055] raid6: int32x8  xor()    82 MB/s
   815  [    0.879178] raid6: neonx1   gen()   235 MB/s
   816  [    0.947410] raid6: neonx1   xor()   219 MB/s
   817  [    1.015800] raid6: neonx2   gen()   316 MB/s
   818  [    1.083984] raid6: neonx2   xor()   282 MB/s
   819  [    1.152223] raid6: neonx4   gen()   379 MB/s
   820  [    1.220440] raid6: neonx4   xor()   318 MB/s
   821  [    1.288858] raid6: neonx8   gen()   341 MB/s
   822  [    1.357018] raid6: neonx8   xor()   288 MB/s
   823  [    1.357026] raid6: using algorithm neonx4 gen() 379 MB/s
   824  [    1.357032] raid6: .... xor() 318 MB/s, rmw enabled
   825  [    1.357038] raid6: using neon recovery algorithm
   826  [    1.358927] cam500b-avdd: supplied by vcc3v3
   827  [    1.359405] cam500b-dovdd: supplied by vcc3v3
   828  [    1.359842] cam500b-dvdd: supplied by vcc3v3
   829  [    1.361015] SCSI subsystem initialized
   830  [    1.361425] libata version 3.00 loaded.
   831  [    1.361800] usbcore: registered new interface driver usbfs
   832  [    1.361894] usbcore: registered new interface driver hub
   833  [    1.362028] usbcore: registered new device driver usb
   834  [    1.362378] media: Linux media interface: v0.10
   835  [    1.362435] videodev: Linux video capture interface: v2.00
   836  [    1.362664] pps_core: LinuxPPS API ver. 1 registered
   837  [    1.362673] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
   838  [    1.362703] PTP clock support registered
   839  [    1.365729] clocksource: Switched to clocksource arch_sys_counter
   840  [    1.580677] VFS: Disk quotas dquot_6.6.0
   841  [    1.580815] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
   842  [    1.596241] NET: Registered protocol family 2
   843  [    1.597544] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
   844  [    1.597597] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
   845  [    1.597799] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
   846  [    1.597921] TCP: Hash tables configured (established 4096 bind 4096)
   847  [    1.598116] UDP hash table entries: 256 (order: 1, 8192 bytes)
   848  [    1.598171] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
   849  [    1.598497] NET: Registered protocol family 1
   850  [    1.599532] RPC: Registered named UNIX socket transport module.
   851  [    1.599541] RPC: Registered udp transport module.
   852  [    1.599546] RPC: Registered tcp transport module.
   853  [    1.599554] RPC: Registered tcp NFSv4.1 backchannel transport module.
   854  [    1.599978] Trying to unpack rootfs image as initramfs...
   855  [    2.387274] Freeing initrd memory: 6592K
   856  [    2.390741] Initialise system trusted keyrings
   857  [    2.391118] workingset: timestamp_bits=14 max_order=17 bucket_order=3
   858  [    2.402795] zbud: loaded
   859  [    2.407198] NFS: Registering the id_resolver key type
   860  [    2.407240] Key type id_resolver registered
   861  [    2.407246] Key type id_legacy registered
   862  [    2.407270] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
   863  [    2.407279] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
   864  [    2.409386] JFS: nTxBlock = 3929, nTxLock = 31436
   865  [    2.417507] SGI XFS with ACLs, security attributes, realtime, no debug enabled
   866  [    2.432778] Key type asymmetric registered
   867  [    2.432796] Asymmetric key parser 'x509' registered
   868  [    2.432913] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
   869  [    2.433215] io scheduler noop registered
   870  [    2.433224] io scheduler deadline registered
   871  [    2.433578] io scheduler cfq registered (default)
   872  [    2.433589] io scheduler mq-deadline registered
   873  [    2.433597] io scheduler kyber registered
   874  [    2.433923] io scheduler bfq registered
   875  [    2.445033] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
   876  [    2.448150] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
   877  [    2.548036] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
   878  [    2.552333] console [ttyS0] disabled
   879  [    2.572589] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 40, base_baud = 1500000) is a U6_16550A
   880  [    2.572685] console [ttyS0] enabled
   881  [    2.594329] 1c28c00.serial: ttyS1 at MMIO 0x1c28c00 (irq = 41, base_baud = 1500000) is a U6_16550A
   882  [    2.605100] brd: module loaded
   883  [    2.615910] loop: module loaded
   884  [    2.620278] libphy: Fixed MDIO Bus: probed
   885  [    2.622548] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
   886  [    2.622559] ehci-platform: EHCI generic platform driver
   887  [    2.622923] ehci-platform 1c1a000.usb: EHCI Host Controller
   888  [    2.622973] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
   889  [    2.624287] ehci-platform 1c1a000.usb: irq 28, io mem 0x01c1a000
   890  [    2.637768] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
   891  [    2.638305] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
   892  [    2.638321] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   893  [    2.638333] usb usb1: Product: EHCI Host Controller
   894  [    2.638345] usb usb1: Manufacturer: Linux 4.19.64-sunxi ehci_hcd
   895  [    2.638355] usb usb1: SerialNumber: 1c1a000.usb
   896  [    2.639362] hub 1-0:1.0: USB hub found
   897  [    2.639456] hub 1-0:1.0: 1 port detected
   898  [    2.640460] ehci-platform 1c1b000.usb: EHCI Host Controller
   899  [    2.640513] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 2
   900  [    2.641026] ehci-platform 1c1b000.usb: irq 30, io mem 0x01c1b000
   901  [    2.653756] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
   902  [    2.654218] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
   903  [    2.654233] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   904  [    2.654245] usb usb2: Product: EHCI Host Controller
   905  [    2.654256] usb usb2: Manufacturer: Linux 4.19.64-sunxi ehci_hcd
   906  [    2.654268] usb usb2: SerialNumber: 1c1b000.usb
   907  [    2.655156] hub 2-0:1.0: USB hub found
   908  [    2.655268] hub 2-0:1.0: 1 port detected
   909  [    2.656224] ehci-platform 1c1c000.usb: EHCI Host Controller
   910  [    2.656263] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 3
   911  [    2.656919] ehci-platform 1c1c000.usb: irq 32, io mem 0x01c1c000
   912  [    2.669733] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
   913  [    2.670168] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
   914  [    2.670183] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   915  [    2.670195] usb usb3: Product: EHCI Host Controller
   916  [    2.670206] usb usb3: Manufacturer: Linux 4.19.64-sunxi ehci_hcd
   917  [    2.670217] usb usb3: SerialNumber: 1c1c000.usb
   918  [    2.671109] hub 3-0:1.0: USB hub found
   919  [    2.671207] hub 3-0:1.0: 1 port detected
   920  [    2.672107] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
   921  [    2.672146] ohci-platform: OHCI generic platform driver
   922  [    2.672510] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
   923  [    2.672549] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 4
   924  [    2.672917] ohci-platform 1c1a400.usb: irq 29, io mem 0x01c1a400
   925  [    2.734227] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
   926  [    2.734242] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   927  [    2.734254] usb usb4: Product: Generic Platform OHCI controller
   928  [    2.734266] usb usb4: Manufacturer: Linux 4.19.64-sunxi ohci_hcd
   929  [    2.734276] usb usb4: SerialNumber: 1c1a400.usb
   930  [    2.735135] hub 4-0:1.0: USB hub found
   931  [    2.735225] hub 4-0:1.0: 1 port detected
   932  [    2.736140] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
   933  [    2.736180] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 5
   934  [    2.736594] ohci-platform 1c1b400.usb: irq 31, io mem 0x01c1b400
   935  [    2.798183] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
   936  [    2.798198] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   937  [    2.798210] usb usb5: Product: Generic Platform OHCI controller
   938  [    2.798222] usb usb5: Manufacturer: Linux 4.19.64-sunxi ohci_hcd
   939  [    2.798233] usb usb5: SerialNumber: 1c1b400.usb
   940  [    2.799148] hub 5-0:1.0: USB hub found
   941  [    2.799262] hub 5-0:1.0: 1 port detected
   942  [    2.800183] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
   943  [    2.800223] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 6
   944  [    2.800568] ohci-platform 1c1c400.usb: irq 33, io mem 0x01c1c400
   945  [    2.862237] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
   946  [    2.862252] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   947  [    2.862264] usb usb6: Product: Generic Platform OHCI controller
   948  [    2.862275] usb usb6: Manufacturer: Linux 4.19.64-sunxi ohci_hcd
   949  [    2.862286] usb usb6: SerialNumber: 1c1c400.usb
   950  [    2.863169] hub 6-0:1.0: USB hub found
   951  [    2.863268] hub 6-0:1.0: 1 port detected
   952  [    2.865058] usbcore: registered new interface driver usb-storage
   953  [    2.865605] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
   954  [    2.865831] usb_phy_generic usb_phy_generic.0.auto: Linked as a consumer to regulator.0
   955  [    2.867981] sun6i-rtc 1f00000.rtc: rtc core: registered rtc-sun6i as rtc0
   956  [    2.867994] sun6i-rtc 1f00000.rtc: RTC enabled
   957  [    2.868399] i2c /dev entries driver
   958  [    2.872239] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
   959  [    2.873956] sunxi-mmc 1c0f000.mmc: Linked as a consumer to regulator.2
   960  [    2.874718] ledtrig-cpu: registered to indicate activity on CPUs
   961  [    2.874893] sunxi-mmc 1c0f000.mmc: Got CD GPIO
   962  [    2.874897] hidraw: raw HID events driver (C) Jiri Kosina
   963  [    2.875153] usbcore: registered new interface driver usbhid
   964  [    2.875158] usbhid: USB HID core driver
   965  [    2.882868] Initializing XFRM netlink socket
   966  [    2.884112] NET: Registered protocol family 10
   967  [    2.898501] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
   968  [    2.899247] sunxi-mmc 1c10000.mmc: Linked as a consumer to regulator.2
   969  [    2.901470] sunxi-mmc 1c11000.mmc: Linked as a consumer to regulator.2
   970  [    2.925832] sunxi-mmc 1c11000.mmc: initialized, max. request size: 16384 KB
   971  [    2.935802] mmc0: host does not support reading read-only switch, assuming write-enable
   972  [    2.937964] mmc0: new high speed SDHC card at address 0007
   973  [    2.940492] mmcblk0: mmc0:0007 SD8GB 7.42 GiB
   974  [    2.943626]  mmcblk0: p1
   975  [    2.968250] Segment Routing with IPv6
   976  [    2.968430] NET: Registered protocol family 17
   977  [    2.968477] NET: Registered protocol family 15
   978  [    2.968577] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
   979  [    2.968686] 8021q: 802.1Q VLAN Support v1.8
   980  [    2.969649] rfkill_gpio rfkill_bt: sunxi-bt device registered.
