Turgus Posted May 9, 2020 Posted May 9, 2020 ..was confused, because I thought there were already 2 versions of 20.05.4...
erew Posted May 9, 2020 Posted May 9, 2020 20 hours ago, balbes150 said: Where did you get the image ? Why did you change the scripts ? I downloaded the images from here https://yadi.sk/d/_rQgn_FosYuW0g and the uart boot I show up in my post, is a freshly imaged Armbian on a USB SSD, using the meson-g12b-gtking.dtb that came with the image. (I tried multiple versions of Armbian and for a test, later, I tried the corelec DTB to see if it may work, which it didnt even boot Armbian).
dante6913 Posted May 9, 2020 Posted May 9, 2020 Hi, First time that I'm installing I have an odroid c2, and in my emmc I have android 6. So I'm trying to enable multiboot I downloaded the image for my odroid c2 Armbian_20.05.4_Arm-64_bullseye_current_5.7.0-rc3_desktop_20200508.img.xz burned with etcher on my sd card downloaded u-boot-odroid-c2.img burned with etcher on the same sd card edit uEnv.txt pointing to odroid c2 DTB Opened android on c2 with sd card inserted used odroid utility to try to use aml_autoscript.zip but nothing hapens I can't start the script. Is anything that I'm missing? Thanks in advance
dante6913 Posted May 9, 2020 Posted May 9, 2020 17 minutes ago, dante6913 said: Hi, First time that I'm installing I have an odroid c2, and in my emmc I have android 6. So I'm trying to enable multiboot I downloaded the image for my odroid c2 Armbian_20.05.4_Arm-64_bullseye_current_5.7.0-rc3_desktop_20200508.img.xz burned with etcher on my sd card downloaded u-boot-odroid-c2.img burned with etcher on the same sd card edit uEnv.txt pointing to odroid c2 DTB Opened android on c2 with sd card inserted used odroid utility to try to use aml_autoscript.zip but nothing hapens I can't start the script. Is anything that I'm missing? Thanks in advance I have instaled update&backup from apk (com-droidlogic-otaupgrade-2-49567460-7e54b2e37b44fe75b97581da85b68e61.apk) starting the app I can find from local aml_autoscript.zip then it asks if I want update but just reboots and nothing happens
balbes150 Posted May 10, 2020 Author Posted May 10, 2020 19 hours ago, erew said: I downloaded the images from here Show the output of the "printenv" and "help" commands from u-boot 15 hours ago, dante6913 said: Is anything that I'm missing? What result do you want to get (leave Android on eMMC and run other systems with SD\USB) ? Show the list of files on the first eMMC partition (which are used to run Android).
dante6913 Posted May 10, 2020 Posted May 10, 2020 5 minutes ago, balbes150 said: Show the output of the "printenv" and "help" commands from u-boot What result do you want to get (leave Android on eMMC and run other systems with SD\USB) ? Show the list of files on the first eMMC partition (which are used to run Android). I want to run android on the emmc and armbian in the sd. Here is the list of files Android boot-logo.bmp.gz display.bin Image_android boot.ini default.prop edid.bin LOST.DIR
balbes150 Posted May 10, 2020 Author Posted May 10, 2020 3 minutes ago, dante6913 said: I want to run android on the emmc and armbian in the sd. Show the contents of the file (boot.ini)
