GilGonGan Posted November 8, 2019 Posted November 8, 2019 I did an apt get update and upgrade on my OrangePi Zero and it seems to have just outright stopped near the end. Setting up libssl1.1:armhf (1.1.1d-0+deb10u2) ... Setting up armbian-config (5.98) ... Setting up libssl-dev:armhf (1.1.1d-0+deb10u2) ... Setting up containerd.io (1.2.10-3) ... Setting up sudo (1.8.27-1+deb10u1) ... Setting up armbian-firmware (5.98) ... Setting up docker-ce-cli (5:19.03.4~3-0~debian-buster) ... Setting up openssl (1.1.1d-0+deb10u2) ...Setting up docker-ce (5:19.03.4~3-0~debian-buster) ... It seems to have just stopped there, I'm leaving it for the time being - but I suspect I broke the system, right? I can restore from an SDCard image I think, I have a file somewhere.
GilGonGan Posted November 11, 2019 Author Posted November 11, 2019 Ok so it never recovered. I restored from .IMG file (long process) via DD and rebooted, she's back. What is the CORRECT way for me to apt update / apt upgrade, with docker installed? Do I pause / destroy containers? Type a different command?
Igor Posted November 11, 2019 Posted November 11, 2019 On 11/11/2019 at 10:30 AM, GilGonGan said: What is the CORRECT way for me to apt update / apt upgrade, with docker installed? Expand This is correct way but it can fail in case of: - hardware defects (bad SD card, failed powering = very common) - broken packages On 11/11/2019 at 10:30 AM, GilGonGan said: with docker installed Expand This you need to ask Docker specialists, but I don't think you need to do anything ... Docker engine upgrade could be broken, who know? Not an Armbian issue.
GilGonGan Posted November 11, 2019 Author Posted November 11, 2019 You know what, I did a reboot THEN the update, worked fine. Very happy with Armbian over all, considering how cheapo this hardware is. It's a print and DNS server now (!) great stuff. Thanks 1