   981  [    2.969930] Key type dns_resolver registered
   982  [    2.970776] Registering SWP/SWPB emulation handler
   983  [    2.971907] registered taskstats version 1
   984  [    2.971917] Loading compiled-in X.509 certificates
   985  [    2.972066] zswap: loaded using pool lzo/zbud
   986  [    2.976086] Btrfs loaded, crc32c=crc32c-generic
   987  [    3.014985] Key type encrypted registered
   988  [    3.029971] mmc1: new DDR MMC card at address 0001
   989  [    3.032652] mmcblk1: mmc1:0001 8GTF4R 7.28 GiB
   990  [    3.033532] sun6i-rtc 1f00000.rtc: setting system clock to 2019-11-03 13:25:52 UTC (1572787552)
   991  [    3.034286] of_cfs_init
   992  [    3.034636] of_cfs_init: OK
   993  [    3.034669] mmcblk1boot0: mmc1:0001 8GTF4R partition 1 4.00 MiB
   994  [    3.035126] vcc3v0: disabling
   995  [    3.035150] vcc5v0: disabling
   996  [    3.035163] cam500b-avdd: disabling
   997  [    3.035176] cam500b-dovdd: disabling
   998  [    3.035188] cam500b-dvdd: disabling
   999  [    3.036718] mmcblk1boot1: mmc1:0001 8GTF4R partition 2 4.00 MiB
  1000  [    3.038758]  mmcblk1: p1
  1001  [    3.046113] Freeing unused kernel memory: 1024K
  1002  [    3.058173] Run /init as init process
  1003  [    4.242351] random: fast init done
  1004  [    4.315439] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
  1005  [    4.549880] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB
  1006  [    5.314738] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
  1007  [    6.212976] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  1008  [    6.214384] systemd[1]: Detected architecture arm.
  1009  [    6.251138] systemd[1]: Set hostname to <nanopiair>.
  1010  [    6.254046] systemd[1]: Failed to bump fs.file-max, ignoring: Invalid argument
  1011  [    7.332961] random: systemd: uninitialized urandom read (16 bytes read)
  1012  [    7.355502] random: systemd: uninitialized urandom read (16 bytes read)
  1013  [    7.364442] systemd[1]: Created slice system-serial\x2dgetty.slice.
  1014  [    7.378057] random: systemd: uninitialized urandom read (16 bytes read)
  1015  [    7.378681] systemd[1]: Listening on initctl Compatibility Named Pipe.
  1016  [    7.390095] systemd[1]: Reached target System Time Synchronized.
  1017  [    7.402817] systemd[1]: Listening on fsck to fsckd communication Socket.
  1018  [    7.430746] systemd[1]: Listening on Syslog Socket.
  1019  [    7.442072] systemd[1]: Reached target Remote File Systems.
  1020  [    8.026250] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  1021  [    8.058968] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
  1022  [    8.171660] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  1023  [    8.173803] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
  1024  [    8.173829] platform regulatory.0: Falling back to syfs fallback for: regulatory.db
  1025  [    8.326260] g_serial gadget: Gadget Serial v2.4
  1026  [    8.326286] g_serial gadget: g_serial ready
  1027  [    8.634903] systemd-journald[222]: Received request to flush runtime journal from PID 1
  1028  [    9.573194] zram: Added device: zram0
  1029  [    9.575823] zram: Added device: zram1
  1030  [    9.577085] zram: Added device: zram2
  1031  [    9.666138] cfg80211: failed to load regulatory.db
  1032  [    9.737802] zram1: detected capacity change from 0 to 258052096
  1033  [    9.915584] sun8i_ths 1c25000.thermal-sensor: no memory resources defined
  1034  [    9.915616] sun8i_ths: probe of 1c25000.thermal-sensor failed with error -22
  1035  [    9.978388] thermal thermal_zone0: failed to read out thermal zone (-110)
  1036  [    9.989143] lima 1c40000.gpu: bus rate = 200000000
  1037  [    9.989156] lima 1c40000.gpu: mod rate = 384000000
  1038  [    9.998683] [TTM] Zone  kernel: Available graphics memory: 252002 kiB
  1039  [    9.998699] [TTM] Initializing pool allocator
  1040  [    9.999885] lima 1c40000.gpu: gp - mali400 version major 1 minor 1
  1041  [    9.999957] lima 1c40000.gpu: pp0 - mali400 version major 1 minor 1
  1042  [   10.000000] lima 1c40000.gpu: pp1 - mali400 version major 1 minor 1
  1043  [   10.000035] lima 1c40000.gpu: l2 cache 64K, 4-way, 64byte cache line, 64bit external bus
  1044  [   10.015038] [drm] Initialized lima 1.0.0 20170325 for 1c40000.gpu on minor 0
  1045  [   10.831514] Adding 252000k swap on /dev/zram1.  Priority:5 extents:1 across:252000k SSFS
  1046  [   10.978185] zram0: detected capacity change from 0 to 52428800
  1047  [   11.116184] random: crng init done
  1048  [   11.116200] random: 7 urandom warning(s) missed due to ratelimiting
  1049  [   13.627465] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
  1050
  1051  ### armbian-release:
  1052
  1053  # PLEASE DO NOT EDIT THIS FILE
  1054  BOARD=nanopiair
  1055  BOARD_NAME="NanoPi Air"
  1056  BOARDFAMILY=sun8i
  1057  BUILD_REPOSITORY_URL=https://github.com/armbian/build
  1058  BUILD_REPOSITORY_COMMIT=d8bfdf48
  1059  VERSION=5.93
  1060  LINUXFAMILY=sunxi
  1061  BRANCH=next
  1062  ARCH=arm
  1063  IMAGE_TYPE=stable
  1064  BOARD_TYPE=conf
  1065  INITRD_ARCH=arm
  1066  KERNEL_IMAGE_TYPE=zImage
  1067
  1068  ### boot environment:
  1069
  1070  verbosity=1
  1071  logo=disabled
  1072  console=serial
  1073  disp_mode=1920x1080p60
  1074  overlay_prefix=sun8i-h3
  1075  overlays=usbhost1 usbhost2
  1076  rootdev=UUID=35e2b40e-c54a-4387-9fda-d5b7bff9e053
  1077  rootfstype=ext4
  1078  usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
  1079
  1080  ### lsusb:
  1081
  1082  Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  1083  Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  1084  Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  1085  Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  1086  Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  1087  Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  1088
  1089  ### lscpu:
  1090
  1091  Architecture:        armv7l
  1092  Byte Order:          Little Endian
  1093  CPU(s):              4
  1094  On-line CPU(s) list: 0-3
  1095  Thread(s) per core:  1
  1096  Core(s) per socket:  4
  1097  Socket(s):           1
  1098  Vendor ID:           ARM
  1099  Model:               5
  1100  Model name:          Cortex-A7
  1101  Stepping:            r0p5
  1102  CPU max MHz:         1368.0000
  1103  CPU min MHz:         120.0000
  1104  BogoMIPS:            136.80
  1105  Flags:               half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
  1106
  1107  ### cpuinfo:
  1108
  1109  processor       : 0
  1110  model name      : ARMv7 Processor rev 5 (v7l)
  1111  BogoMIPS        : 136.80
  1112  Features        : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
  1113  CPU implementer : 0x41
  1114  CPU architecture: 7
  1115  CPU variant     : 0x0
  1116  CPU part        : 0xc07
  1117  CPU revision    : 5
  1118
  1119  processor       : 1
  1120  model name      : ARMv7 Processor rev 5 (v7l)
  1121  BogoMIPS        : 136.80
  1122  Features        : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
  1123  CPU implementer : 0x41
  1124  CPU architecture: 7
  1125  CPU variant     : 0x0
  1126  CPU part        : 0xc07
  1127  CPU revision    : 5
  1128
  1129  processor       : 2
  1130  model name      : ARMv7 Processor rev 5 (v7l)
  1131  BogoMIPS        : 136.80
  1132  Features        : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
  1133  CPU implementer : 0x41
  1134  CPU architecture: 7
  1135  CPU variant     : 0x0