dante6913 Posted May 10, 2020 Posted May 10, 2020 2 minutes ago, dante6913 said: I want to run android on the emmc and armbian in the sd. Here is the list of files Android boot-logo.bmp.gz display.bin Image_android boot.ini default.prop edid.bin LOST.DIR Sorry are you asking for the rootsystem? acct file_contexts init.usb.rc seapp_contexts addon.d fonts init.zygote32.rc selinux_version app framework internal sepolicy bin fstab.odroidc2 lib service_contexts boot fstab.odroidc2.sdboot lost+found storage build.prop init media swap_zram0 cache init.environ.rc mnt sys charger init.odroidc2.board.rc odroid-usbgps.xml system config init.odroidc2.rc oem tts d init.odroidc2.usb.rc package_config ueventd.odroidc2.rc data init.rc priv-app ueventd.rc default.prop init.recovery.odroidc2.rc proc usr dev init.superuser.rc property_contexts vendor etc init.trace.rc sbin xbin factory init.usb.configfs.rc sdcard
balbes150 Posted May 10, 2020 Author Posted May 10, 2020 2 minutes ago, dante6913 said: Sorry are you asking for the rootsystem? 2 minutes ago, dante6913 said: Android boot-logo.bmp.gz display.bin Image_androidboot.ini default.prop edid.bin LOST.DIR
dante6913 Posted May 10, 2020 Posted May 10, 2020 1 minute ago, balbes150 said: DROIDC2-UBOOT-CONFIG setenv dtbaddr 0x1000000 setenv loadaddr 0x20000000 # Resolution Configuration # 'hdmimode' must be one of below to configure display resolution within # supported by your TV or monitor. # Symbol | Resolution # ----------------------+------------- # "480p60hz" | 720x480 Progressive 60Hz # "576p50hz" | 720x576 Progressive 50Hz # "720p60hz" | 1280x720 Progressive 60Hz # "720p50hz" | 1280x720 Progressive 50Hz # "1080p60hz" | 1920x1080 Progressive 60Hz # "1080p50hz" | 1920x1080 Progressive 50Hz # "1080p30hz" | 1920x1080 Progressive 30Hz # "1080p24hz" | 1920x1080 Progressive 24Hz # "1080i60hz" | 1920x1080 Interlaced 60Hz # "1080i50hz" | 1920x1080 Interlaced 50Hz # "2160p60hz" | 3840x2160 Progressive 60Hz # "2160p50hz" | 3840x2160 Progressive 50Hz # "2160p30hz" | 3840x2160 Progressive 30Hz # "2160p25hz" | 3840x2160 Progressive 25Hz # "2160p24hz" | 3840x2160 Progressive 24Hz # "2160p60hz420" | 3840x2160 Progressive 60Hz YCbCr 4:2:0 # "2160p50hz420" | 3840x2160 Progressive 50Hz YCbCr 4:2:0 # "640x480p60hz" | 640x480 Progressive 60Hz # "800x480p60hz" | 800x480 Progressive 60Hz # "800x600p60hz" | 800x600 Progressive 60Hz # "1024x600p60hz" | 1024x600 Progressive 60Hz # "1024x768p60hz" | 1024x768 Progressive 60Hz # "1280x800p60hz" | 1280x800 Progressive 60Hz # "1280x1024p60hz" | 1280x1024 Progressive 60Hz # "1360x768p60hz" | 1360x768 Progressive 60Hz # "1440x900p60hz" | 1440x900 Progressive 60Hz # "1600x900p60hz" | 1600x900 Progressive 60Hz # "1600x1200p60hz" | 1600x1200 Progressive 60Hz # "1680x1050p60hz" | 1680x1050 Progressive 60Hz # "1920x1200p60hz" | 1920x1200 Progressive 60Hz # "2560x1080p60hz" | 2560x1080 Progressive 60Hz # "2560x1440p60hz" | 2560x1440 Progressive 60Hz # "2560x1600p60hz" | 2560x1600 Progressive 60Hz # "3440x1440p60hz" | 3440x1440 Progressive 60Hz setenv hdmimode "1080p60hz" setenv rootopt "root=/dev/mmcblk0p2 rw init=/init rootwait" setenv consoleopt "console=ttyS0,115200" setenv androidopt "androidboot.hardware=odroidc2 androidboot.serialno=${fbt_id#}" setenv logoopt "osd1,loaded,${fb_addr},${hdmimode}" setenv selinuxopt "androidboot.selinux=disabled" # HDMI/DVI Mode Configuration # This will enforce the signal type of display # "hdmi" - For HDMI interface # "dvi" - For DVI interface