p3f Posted July 3, 2015 Posted July 3, 2015 Hello, i want to compile an new Kernel for my BananaPi and used the great script from Igor. (Thanks for your support). Everything works perfect, but there are one error by the development of the Kernelmodul tusbd.ko. Do you know them? [ ok ] Installing external applications --2015-07-03 21:56:33-- http://www.incentivespro.com/usb-redirector-linux-arm-eabi.tar.gz Auflösen des Hostnamen »www.incentivespro.com (www.incentivespro.com)«... 74.52.236.44 Verbindungsaufbau zu www.incentivespro.com (www.incentivespro.com)|74.52.236.44|:80... verbunden. HTTP-Anforderung gesendet, warte auf Antwort... 200 OK Länge: 1851845 (1,8M) [application/x-gzip] In »»usb-redirector-linux-arm-eabi.tar.gz«« speichern. 100%[===========================================================================================>] 1.851.845 4,27KB/s in 16s 2015-07-03 21:56:50 (114 KB/s) - »»usb-redirector-linux-arm-eabi.tar.gz«« gespeichert [1851845/1851845] make -C /home/pit/BananaPi_debian/output/linux-mainline/ M=/home/pit/BananaPi_debian/output/usb-redirector-linux-arm-eabi/files/modules/src/tusbd modules make[1]: Verzeichnis »/home/pit/BananaPi_debian/output/linux-mainline« wird betreten make[1]: Warnung: Kein Jobserver verfügbar: -j1 wird gesetzt. »+« zur Ursprungsregel hinzufügen. CC [M] /home/pit/BananaPi_debian/output/usb-redirector-linux-arm-eabi/files/modules/src/tusbd/usbdcdev.o CC [M] /home/pit/BananaPi_debian/output/usb-redirector-linux-arm-eabi/files/modules/src/tusbd/minor_control.o /home/pit/BananaPi_debian/output/usb-redirector-linux-arm-eabi/files/modules/src/tusbd/minor_control.c: In function ‘IIIlIllll’: /home/pit/BananaPi_debian/output/usb-redirector-linux-arm-eabi/files/modules/src/tusbd/minor_control.c:54:1: error: implicit declaration of function ‘strnicmp’ [-Werror=implicit-function-declaration] if(strnicmp(IllIll,"\x73\x68\x61\x72\x65",(0x1448+2821-0x1f48))== ^ cc1: some warnings being treated as errors make[2]: *** [/home/pit/BananaPi_debian/output/usb-redirector-linux-arm-eabi/files/modules/src/tusbd/minor_control.o] Fehler 1 make[1]: *** [_module_/home/pit/BananaPi_debian/output/usb-redirector-linux-arm-eabi/files/modules/src/tusbd] Fehler 2 make[1]: Verzeichnis »/home/pit/BananaPi_debian/output/linux-mainline« wird verlassen make: *** [default] Fehler 2 cp: der Aufruf von stat für »/home/pit/BananaPi_debian/output/usb-redirector-linux-arm-eabi/files/modules/src/tusbd/tusbd.ko“ ist nicht möglich: Datei oder Verzeichnis nicht gefunden make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- -C /home/pit/BananaPi_debian/output/linux-mainline/ M=/home/pit/BananaPi_debian/output/rt8192cu modules make[1]: Verzeichnis »/home/pit/BananaPi_debian/output/linux-mainline« wird betreten Regards, Pit
Igor Posted July 4, 2015 Posted July 4, 2015 USB redirector fails to compile within kernel 4.x ... I already notified the author and got response that they are aware and working on. Thanks for bringing up.