  1136  CPU part        : 0xc07
  1137  CPU revision    : 5
  1138
  1139  processor       : 3
  1140  model name      : ARMv7 Processor rev 5 (v7l)
  1141  BogoMIPS        : 136.80
  1142  Features        : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
  1143  CPU implementer : 0x41
  1144  CPU architecture: 7
  1145  CPU variant     : 0x0
  1146  CPU part        : 0xc07
  1147  CPU revision    : 5
  1148
  1149  Hardware        : Allwinner sun8i Family
  1150  Revision        : 0000
  1151  Serial          : 02c0008140384e35
  1152
  1153  ### meminfo:
  1154
  1155  MemTotal:         504004 kB
  1156  MemFree:          399420 kB
  1157  MemAvailable:     434964 kB
  1158  Buffers:            7568 kB
  1159  Cached:            26052 kB
  1160  SwapCached:            0 kB
  1161  Active:            27720 kB
  1162  Inactive:          14064 kB
  1163  Active(anon):       8292 kB
  1164  Inactive(anon):     1856 kB
  1165  Active(file):      19428 kB
  1166  Inactive(file):    12208 kB
  1167  Unevictable:           0 kB
  1168  Mlocked:               0 kB
  1169  HighTotal:             0 kB
  1170  HighFree:              0 kB
  1171  LowTotal:         504004 kB
  1172  LowFree:          399420 kB
  1173  SwapTotal:        252000 kB
  1174  SwapFree:         252000 kB
  1175  Dirty:                 0 kB
  1176  Writeback:             0 kB
  1177  AnonPages:          8200 kB
  1178  Mapped:             8808 kB
  1179  Shmem:              1944 kB
  1180  Slab:              36144 kB
  1181  SReclaimable:      13912 kB
  1182  SUnreclaim:        22232 kB
  1183  KernelStack:         944 kB
  1184  PageTables:          424 kB
  1185  NFS_Unstable:          0 kB
  1186  Bounce:                0 kB
  1187  WritebackTmp:          0 kB
  1188  CommitLimit:      504000 kB
  1189  Committed_AS:      18776 kB
  1190  VmallocTotal:     507904 kB
  1191  VmallocUsed:           0 kB
  1192  VmallocChunk:          0 kB
  1193  Percpu:              528 kB
  1194  CmaTotal:         131072 kB
  1195  CmaFree:          128964 kB
  1196
  1197  ### virtual memory:
  1198
  1199  vm.admin_reserve_kbytes = 8192
  1200  vm.block_dump = 0
  1201  vm.compact_unevictable_allowed = 1
  1202  vm.dirty_background_bytes = 0
  1203  vm.dirty_background_ratio = 10
  1204  vm.dirty_bytes = 0
  1205  vm.dirty_expire_centisecs = 3000
  1206  vm.dirty_ratio = 20
  1207  vm.dirtytime_expire_seconds = 43200
  1208  vm.dirty_writeback_centisecs = 500
  1209  vm.drop_caches = 0
  1210  vm.extfrag_threshold = 500
  1211  vm.highmem_is_dirtyable = 0
  1212  vm.laptop_mode = 0
  1213  vm.legacy_va_layout = 0
  1214  vm.lowmem_reserve_ratio = 32    0       0
  1215  vm.max_map_count = 65530
  1216  vm.min_free_kbytes = 2417
  1217  vm.mmap_min_addr = 4096
  1218  vm.mmap_rnd_bits = 8
  1219  vm.oom_dump_tasks = 1
  1220  vm.oom_kill_allocating_task = 0
  1221  vm.overcommit_kbytes = 0
  1222  vm.overcommit_memory = 0
  1223  vm.overcommit_ratio = 50
  1224  vm.page-cluster = 0
  1225  vm.panic_on_oom = 0
  1226  vm.percpu_pagelist_fraction = 0
  1227  vm.stat_interval = 1
  1228  vm.swappiness = 100
  1229  vm.user_reserve_kbytes = 15348
  1230  vm.vfs_cache_pressure = 100
  1231  vm.watermark_scale_factor = 10
  1232
  1233  ### ip addr:
  1234
  1235  1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  1236      link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  1237      inet XXX.XXX.0.1/8 scope host lo
  1238         valid_lft forever preferred_lft forever
  1239      inet6 ::1/128 scope host
  1240         valid_lft forever preferred_lft forever
  1241  2: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000
  1242      link/ether f6:6d:bd:d6:43:a9 brd ff:ff:ff:ff:ff:ff
  1243
  1244  ### partitions:
  1245
  1246  major minor  #blocks  name
  1247
  1248   179        0    7782400 mmcblk0
  1249   179        1    7622656 mmcblk0p1
  1250   179        8    7634944 mmcblk1
  1251   179        9    7554496 mmcblk1p1
  1252   254        0      51200 zram0
  1253   254        1     252004 zram1
  1254
  1255  ### df:
  1256
  1257  udev            179M     0  179M   0% /dev
  1258  tmpfs            50M  2.0M   48M   4% /run
  1259  /dev/mmcblk0p1  7.2G  903M  6.2G  13% /
  1260  tmpfs           247M     0  247M   0% /dev/shm
  1261  tmpfs           5.0M     0  5.0M   0% /run/lock
  1262  tmpfs           247M     0  247M   0% /sys/fs/cgroup
  1263  tmpfs           247M  4.0K  247M   1% /tmp
  1264  /dev/zram0       49M  1.2M   44M   3% /var/log
  1265
  1266  ### lsblk:
  1267
  1268  NAME         FSTYPE   SIZE MOUNTPOINT UUID
  1269  mmcblk0               7.4G
  1270  └─mmcblk0p1  ext4     7.3G /          35e2b40e-c54a-4387-9fda-d5b7bff9e053
  1271  mmcblk1               7.3G
  1272  └─mmcblk1p1  ext4     7.2G            9dc442a5-d123-4804-979c-3701b5c60f71
  1273  mmcblk1boot0            4M
  1274  mmcblk1boot1            4M
  1275  zram0                  50M /var/log
  1276
  1277  ### zramctl:
  1278
  1279  NAME       ALGORITHM DISKSIZE  DATA  COMPR TOTAL STREAMS MOUNTPOINT
  1280  /dev/zram1 lzo         246.1M    4K    78B   12K       4 [SWAP]
  1281  /dev/zram0 zstd           50M  1.1M 155.1K  520K       4 /var/log
  1282
  1283  ### mtab:
  1284
  1285  /dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  1286  /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  1287  /dev/zram0 /var/log ext4 rw,relatime,discard 0 0
  1288
  1289  ### mmc1:0001 info:
  1290
  1291                manfid: 0x000015
  1292                   cid: 15010038475446345206a25c475da5fb
  1293                 fwrev: 0x0600000000000000
  1294                   rca: 0x0001
  1295                   csd: d02701320f5903fff6dbffef8e40400d
  1296             life_time: 0x01 0x01
  1297                   ocr: 0x00200000
  1298                  type: MMC
  1299  enhanced_area_offset: 18446744073709551594
  1300                  date: 10/2018
  1301                 hwrev: 0x0
  1302                   prv: 0x6
  1303                   dsr: 0x404
  1304           ffu_capable: 1
  1305                serial: 0xa25c475d
  1306    raw_rpmb_size_mult: 0x4
  1307            erase_size: 524288
  1308          pre_eol_info: 0x01
  1309           rel_sectors: 0x1
  1310               cmdq_en: 0
  1311                uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=8GTF4R MODALIAS=mmc:block
  1312    enhanced_area_size: 4294967274
  1313                 oemid: 0x0100
  1314                   rev: 0x8
  1315  preferred_erase_size: 4194304
  1316                  name: 8GTF4R
  1317
  1318  ### mmc0:0007 info:
  1319
  1320                manfid: 0x000041
  1321                   cid: 4134325344384742300005c6d500d259
  1322                 fwrev: 0x0
  1323                   rca: 0x0007
  1324                   csd: 400e00325b5900003b5f7f800a400075
  1325                   ocr: 0x00200000
  1326                  type: SD
  1327                  date: 02/2013
  1328                 hwrev: 0x3
  1329                   dsr: 0x404
  1330                serial: 0x0005c6d5
  1331            erase_size: 512
  1332                uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SD8GB MODALIAS=mmc:block
  1333                   ssr: 00000000030000000400900100aa1f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  1334                   scr: 0235800001000000
  1335                 oemid: 0x3432
  1336  preferred_erase_size: 4194304
  1337                  name: SD8GB
  1338
  1339  ### Boot system health:
  1340
  1341  Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU  C.St.
