i want to compile an new Kernel for my BananaPi and used the great script from Igor. (Thanks for your support).
Everything works perfect, but there are one error by the development of the Kernelmodul tusbd.ko. Do you know them?
[ ok ] Installing external applications
--2015-07-03 21:56:33--  http://www.incentivespro.com/usb-redirector-linux-arm-eabi.tar.gz
Auflösen des Hostnamen »www.incentivespro.com (www.incentivespro.com)«... 74.52.236.44
Verbindungsaufbau zu www.incentivespro.com (www.incentivespro.com)|74.52.236.44|:80... verbunden.
HTTP-Anforderung gesendet, warte auf Antwort... 200 OK
Länge: 1851845 (1,8M) [application/x-gzip]
In »»usb-redirector-linux-arm-eabi.tar.gz«« speichern.
100%[===========================================================================================>] 1.851.845   4,27KB/s   in 16s
2015-07-03 21:56:50 (114 KB/s) - »»usb-redirector-linux-arm-eabi.tar.gz«« gespeichert [1851845/1851845]
make -C /home/pit/BananaPi_debian/output/linux-mainline/ M=/home/pit/BananaPi_debian/output/usb-redirector-linux-arm-eabi/files/modules/src/tusbd modules
make[1]: Verzeichnis »/home/pit/BananaPi_debian/output/linux-mainline« wird betreten
make[1]: Warnung: Kein Jobserver verfügbar: -j1 wird gesetzt. »+« zur Ursprungsregel
hinzufügen.
  CC [M]  /home/pit/BananaPi_debian/output/usb-redirector-linux-arm-eabi/files/modules/src/tusbd/usbdcdev.o
  CC [M]  /home/pit/BananaPi_debian/output/usb-redirector-linux-arm-eabi/files/modules/src/tusbd/minor_control.o
/home/pit/BananaPi_debian/output/usb-redirector-linux-arm-eabi/files/modules/src/tusbd/minor_control.c: In function ‘IIIlIllll’:
/home/pit/BananaPi_debian/output/usb-redirector-linux-arm-eabi/files/modules/src/tusbd/minor_control.c:54:1: error: implicit declaration of function ‘strnicmp’ [-Werror=implicit-function-declaration]
 if(strnicmp(IllIll,"\x73\x68\x61\x72\x65",(0x1448+2821-0x1f48))==
cc1: some warnings being treated as errors
make[2]: *** [/home/pit/BananaPi_debian/output/usb-redirector-linux-arm-eabi/files/modules/src/tusbd/minor_control.o] Fehler 1
make[1]: *** [_module_/home/pit/BananaPi_debian/output/usb-redirector-linux-arm-eabi/files/modules/src/tusbd] Fehler 2
make[1]: Verzeichnis »/home/pit/BananaPi_debian/output/linux-mainline« wird verlassen
make: *** [default] Fehler 2
cp: der Aufruf von stat für »/home/pit/BananaPi_debian/output/usb-redirector-linux-arm-eabi/files/modules/src/tusbd/tusbd.ko“ ist nicht möglich: Datei oder Verzeichnis nicht gefunden
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- -C /home/pit/BananaPi_debian/output/linux-mainline/ M=/home/pit/BananaPi_debian/output/rt8192cu  modules
Regards,
Pit
USB redirector fails to compile within kernel 4.x ... I already notified the author and got response that they are aware and working on.
Thanks for bringing up.
