Over a year (or two?) I used a PS1-line in my ~/-bashrc with many cryptic ANSI-Escape-codes which were hard to read and edit :(
export PS1='\[\033[1;36m\]\u\[\033[1;37m\]@\[\033[1;33m\]\h\[\033[1;37m\](\[\033[1;32m\]$THEIP\[\033[1;37m\])\[\033[1;31m\]:\[\033[1;36m\]\w\[\033[1;31m\]\$\[\033[0m\] '
Today I did installed Linux Lite 4.6 on a PC (a former Chromebox) and did see the nice Powerline prompt and did try to use that on a nanoPi Neo2.
I installed the packages fonts-powerlinepowerline and copied the powerline-script /usr/share/powerline/bindings/bash/powerline.sh
from the pc to the NanoPi Neo2.
It did work after I used UTF8 translation in pUTTY, but it wasnt very perfomant :(
So I decided to cleanup my PS1 line for better reading,
I had to define some variables and then I did put these in my PS1 export line in ~/.bashrc:
export THEIP="$(/sbin/ifconfig | grep "inet " | grep -v 127.0.0. | awk '{print $2}')"
BRed='\[\033[31;1m\]'
BGreen='\[\033[32;1m\]'
BYellow='\[\033[33;1m\]'
BCyan='\[\033[36;1m\]'
BWhite='\[\033[37;1m\]'
Reset='\[\033[0m\]'
UserPromptPS1='\$'
export PS1="${BCyan}\u${BWhite}@${BYellow}\h${BWhite}(${BGreen}${THEIP}${BWhite})${BRed}:${BCyan}\w${BRed}${UserPromptPS1}${Reset} "
# \u    = User
# \h    = Host
# \w	= working directory
# \$	= # for root (uid=0) or $ for user
That worked well and did give me the same result as my old but bad readable PS1-line
Now its - for me - much more easy to edit ;)
As Information some more useable color-definition (B before the color is for Bright and colors starting with On are for the Background):
Black='\[\033[30m\]'
Red='\[\033[31m\]'
Green='\[\033[32m\]'
Yellow='\[\033[33m\]'
Blue='\[\033[34m\]'
Magenta='\[\033[35m\]'
Cyan='\[\033[36m\]'
White='\[\033[37m\]'
BBlack='\[\033[30;1m\]'
BBlue='\[\033[34;1m\]'
BMagenta='\[\033[35;1m\]'
OnBlack='\[\033[40m\]'
OnRed='\[\033[41m\]'
OnGreen='\[\033[42m\]'
OnYellow='\[\033[43m\]'
OnBlue='\[\033[44m\]'
OnMagenta='\[\033[45m\]'
OnCyan='\[\033[46m\]'
OnWhite='\[\033[47m\]'
OnBBlack='\[\033[40;1m\]'
OnBRed='\[\033[41;1m\]'
OnBGreen='\[\033[42;1m\]'
OnBYellow='\[\033[43;1m\]'
OnBBlue='\[\033[44;1m\]'
OnBMagenta='\[\033[45;1m\]'
OnBCyan='\[\033[46;1m\]'
OnBWhite='\[\033[47;1m\]'
Reset='\[\033[0m\]'
Hi @guidol,
You describe your journey to this result, but let's think about somebody who just wants to rebuild your config. Can you do a step by step without your legacy ?
Thank you in advance :beer:
Expand
which of the 2 configs you want to rebuild?
for the non-chromebox (colored on black) prompt line there is already everything you need to put on the end of your ~/.bashrc in the first source-part box above.
for the chromebox prompt you need to install the 2 packages fonts-powerline &  powerline via
apt install fonts-powerline powerline
copy powerline.sh to your home-directory:
cp ./powerline.sh ~/
and append at the end of your ~/.bashrc the line:
source ~/powerline.sh
and change pUTTY to UTF8-translation:
Change Setting => Window => Translation => Remote character set => UTF-8 => Apply
or save it directly to your pUTTY session
then activate the new ~./bashrc while starting a new bash with
bash
or reboot
BTW: you have to change the ~/.bashrc for every user where you want to use it - for me these files are
/home/root/.bashrc    and
/home/guido/.bashrc
Do you got any other questions? ;)
powerline.shFetching info...
Hi Guido,
Thank you. As you mentioned several components I wasn't sure what is really needed and to install was a bit overkill, at first sight.
I could have gone ahead with try and error, but as you already have the knowledge, I thought it was better to ask.
Apart from that, others can now also easily benefit from your lesson 😊
Cheers,
Tido
Expand
hard to read - that's a good point in general with ANSI in general - part of the problem for me is that I have challenges in color vision, so some distros and/or terminals default to items I honestly have trouble with.
a former Chromebox
Expand
How old of a chromebox - is it still supported by ChromeOS?
(FWIW - there are more than a few ChromeBoxes and ChromeBooks that are end of support, so it's a legit question)
More recent versions of ChromeOS have linux app support via Crostini - much easier that Crouton or Gallium that break security of the platform by going into dev mode.
And for those who live on the command line - byobu is like screen and tmux on steroids - and it's in the ubuntu repos...
If one wants to have a fun demo...
byobu rocks...
Expand
@sfx2000 My Chromebox was supported until September 2019 ;)
but one year ago I installed the SeaBIOS ( https://mrchromebox.tech/#home ) and use it as a real PC.
Its a HP CB1-020NG ( Intel Celeron 2955U, 2x 1.40GHz ) and I updated it with 8GB RAM (only one socket)
and a 120GB SSD ( running cool & quiet ) :)
I also got a old Samsung ARM Chromebook :)
Expand
That's actually one of the nicer units, similar to the Windows Stream Mini boxes with different UEFI and obviously windows.
