Problem executing scripts APT::Update::Post-Invoke-Success
Hi,
I have Rock64 with fresh armbian installed:
Debian GNU/Linux 10 (buster)
4.4.192-rockchip64
It was installed 2 days ago , first thing I did was "apt-get update" and then "upgrade" which upgraded 3 packages at most.
Now whenever I try to run apt-get update I get error with post install :
~# apt-get update        Hit:1 http://security.debian.org buster/updates InRelease
Hit:3 http://cdn-fastly.deb.debian.org/debian buster InRelease
Hit:2 https://apt.armbian.com buster InRelease
Hit:4 http://cdn-fastly.deb.debian.org/debian buster-updates InRelease
Hit:5 http://cdn-fastly.deb.debian.org/debian buster-backports InRelease
Traceback (most recent call last):
  File "/usr/lib/cnf-update-db", line 26, in <module>
    col.create(db)
  File "/usr/share/command-not-found/CommandNotFound/db/creator.py", line 94, in create
    self._fill_commands(con)
  File "/usr/share/command-not-found/CommandNotFound/db/creator.py", line 132, in _fill_commands
    self._parse_single_contents_file(con, f, fp.stdout)
  File "/usr/share/command-not-found/CommandNotFound/db/creator.py", line 228, in _parse_single_contents_file
    l = l.decode("utf-8")
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xe4 in position 72: invalid continuation byte
Reading package lists... Done
E: Problem executing scripts APT::Update::Post-Invoke-Success 'if /usr/bin/test -w /var/lib/command-not-found/ -a -e /usr/lib/cnf-update-db; then /usr/lib/cnf-update-db > /dev/null; fi'
E: Sub-process returned an error code
Searching in google did not yeld too much results and I'm not linux expert to know what might be culprit
Any help would be awesome
Best Regards
  On 2/29/2020 at 10:08 AM, Igor said:
It's a bug in Ubuntu user land - I didn't investigate further:
https://bugs.launchpad.net/command-not-found/+bug/1824000
Expand
You sure this one is relevant? Traceback in this bugreport end up with "sqlite3.OperationalError: unable to open database file" (it can't open it due to permission issue caused by snapd) and it's looks like unrelated to error we see on Armbian.