  1342  13:26:10: 1368MHz  1.49  49%  23%  22%   0%   3%   0% 51.7°C  0/15
  1343  13:26:11: 1368MHz  1.49  33%   8%  15%   1%   8%   0% 50.7°C  0/15
  1344  13:26:11: 1368MHz  1.49  33%   9%  21%   2%   0%   0% 50.6°C  0/15
  1345  13:26:11: 1368MHz  1.49  32%   6%  23%   1%   0%   0% 50.5°C  0/15
  1346  13:26:12: 1368MHz  1.49  31%   4%  24%   3%   0%   0% 50.3°C  0/15
  1347
  1348  ### lsusb:
  1349
  1350  Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  1351  Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  1352  Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  1353  Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  1354  Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  1355  Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  1356
  1357  /:  Bus 06.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
  1358  /:  Bus 05.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
  1359  /:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
  1360  /:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
  1361  /:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
  1362  /:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
  1363
  1364  ### Installed packages:
  1365
  1366  ii  armbian-config                   5.93                        all          Armbian configuration utility
  1367  ii  armbian-firmware                 5.93                        all          Linux firmware
  1368  ii  armbian-tools-buster             5.93                        armhf        Armbian tools, Cubie bt utils
  1369  ii  hostapd                          3:2.7-99~armbian5.86+1      armhf        IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator
  1370  ii  htop                             2.2.0-3~armbian5.92+1       armhf        interactive processes viewer
  1371  ii  linux-base                       4.6                         all          Linux image base package
  1372  ii  linux-buster-root-next-nanopiair 5.93                        armhf        Armbian tweaks for buster on nanopiair (next branch)
  1373  ii  linux-dtb-next-sunxi             5.93                        armhf        Linux DTB, version 4.19.64-sunxi
  1374  ii  linux-image-next-sunxi           5.93                        armhf        Linux kernel, version 4.19.64-sunxi
  1375  ii  linux-libc-dev:armhf             4.19.37-5+deb10u1           armhf        Linux support headers for userspace development
  1376  ii  linux-u-boot-nanopiair-next      5.93                        armhf        Uboot loader 2019.04
  1377
  1378  ### Loaded modules:
  1379
  1380  Module                  Size  Used by
  1381  zstd                   16384  4
  1382  snd_soc_simple_card    16384  0
  1383  snd_soc_simple_card_utils    16384  1 snd_soc_simple_card
  1384  sun8i_codec_analog     24576  0
  1385  sun8i_adda_pr_regmap    16384  1 sun8i_codec_analog
  1386  sun4i_i2s              20480  0
  1387  lima                   40960  0
  1388  snd_soc_core          114688  4 sun4i_i2s,sun8i_codec_analog,snd_soc_simple_card_utils,snd_soc_simple_card
  1389  sun4i_gpadc_iio        16384  0
  1390  gpu_sched              20480  1 lima
  1391  snd_pcm_dmaengine      16384  1 snd_soc_core
  1392  ttm                    57344  1 lima
  1393  snd_pcm                69632  3 sun4i_i2s,snd_pcm_dmaengine,snd_soc_core
  1394  industrialio           49152  1 sun4i_gpadc_iio
  1395  snd_timer              24576  1 snd_pcm
  1396  snd                    45056  3 snd_timer,snd_soc_core,snd_pcm
  1397  sun8i_ths              16384  0
  1398  soundcore              16384  1 snd
  1399  cpufreq_dt             16384  0
  1400  uio_pdrv_genirq        16384  0
  1401  uio                    16384  1 uio_pdrv_genirq
  1402  thermal_sys            57344  3 cpufreq_dt,sun8i_ths,sun4i_gpadc_iio
  1403  zram                   24576  2
  1404  usb_f_acm              16384  1
  1405  u_serial               20480  3 usb_f_acm
  1406  g_serial               16384  0
  1407  libcomposite           40960  2 g_serial,usb_f_acm
  1408  brcmfmac              159744  0
  1409  brcmutil               16384  1 brcmfmac
  1410  cfg80211              393216  1 brcmfmac
  1411  ip_tables              20480  0
  1412  x_tables               20480  1 ip_tables
  1413  pwrseq_simple          16384  1
  1414
  1415  ### Current system health:
  1416
  1417  Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU  C.St.
  1418  14:20:43:  120MHz  0.22   2%   1%   1%   0%   0%   0% 36.2°C  0/15
  1419  14:20:44:  120MHz  0.22  18%  15%   0%   3%   0%   0% 36.5°C  0/15
  1420  14:20:45:  120MHz  0.22  18%  14%   0%   4%   0%   0% 36.5°C  0/15
  1421  14:20:46:  120MHz  0.22  19%  14%   0%   4%   0%   0% 36.3°C  0/15
  1422  14:20:47:  120MHz  0.22  19%  13%   0%   5%   0%   0% 36.5°C  0/15
  1423  14:20:51:  120MHz  0.28   2%   1%   1%   0%   0%   0% 37.0°C  0/15
  1424  14:20:52:  120MHz  0.28  18%  14%   0%   4%   0%   0% 36.9°C  0/15
  1425  14:20:53:  120MHz  0.34  18%  13%   0%   4%   0%   0% 36.4°C  0/15
  1426  14:20:54:  120MHz  0.34  18%  13%   0%   4%   0%   0% 36.9°C  0/15
  1427  14:20:55:  120MHz  0.34  18%  14%   0%   3%   0%   0% 36.5°C  0/15
  1428
  1429  ### resolv.conf
  1430
  1431  -rw-rw-r-- 1 root root 19 Aug  5 16:08 /etc/resolv.conf
  1432  nameserver XXX.XXX.0.1
  1433
  1434  ### Current sysinfo:
  1435
  1436  Linux 4.19.64-sunxi (nanopiair)         11/03/19        _armv7l_        (4 CPU)
  1437
  1438  avg-cpu:  %user   %nice %system %iowait  %steal   %idle
  1439             1.65    0.04    1.07    0.12    0.00   97.13
  1440
  1441  Device             tps    kB_read/s    kB_wrtn/s    kB_read    kB_wrtn
  1442  ram0              0.00         0.00         0.00          0          0
  1443  ram1              0.00         0.00         0.00          0          0
  1444  ram2              0.00         0.00         0.00          0          0
  1445  ram3              0.00         0.00         0.00          0          0
  1446  mmcblk0          11.17       255.43        16.87     844613      55784
  1447  mmcblk0p1        11.13       254.48        16.87     841477      55784
  1448  mmcblk1           0.07         1.91         0.00       6316          0
  1449  mmcblk1p1         0.02         0.96         0.00       3180          0
  1450  mmcblk1boot1      0.02         0.07         0.00        232          0
  1451  mmcblk1boot0      0.02         0.07         0.00        232          0
  1452  zram0             0.22         0.24         0.66        780       2184
  1453  zram1             0.42         0.41         1.27       1348       4204
  1454  zram2             0.00         0.00         0.00          0          0
  1455
  1456  procs -----------------------memory---------------------- ---swap-- -----io---- -system-- --------cpu--------
  1457   r  b         swpd         free         buff        cache   si   so    bi    bo   in   cs  us  sy  id  wa  st
  1458   0  0         4608        51716        22528       352536    0    0    65     4   29   34   2   1  97   0   0
  1459
  1460                total        used        free      shared  buff/cache   available
  1461  Mem:          492Mi        75Mi        50Mi       2.0Mi       366Mi       404Mi
  1462  Swap:         246Mi       4.0Mi       241Mi
  1463
  1464  NAME       ALGORITHM DISKSIZE  DATA  COMPR TOTAL STREAMS MOUNTPOINT
  1465  /dev/zram1 lzo         246.1M  4.1M   1.9M  2.4M       4 [SWAP]
  1466  /dev/zram0 zstd           50M  1.3M 203.8K  608K       4 /var/log
  1467
  1468   14:20:56 up 55 min,  1 user,  load average: 0.34, 0.10, 0.07
  1469
  1470  [    0.230885] DMA: preallocated 2048 KiB pool for atomic coherent allocations
  1471  [    0.231805] audit: initializing netlink subsys (disabled)
  1472  [    0.232171] audit: type=2000 audit(0.204:1): state=initialized audit_enabled=0 res=1
  1473  [    0.233010] cpuidle: using governor ladder
  1474  [    0.233071] cpuidle: using governor menu
  1475  [    0.234119] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
  1476  [    0.234129] hw-breakpoint: maximum watchpoint size is 8 bytes.
  1477  [    0.333316] raid6: int32x1  gen()    89 MB/s
  1478  [    0.401703] raid6: int32x1  xor()    76 MB/s
  1479  [    0.469828] raid6: int32x2  gen()   122 MB/s
  1480  [    0.537942] raid6: int32x2  xor()    94 MB/s
  1481  [    0.606138] raid6: int32x4  gen()   123 MB/s
  1482  [    0.674361] raid6: int32x4  xor()    91 MB/s
  1483  [    0.742958] raid6: int32x8  gen()   118 MB/s
  1484  [    0.811055] raid6: int32x8  xor()    82 MB/s
  1485  [    0.879178] raid6: neonx1   gen()   235 MB/s
  1486  [    0.947410] raid6: neonx1   xor()   219 MB/s
  1487  [    1.015800] raid6: neonx2   gen()   316 MB/s
  1488  [    1.083984] raid6: neonx2   xor()   282 MB/s
  1489  [    1.152223] raid6: neonx4   gen()   379 MB/s
  1490  [    1.220440] raid6: neonx4   xor()   318 MB/s
  1491  [    1.288858] raid6: neonx8   gen()   341 MB/s
  1492  [    1.357018] raid6: neonx8   xor()   288 MB/s
  1493  [    1.357026] raid6: using algorithm neonx4 gen() 379 MB/s
  1494  [    1.357032] raid6: .... xor() 318 MB/s, rmw enabled
  1495  [    1.357038] raid6: using neon recovery algorithm
  1496  [    1.358927] cam500b-avdd: supplied by vcc3v3
  1497  [    1.359405] cam500b-dovdd: supplied by vcc3v3
  1498  [    1.359842] cam500b-dvdd: supplied by vcc3v3
  1499  [    1.361015] SCSI subsystem initialized
  1500  [    1.361425] libata version 3.00 loaded.
  1501  [    1.361800] usbcore: registered new interface driver usbfs
  1502  [    1.361894] usbcore: registered new interface driver hub
  1503  [    1.362028] usbcore: registered new device driver usb
  1504  [    1.362378] media: Linux media interface: v0.10
  1505  [    1.362435] videodev: Linux video capture interface: v2.00
  1506  [    1.362664] pps_core: LinuxPPS API ver. 1 registered
  1507  [    1.362673] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  1508  [    1.362703] PTP clock support registered
  1509  [    1.365729] clocksource: Switched to clocksource arch_sys_counter
  1510  [    1.580677] VFS: Disk quotas dquot_6.6.0
  1511  [    1.580815] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
  1512  [    1.596241] NET: Registered protocol family 2
  1513  [    1.597544] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
  1514  [    1.597597] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
  1515  [    1.597799] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
  1516  [    1.597921] TCP: Hash tables configured (established 4096 bind 4096)
  1517  [    1.598116] UDP hash table entries: 256 (order: 1, 8192 bytes)
  1518  [    1.598171] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
  1519  [    1.598497] NET: Registered protocol family 1
  1520  [    1.599532] RPC: Registered named UNIX socket transport module.
  1521  [    1.599541] RPC: Registered udp transport module.
  1522  [    1.599546] RPC: Registered tcp transport module.
  1523  [    1.599554] RPC: Registered tcp NFSv4.1 backchannel transport module.
  1524  [    1.599978] Trying to unpack rootfs image as initramfs...
  1525  [    2.387274] Freeing initrd memory: 6592K
  1526  [    2.390741] Initialise system trusted keyrings
  1527  [    2.391118] workingset: timestamp_bits=14 max_order=17 bucket_order=3
  1528  [    2.402795] zbud: loaded
  1529  [    2.407198] NFS: Registering the id_resolver key type
  1530  [    2.407240] Key type id_resolver registered
  1531  [    2.407246] Key type id_legacy registered
  1532  [    2.407270] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
  1533  [    2.407279] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
  1534  [    2.409386] JFS: nTxBlock = 3929, nTxLock = 31436
  1535  [    2.417507] SGI XFS with ACLs, security attributes, realtime, no debug enabled
  1536  [    2.432778] Key type asymmetric registered
  1537  [    2.432796] Asymmetric key parser 'x509' registered
  1538  [    2.432913] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
  1539  [    2.433215] io scheduler noop registered
  1540  [    2.433224] io scheduler deadline registered
  1541  [    2.433578] io scheduler cfq registered (default)
  1542  [    2.433589] io scheduler mq-deadline registered
  1543  [    2.433597] io scheduler kyber registered
  1544  [    2.433923] io scheduler bfq registered
  1545  [    2.445033] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
  1546  [    2.448150] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
  1547  [    2.548036] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
  1548  [    2.552333] console [ttyS0] disabled
  1549  [    2.572589] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 40, base_baud = 1500000) is a U6_16550A
  1550  [    2.572685] console [ttyS0] enabled
  1551  [    2.594329] 1c28c00.serial: ttyS1 at MMIO 0x1c28c00 (irq = 41, base_baud = 1500000) is a U6_16550A
  1552  [    2.605100] brd: module loaded
  1553  [    2.615910] loop: module loaded
  1554  [    2.620278] libphy: Fixed MDIO Bus: probed
  1555  [    2.622548] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  1556  [    2.622559] ehci-platform: EHCI generic platform driver
  1557  [    2.622923] ehci-platform 1c1a000.usb: EHCI Host Controller
  1558  [    2.622973] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
  1559  [    2.624287] ehci-platform 1c1a000.usb: irq 28, io mem 0x01c1a000
  1560  [    2.637768] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
  1561  [    2.638305] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
  1562  [    2.638321] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1563  [    2.638333] usb usb1: Product: EHCI Host Controller
  1564  [    2.638345] usb usb1: Manufacturer: Linux 4.19.64-sunxi ehci_hcd
  1565  [    2.638355] usb usb1: SerialNumber: 1c1a000.usb
  1566  [    2.639362] hub 1-0:1.0: USB hub found
  1567  [    2.639456] hub 1-0:1.0: 1 port detected
  1568  [    2.640460] ehci-platform 1c1b000.usb: EHCI Host Controller
  1569  [    2.640513] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 2
  1570  [    2.641026] ehci-platform 1c1b000.usb: irq 30, io mem 0x01c1b000
  1571  [    2.653756] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
  1572  [    2.654218] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
  1573  [    2.654233] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1574  [    2.654245] usb usb2: Product: EHCI Host Controller
  1575  [    2.654256] usb usb2: Manufacturer: Linux 4.19.64-sunxi ehci_hcd
  1576  [    2.654268] usb usb2: SerialNumber: 1c1b000.usb
  1577  [    2.655156] hub 2-0:1.0: USB hub found
  1578  [    2.655268] hub 2-0:1.0: 1 port detected
  1579  [    2.656224] ehci-platform 1c1c000.usb: EHCI Host Controller
  1580  [    2.656263] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 3
  1581  [    2.656919] ehci-platform 1c1c000.usb: irq 32, io mem 0x01c1c000
  1582  [    2.669733] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
  1583  [    2.670168] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
  1584  [    2.670183] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1585  [    2.670195] usb usb3: Product: EHCI Host Controller
  1586  [    2.670206] usb usb3: Manufacturer: Linux 4.19.64-sunxi ehci_hcd
  1587  [    2.670217] usb usb3: SerialNumber: 1c1c000.usb
  1588  [    2.671109] hub 3-0:1.0: USB hub found
  1589  [    2.671207] hub 3-0:1.0: 1 port detected
  1590  [    2.672107] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  1591  [    2.672146] ohci-platform: OHCI generic platform driver
  1592  [    2.672510] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
  1593  [    2.672549] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 4
  1594  [    2.672917] ohci-platform 1c1a400.usb: irq 29, io mem 0x01c1a400
  1595  [    2.734227] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
  1596  [    2.734242] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1597  [    2.734254] usb usb4: Product: Generic Platform OHCI controller
  1598  [    2.734266] usb usb4: Manufacturer: Linux 4.19.64-sunxi ohci_hcd
  1599  [    2.734276] usb usb4: SerialNumber: 1c1a400.usb
  1600  [    2.735135] hub 4-0:1.0: USB hub found
  1601  [    2.735225] hub 4-0:1.0: 1 port detected
  1602  [    2.736140] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
  1603  [    2.736180] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 5
  1604  [    2.736594] ohci-platform 1c1b400.usb: irq 31, io mem 0x01c1b400
  1605  [    2.798183] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
  1606  [    2.798198] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1607  [    2.798210] usb usb5: Product: Generic Platform OHCI controller
  1608  [    2.798222] usb usb5: Manufacturer: Linux 4.19.64-sunxi ohci_hcd
  1609  [    2.798233] usb usb5: SerialNumber: 1c1b400.usb
  1610  [    2.799148] hub 5-0:1.0: USB hub found
  1611  [    2.799262] hub 5-0:1.0: 1 port detected
  1612  [    2.800183] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
  1613  [    2.800223] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 6
  1614  [    2.800568] ohci-platform 1c1c400.usb: irq 33, io mem 0x01c1c400
  1615  [    2.862237] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
  1616  [    2.862252] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1617  [    2.862264] usb usb6: Product: Generic Platform OHCI controller
  1618  [    2.862275] usb usb6: Manufacturer: Linux 4.19.64-sunxi ohci_hcd
  1619  [    2.862286] usb usb6: SerialNumber: 1c1c400.usb
  1620  [    2.863169] hub 6-0:1.0: USB hub found
  1621  [    2.863268] hub 6-0:1.0: 1 port detected
  1622  [    2.865058] usbcore: registered new interface driver usb-storage
  1623  [    2.865605] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
  1624  [    2.865831] usb_phy_generic usb_phy_generic.0.auto: Linked as a consumer to regulator.0
  1625  [    2.867981] sun6i-rtc 1f00000.rtc: rtc core: registered rtc-sun6i as rtc0
  1626  [    2.867994] sun6i-rtc 1f00000.rtc: RTC enabled
  1627  [    2.868399] i2c /dev entries driver
  1628  [    2.872239] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
  1629  [    2.873956] sunxi-mmc 1c0f000.mmc: Linked as a consumer to regulator.2
  1630  [    2.874718] ledtrig-cpu: registered to indicate activity on CPUs
  1631  [    2.874893] sunxi-mmc 1c0f000.mmc: Got CD GPIO
  1632  [    2.874897] hidraw: raw HID events driver (C) Jiri Kosina
  1633  [    2.875153] usbcore: registered new interface driver usbhid
  1634  [    2.875158] usbhid: USB HID core driver
  1635  [    2.882868] Initializing XFRM netlink socket
  1636  [    2.884112] NET: Registered protocol family 10
  1637  [    2.898501] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
  1638  [    2.899247] sunxi-mmc 1c10000.mmc: Linked as a consumer to regulator.2
  1639  [    2.901470] sunxi-mmc 1c11000.mmc: Linked as a consumer to regulator.2
  1640  [    2.925832] sunxi-mmc 1c11000.mmc: initialized, max. request size: 16384 KB
  1641  [    2.935802] mmc0: host does not support reading read-only switch, assuming write-enable
  1642  [    2.937964] mmc0: new high speed SDHC card at address 0007
  1643  [    2.940492] mmcblk0: mmc0:0007 SD8GB 7.42 GiB
  1644  [    2.943626]  mmcblk0: p1
  1645  [    2.968250] Segment Routing with IPv6
  1646  [    2.968430] NET: Registered protocol family 17
  1647  [    2.968477] NET: Registered protocol family 15
  1648  [    2.968577] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
  1649  [    2.968686] 8021q: 802.1Q VLAN Support v1.8
  1650  [    2.969649] rfkill_gpio rfkill_bt: sunxi-bt device registered.
  1651  [    2.969930] Key type dns_resolver registered
  1652  [    2.970776] Registering SWP/SWPB emulation handler
  1653  [    2.971907] registered taskstats version 1
  1654  [    2.971917] Loading compiled-in X.509 certificates
  1655  [    2.972066] zswap: loaded using pool lzo/zbud
  1656  [    2.976086] Btrfs loaded, crc32c=crc32c-generic
  1657  [    3.014985] Key type encrypted registered
  1658  [    3.029971] mmc1: new DDR MMC card at address 0001
  1659  [    3.032652] mmcblk1: mmc1:0001 8GTF4R 7.28 GiB
  1660  [    3.033532] sun6i-rtc 1f00000.rtc: setting system clock to 2019-11-03 13:25:52 UTC (1572787552)
  1661  [    3.034286] of_cfs_init
  1662  [    3.034636] of_cfs_init: OK
  1663  [    3.034669] mmcblk1boot0: mmc1:0001 8GTF4R partition 1 4.00 MiB
  1664  [    3.035126] vcc3v0: disabling
  1665  [    3.035150] vcc5v0: disabling
  1666  [    3.035163] cam500b-avdd: disabling
  1667  [    3.035176] cam500b-dovdd: disabling
  1668  [    3.035188] cam500b-dvdd: disabling
  1669  [    3.036718] mmcblk1boot1: mmc1:0001 8GTF4R partition 2 4.00 MiB
  1670  [    3.038758]  mmcblk1: p1
  1671  [    3.046113] Freeing unused kernel memory: 1024K
  1672  [    3.058173] Run /init as init process
  1673  [    4.242351] random: fast init done
  1674  [    4.315439] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
  1675  [    4.549880] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB
  1676  [    5.314738] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
  1677  [    6.212976] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  1678  [    6.214384] systemd[1]: Detected architecture arm.
  1679  [    6.251138] systemd[1]: Set hostname to <nanopiair>.
  1680  [    6.254046] systemd[1]: Failed to bump fs.file-max, ignoring: Invalid argument
  1681  [    7.332961] random: systemd: uninitialized urandom read (16 bytes read)
  1682  [    7.355502] random: systemd: uninitialized urandom read (16 bytes read)
  1683  [    7.364442] systemd[1]: Created slice system-serial-getty.slice.
  1684  [    7.378057] random: systemd: uninitialized urandom read (16 bytes read)
  1685  [    7.378681] systemd[1]: Listening on initctl Compatibility Named Pipe.
  1686  [    7.390095] systemd[1]: Reached target System Time Synchronized.
  1687  [    7.402817] systemd[1]: Listening on fsck to fsckd communication Socket.
  1688  [    7.430746] systemd[1]: Listening on Syslog Socket.
  1689  [    7.442072] systemd[1]: Reached target Remote File Systems.
  1690  [    8.026250] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  1691  [    8.058968] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
  1692  [    8.171660] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  1693  [    8.173803] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
  1694  [    8.173829] platform regulatory.0: Falling back to syfs fallback for: regulatory.db
  1695  [    8.326260] g_serial gadget: Gadget Serial v2.4
  1696  [    8.326286] g_serial gadget: g_serial ready
  1697  [    8.634903] systemd-journald[222]: Received request to flush runtime journal from PID 1
  1698  [    9.573194] zram: Added device: zram0
  1699  [    9.575823] zram: Added device: zram1
  1700  [    9.577085] zram: Added device: zram2
  1701  [    9.666138] cfg80211: failed to load regulatory.db
  1702  [    9.737802] zram1: detected capacity change from 0 to 258052096
  1703  [    9.915584] sun8i_ths 1c25000.thermal-sensor: no memory resources defined
  1704  [    9.915616] sun8i_ths: probe of 1c25000.thermal-sensor failed with error -22
  1705  [    9.978388] thermal thermal_zone0: failed to read out thermal zone (-110)
  1706  [    9.989143] lima 1c40000.gpu: bus rate = 200000000
  1707  [    9.989156] lima 1c40000.gpu: mod rate = 384000000
  1708  [    9.998683] [TTM] Zone  kernel: Available graphics memory: 252002 kiB
  1709  [    9.998699] [TTM] Initializing pool allocator
  1710  [    9.999885] lima 1c40000.gpu: gp - mali400 version major 1 minor 1
  1711  [    9.999957] lima 1c40000.gpu: pp0 - mali400 version major 1 minor 1
  1712  [   10.000000] lima 1c40000.gpu: pp1 - mali400 version major 1 minor 1
  1713  [   10.000035] lima 1c40000.gpu: l2 cache 64K, 4-way, 64byte cache line, 64bit external bus
  1714  [   10.015038] [drm] Initialized lima 1.0.0 20170325 for 1c40000.gpu on minor 0
  1715  [   10.831514] Adding 252000k swap on /dev/zram1.  Priority:5 extents:1 across:252000k SSFS
  1716  [   10.978185] zram0: detected capacity change from 0 to 52428800
  1717  [   11.116184] random: crng init done
  1718  [   11.116200] random: 7 urandom warning(s) missed due to ratelimiting
  1719  [   13.627465] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
  1720
  1721
  1722  vm.admin_reserve_kbytes = 8192
  1723  vm.block_dump = 0
  1724  vm.compact_unevictable_allowed = 1
  1725  vm.dirty_background_bytes = 0
  1726  vm.dirty_background_ratio = 10
  1727  vm.dirty_bytes = 0
  1728  vm.dirty_expire_centisecs = 3000
  1729  vm.dirty_ratio = 20
  1730  vm.dirty_writeback_centisecs = 500
  1731  vm.dirtytime_expire_seconds = 43200
  1732  vm.drop_caches = 0
  1733  vm.extfrag_threshold = 500
  1734  vm.highmem_is_dirtyable = 0
  1735  vm.laptop_mode = 0
  1736  vm.legacy_va_layout = 0
  1737  vm.lowmem_reserve_ratio = 32    0       0
  1738  vm.max_map_count = 65530
  1739  vm.min_free_kbytes = 2417
  1740  vm.mmap_min_addr = 4096
  1741  vm.mmap_rnd_bits = 8
  1742  vm.oom_dump_tasks = 1
  1743  vm.oom_kill_allocating_task = 0
  1744  vm.overcommit_kbytes = 0
  1745  vm.overcommit_memory = 0
  1746  vm.overcommit_ratio = 50
  1747  vm.page-cluster = 0
  1748  vm.panic_on_oom = 0
  1749  vm.percpu_pagelist_fraction = 0
  1750  vm.stat_interval = 1
  1751  vm.swappiness = 100
  1752  vm.user_reserve_kbytes = 15348
  1753  vm.vfs_cache_pressure = 100
  1754  vm.watermark_scale_factor = 10
  1755
  1756  ### interrupts:
  1757             CPU0       CPU1       CPU2       CPU3
  1758   17:          0          0          0          0     GICv2  50 Level     timer@1c20c00
  1759   18:          0          0          0          0     GICv2  29 Level     arch_timer
  1760   19:      43119      44902      51097      31484     GICv2  30 Level     arch_timer
  1761   22:          0          0          0          0     GICv2  82 Level     1c02000.dma-controller
  1762   24:       9094          0          0      59904     GICv2  92 Level     sunxi-mmc
  1763   25:         25          0          0          0     GICv2  93 Level     sunxi-mmc
  1764   26:        622          0          0          0     GICv2  94 Level     sunxi-mmc
  1765   27:          1          0          0          0     GICv2 103 Level     musb-hdrc.1.auto
  1766   28:          0          0          0          0     GICv2 104 Level     ehci_hcd:usb1
  1767   29:          0          0          0          0     GICv2 105 Level     ohci_hcd:usb4
  1768   30:          0          0          0          0     GICv2 106 Level     ehci_hcd:usb2
  1769   31:          0          0          0          0     GICv2 107 Level     ohci_hcd:usb5
  1770   32:          0          0          0          0     GICv2 108 Level     ehci_hcd:usb3
  1771   33:          0          0          0          0     GICv2 109 Level     ohci_hcd:usb6
  1772   36:      37795          0          0          0     GICv2  63 Level     1c25000.thermal-sensor
  1773   40:       6317          0          0          0     GICv2  32 Level     ttyS0
  1774   42:          0          0          0          0     GICv2  40 Level     mv64xxx_i2c
  1775   44:          0          0          0          0     GICv2  72 Level     1f00000.rtc
  1776   47:          0          0          0          0     GICv2 129 Level     gp
  1777   48:          0          0          0          0     GICv2 130 Level     gpmmu
  1778   49:          0          0          0          0     GICv2 131 Level     pp0
  1779   50:          0          0          0          0     GICv2 132 Level     ppmmu0
  1780   51:          0          0          0          0     GICv2 134 Level     pp1
  1781   52:          0          0          0          0     GICv2 135 Level     ppmmu1
  1782  IPI0:          0          0          0          0  CPU wakeup interrupts
  1783  IPI1:          0          0          0          0  Timer broadcast interrupts
  1784  IPI2:      38039      23734      27852      11673  Rescheduling interrupts
  1785  IPI3:        305        266        250        256  Function call interrupts
  1786  IPI4:          0          0          0          0  CPU stop interrupts
  1787  IPI5:        563         80        115        167  IRQ work interrupts
  1788  IPI6:          0          0          0          0  completion interrupts
  1789  Err:          0
Please upload the whole output above to an online pasteboard service
and provide the URL in the forum where you have been asked for this.
root@nanopiair:~#
23 minutes ago, bbtftf said:
With both versions I have the same problem:
Kernel talks with hardware. It's ours and identical on all boards that have same SoC, 32bit Allwinner in this case. My test device works perfectly fine: http://ix.io/20Hq
Can't see which version (probably) 1.0, Nanopi Neo Air 1608 ... yours might be a bit different?
8 minutes ago, bbtftf said:
Here  my log
Can you get serial console boot from power on too see what u-boot tells.
Here:
U-Boot SPL 2019.04-armbian (Aug 05 2019 - 18:00:58 +0200)
DRAM: 512 MiB
Trying to boot from MMC2
U-Boot 2019.04-armbian (Aug 05 2019 - 18:00:58 +0200) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: FriendlyARM NanoPi NEO Air
DRAM:  512 MiB
MMC:   Device 'mmc@1c11000': seq 1 is in use by 'mmc@1c10000'
mmc@1c0f000: 0, mmc@1c10000: 2, mmc@1c11000: 1
Loading Environment from EXT4... In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
starting USB...
No controllers found
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc1(part 0) is current device
Scanning mmc 1:1...
3798 bytes read in 1 ms (3.6 MiB/s)
U-boot loaded from eMMC or secondary SD
Boot script loaded from mmc
341 bytes read in 1 ms (333 KiB/s)
8121495 bytes read in 625 ms (12.4 MiB/s)
7499128 bytes read in 577 ms (12.4 MiB/s)
30999 bytes read in 8 ms (3.7 MiB/s)
382 bytes read in 9 ms (41 KiB/s)
Applying kernel provided DT overlay sun8i-h3-cir.dtbo
374 bytes read in 8 ms (44.9 KiB/s)
Applying kernel provided DT overlay sun8i-h3-i2c0.dtbo
374 bytes read in 7 ms (51.8 KiB/s)
Applying kernel provided DT overlay sun8i-h3-i2c1.dtbo
Applying kernel provided DT overlay sun8i-h3-i2c2.dtbo
778 bytes read in 7 ms (108.4 KiB/s)
Applying kernel provided DT overlay sun8i-h3-pps-gpio.dtbo
1043 bytes read in 8 ms (127 KiB/s)
Applying kernel provided DT overlay sun8i-h3-spdif-out.dtbo
1177 bytes read in 8 ms (143.6 KiB/s)
Applying kernel provided DT overlay sun8i-h3-spi-add-cs1.dtbo
804 bytes read in 8 ms (97.7 KiB/s)
Applying kernel provided DT overlay sun8i-h3-spi-jedec-nor.dtbo
780 bytes read in 8 ms (94.7 KiB/s)
Applying kernel provided DT overlay sun8i-h3-spi-spidev.dtbo
502 bytes read in 8 ms (60.5 KiB/s)
Applying kernel provided DT overlay sun8i-h3-uart1.dtbo
Applying kernel provided DT overlay sun8i-h3-uart2.dtbo
Applying kernel provided DT overlay sun8i-h3-uart3.dtbo
504 bytes read in 9 ms (54.7 KiB/s)
Applying kernel provided DT overlay sun8i-h3-usbhost0.dtbo
504 bytes read in 8 ms (61.5 KiB/s)
Applying kernel provided DT overlay sun8i-h3-usbhost1.dtbo
Applying kernel provided DT overlay sun8i-h3-usbhost2.dtbo
Applying kernel provided DT overlay sun8i-h3-usbhost3.dtbo
4155 bytes read in 9 ms (450.2 KiB/s)
Applying kernel provided DT fixup script (sun8i-h3-fixup.scr)
## Executing script at 44000000
## Loading init Ramdisk from Legacy Image at 43300000 ...
   Image Name:   uInitrd
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    8121431 Bytes = 7.7 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 43000000
   Booting using the fdt blob at 0x43000000
   Loading Ramdisk to 49841000, end 49fffc57 ... OK
   Loading Device Tree to 497d1000, end 49840fff ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Loading, please wait...
starting version 237
done.
Begin: Will now check root file system ... fsck from util-linux 2.31.1
[/sbin/fsck.ext4 (1) -- /dev/mmcblk1p1] fsck.ext4 -a -C0 /dev/mmcblk1p1
/dev/mmcblk1p1: recovering journal
/dev/mmcblk1p1: clean, 35984/472352 files, 258857/1888624 blocks
done.
done.
Welcome to Ubuntu 18.04.2 LTS!
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Created slice System Slice.
[  OK  ] Reached target Remote File Systems.
[  OK  ] Reached target System Time Synchronized.
[  OK  ] Listening on udev Control Socket.
[  OK  ] Created slice User and Session Slice.
[  OK  ] Reached target Swap.
[  OK  ] Listening on udev Kernel Socket.
[  OK  ] Started ntp-systemd-netif.path.
[  OK  ] Listening on Journal Socket (/dev/log).
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Reached target Local Encrypted Volumes.
[  OK  ] Listening on Journal Audit Socket.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[  OK  ] Reached target Slices.
[  OK  ] Set up automount Arbitrary Executab…rmats File System Automount Point.
[  OK  ] Listening on Journal Socket.
         Mounting Kernel Debug File System...
         Starting Load Kernel Modules...
         Starting Set the console keyboard layout...
         Starting Nameserver information manager...
         Starting Create list of required st…ce nodes for the current kernel...
         Starting udev Coldplug all Devices...
[  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
         Starting Restore / save the current clock...
[  OK  ] Listening on Syslog Socket.
         Starting Journal Service...
         Mounting POSIX Message Queue File System...
[  OK  ] Listening on fsck to fsckd communication Socket.
         Starting Remount Root and Kernel File Systems...
[  OK  ] Mounted Kernel Debug File System.
[  OK  ] Started Load Kernel Modules.
[  OK  ] Started Create list of required sta…vice nodes for the current kernel.
[  OK  ] Started Restore / save the current clock.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Started Remount Root and Kernel File Systems.
[  OK  ] Started Nameserver information manager.
[  OK  ] Reached target Network (Pre).
         Starting Load/Save Random Seed...
         Starting Create Static Device Nodes in /dev...
         Starting Apply Kernel Variables...
         Mounting Kernel Configuration File System...
[  OK  ] Started Load/Save Random Seed.
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Started Create Static Device Nodes in /dev.
[  OK  ] Started Journal Service.
[  OK  ] Started Apply Kernel Variables.
         Starting Flush Journal to Persistent Storage...
         Starting udev Kernel Device Manager...
[  OK  ] Started Flush Journal to Persistent Storage.
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Found device /dev/ttyGS0.
[  OK  ] Started Set the console keyboard layout.
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /tmp...
[  OK  ] Mounted /tmp.
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
         Starting Raise network interfaces...
         Starting Armbian ZRAM config...
         Starting Set console font and keymap...
[  OK  ] Started Set console font and keymap.
[  OK  ] Started Create Volatile Files and Directories.
         Starting Network Name Resolution...
         Starting Update UTMP about System Boot/Shutdown...
         Starting Network Time Synchronization...
[  OK  ] Started Entropy daemon using the HAVEGE algorithm.
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Started udev Coldplug all Devices.
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Host and Network Name Lookups.
[  OK  ] Started Network Time Synchronization.
[  OK  ] Found device /dev/ttyS0.
[  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
         Starting Load/Save RF Kill Switch Status...
[  OK  ] Started Load/Save RF Kill Switch Status.
[  OK  ] Started Raise network interfaces.
[  OK  ] Started Armbian ZRAM config.
[  OK  ] Reached target Sound Card.
         Starting Armbian memory supported logging...
[  OK  ] Started Armbian memory supported logging.
[  OK  ] Reached target System Initialization.
         Starting Armbian hardware monitoring...
[  OK  ] Started Daily apt download activities.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Reached target Sockets.
[  OK  ] Started Discard unused blocks once a week.
[  OK  ] Started Message of the Day.
         Starting Armbian hardware optimization...
[  OK  ] Started Daily apt upgrade and clean activities.
[  OK  ] Started resolvconf-pull-resolved.path.
[  OK  ] Reached target Paths.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target Timers.
[  OK  ] Started Armbian hardware monitoring.
[  OK  ] Started Armbian hardware optimization.
[  OK  ] Reached target Basic System.
         Starting LSB: Patch firmware for ap6212 adapter...
         Starting Login Service...
         Starting LSB: Load kernel modules needed to enable cpufreq scaling...
         Starting System Logging Service...
[  OK  ] Started ntp-systemd-netif.service.
         Starting resolvconf-pull-resolved.service...
         Starting Save/Restore Sound Card State...
         Starting Resets System Activity Data Collector...
[  OK  ] Started D-Bus System Message Bus.
[  OK  ] Started Login Service.
         Starting WPA supplicant...
[  OK  ] Started Regular background program processing daemon.
         Starting Dispatcher daemon for systemd-networkd...
         Starting Network Manager...
[  OK  ] Started System Logging Service.
[  OK  ] Started LSB: Patch firmware for ap6212 adapter.
[  OK  ] Started resolvconf-pull-resolved.service.
[  OK  ] Started Resets System Activity Data Collector.
[  OK  ] Started Save/Restore Sound Card State.
[  OK  ] Started WPA supplicant.
[  OK  ] Started LSB: Load kernel modules needed to enable cpufreq scaling.
         Starting LSB: set CPUFreq kernel parameters...
         Starting Hostname Service...
[  OK  ] Started LSB: set CPUFreq kernel parameters.
         Starting LSB: Set sysfs variables from /etc/sysfs.conf...
[  OK  ] Started Hostname Service.
[  OK  ] Started Network Manager.
         Starting Network Manager Wait Online...
[  OK  ] Reached target Network.
[  OK  ] Started Unattended Upgrades Shutdown.
         Starting Permit User Sessions...
         Starting OpenBSD Secure Shell server...
[  OK  ] Started LSB: Set sysfs variables from /etc/sysfs.conf.
[  OK  ] Started Permit User Sessions.
         Starting Network Manager Script Dispatcher Service...
         Starting Set console scheme...
[  OK  ] Started Set console scheme.
[  OK  ] Created slice system-getty.slice.
[  OK  ] Started Network Manager Script Dispatcher Service.
[  OK  ] Started OpenBSD Secure Shell server.
[  OK  ] Started Dispatcher daemon for systemd-networkd.
         Starting Authorization Manager...
[  OK  ] Started Authorization Manager.
[  OK  ] Started Network Manager Wait Online.
[  OK  ] Reached target Network is Online.
         Starting LSB: Advanced IEEE 802.11 management daemon...
         Starting Message of the Day...
         Starting /etc/rc.local Compatibility...
[  OK  ] Started LSB: Advanced IEEE 802.11 management daemon.
[  OK  ] Started /etc/rc.local Compatibility.
[  OK  ] Started Serial Getty on ttyGS0.
[  OK  ] Started Serial Getty on ttyS0.
[  OK  ] Started Getty on tty1.
[  OK  ] Reached target Login Prompts.
[  OK  ] Reached target Multi-User System.
[  OK  ] Reached target Graphical Interface.
         Starting Update UTMP about System Runlevel Changes...
[  OK  ] Started Update UTMP about System Runlevel Changes.
Ubuntu Bionic with Armbian Linux ttyS0
nanopiair login:
Password:
Those
are certainly not a default settings. Use unmodified image where only usbhost1 and usbhost2 are enabled.
I will try but this is what I have done before.
I was in Armbian config and enabled uarts and usbhosts (because I need them and used them in the Friendlyarm ubuntu 16.04 image)
But I will do another fresh install and report.
Please verify:
After this install I 1,) change password for root, 2.) create an new user , 3.) reboot, 4.) call "nmtui-connect" .
As stated in: https://docs.armbian.com/User-Guide_Getting-Started/
Here is the UBoot log after fresh install of Debian (before first login):
DRAM: 512 MiB
Trying to boot from MMC1
DRAM:  512 MiB
Loading Environment from EXT4... ** File not found /boot/boot.env **
** Unable to read "/boot/boot.env" from mmc0:1 **
In:    serial
Out:   serial
Err:   serial
starting USB...
mmc0 is current device
Scanning mmc 0:1...
3798 bytes read in 2 ms (1.8 MiB/s)
U-boot loaded from SD
181 bytes read in 1 ms (176.8 KiB/s)
6747520 bytes read in 520 ms (12.4 MiB/s)
7499128 bytes read in 574 ms (12.5 MiB/s)
30999 bytes read in 10 ms (3 MiB/s)
504 bytes read in 4 ms (123 KiB/s)
4155 bytes read in 6 ms (675.8 KiB/s)
   Image Name:   uInitrd
   Data Size:    6747456 Bytes = 6.4 MiB
   Loading Ramdisk to 49990000, end 49fff540 ... OK
   Loading Device Tree to 49920000, end 4998ffff ... OK
Starting kernel ...
Starting version 241
done.
Begin: Will now check root file system ... fsck from util-linux 2.33.1
[/sbin/fsck.ext4 (1) -- /dev/mmcblk0p1] fsck.ext4 -a -C0 /dev/mmcblk0p1
/dev/mmcblk0p1: clean, 37217/71280 files, 243192/284672 blocks
done.
done.
Welcome to Debian GNU/Linux 10 (buster)!
[  OK  ] Set up automount Arbitrary…s File System Automount Point.
[  OK  ] Started Dispatch Password …ts to Console Directory Watch.
[  OK  ] Listening on initctl Compatibility Named Pipe.
         Starting Create list of re…odes for the current kernel...
[  OK  ] Started Forward Password R…uests to Wall Directory Watch.
[  OK  ] Started Create list of req… nodes for the current kernel.
         Starting Create System Users...
[  OK  ] Started Create System Users.
         Mounting /tmp...
         Starting Helper to synchronize boot up for ifupdown...
[  OK  ] Started Helper to synchronize boot up for ifupdown.
[  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
[  OK  ] Started Daily rotation of log files.
[  OK  ] Started Daily man-db regeneration.
         Starting Armbian filesystem resize...
[  OK  ] Started Armbian filesystem resize.
         Starting LSB: Load kernel …d to enable cpufreq scaling...
[  OK  ] Started Armbian first run tasks.
[  OK  ] Started LSB: Load kernel m…ded to enable cpufreq scaling.
         Starting Network Time Service...
[  OK  ] Started Network Time Service.
Debian Buster with Armbian Linux ttyS0
nanopiair login:
If wireless doesn't work, it must be some difference on a hardware level.
Sorry, but no luck...
I try to go back to the Friendlyarm image and see if WiFi works there....
I will report.
Miracle?
While waiting for the 6GB Friendlyarm Ubuntu Image I did:
1. Reboot again
2. copied the image with nand-sata-install into eMMC
3. rebooted again
4. and tried nmtui-connect ....
Oh wonder now I got all WLANs in the vincinity and was able to connect....
But I would like to understand why.......