setenv vout_mode "hdmi" # Display Auto Detection # "false" or "true" setenv display_autodetect "true" # HPD enable/disable option setenv disablehpd "false" # Overscan offset configuration # All offsets are zero and can be tuned by manual or ODROID Utility setenv overscan_top "0" setenv overscan_left "0" setenv overscan_bottom "0" setenv overscan_right "0" setenv led_onoff "on" suspend_hdmiphy=0 # max cpu frequency in dvfs table / in MHz unit # setenv max_freq "2016" # 2.016GHz # setenv max_freq "1944" # 1.944GHz # setenv max_freq "1920" # 1.920GHz # setenv max_freq "1896" # 1.896GHz # setenv max_freq "1752" # 1.752GHz # setenv max_freq "1680" # 1.680GHz # setenv max_freq "1656" # 1.656GHz # setenv max_freq "1536" # 1.536GHz setenv max_freq "1536" # max cpu-cores # setenv maxcpus "1" # setenv maxcpus "2" # setenv maxcpus "3" setenv maxcpus "4" # disable vu7 setenv disable_vu7 "false" # invert touch screen x,y setenv touch_invert_x "false" setenv touch_invert_y "false" # gpio power key : J2 (2x20) Pin#35, GPIOY.BIT3 #setenv gpiopower "214" # usb timing tweak setenv usbmulticam "false" if test "${display_autodetect}" = "true"; then usb pwren; hdmitx edid; fi if test "${hdmimode}" = "custombuilt"; then setenv cmode "modeline=${modeline}"; fi setenv bootargs "${rootopt} ${consoleopt} hdmimode=${hdmimode} ${cmode} hdmitx=${cecconfig} vout=${vout_mode} disablehpd=${disablehpd} logo=${logoopt} ${androidopt} ${selinuxopt} suspend_hdmiphy=${suspend_hdmiphy} led_onoff=${led_onoff} max_freq=${max_freq} maxcpus=${maxcpus} disable_vu7=${disable_vu7} touch_invert_x=${touch_invert_x} touch_invert_y=${touch_invert_y} usbmulticam=${usbmulticam} gpiopower=${gpiopower}" save showlogo ${hdmimode} #usb pwren movi read dtb 0 ${dtbaddr} # load kernel from vat or boot partition. movi read boot 0 ${loadaddr} #fatload mmc 0:1 ${loadaddr} Image_android booti ${loadaddr} - ${dtbaddr}
balbes150 Posted May 10, 2020 Author Posted May 10, 2020 You don't need to activate multi-upload, just add a couple of lines to this file to start it. Write what system you want to run , and I'll write what needs to be added to (boot.ini) on eMMC.
dante6913 Posted May 10, 2020 Posted May 10, 2020 1 minute ago, balbes150 said: You don't need to activate multi-upload, just add a couple of lines to this file to start it. Write what system you want to run , and I'll write what needs to be added to (boot.ini) on eMMC. Can you kindly tell me what to write? Thank you.
dante6913 Posted May 10, 2020 Posted May 10, 2020 1 minute ago, dante6913 said: Can you kindly tell me what to write? Thank you. Armbian_20.05.4_Arm-64_bullseye_current_5.7.0-rc3_desktop_20200508.img.xz
balbes150 Posted May 10, 2020 Author Posted May 10, 2020 16 hours ago, dante6913 said: I downloaded the image for my odroid c2 Armbian_20.05.4_Arm-64_bullseye_current_5.7.0-rc3_desktop_20200508.img.xz burned with etcher on my sd card downloaded u-boot-odroid-c2.img burned with etcher on the same sd card edit uEnv.txt pointing to odroid c2 DTB If you have u-boot to eMMC, you don't need to write u-boot to SD. To run ArmbianTV from an SD card or USB drive, you just need to edit (boot.ini) on eMMC. Add these lines after the first line. for SD DROIDC2-UBOOT-CONFIG setenv dtbaddr 0x1000000 setenv loadaddr 0x20000000 fatload mmc 1 loadaddr boot.scr source loadaddr # Resolution Configuration # 'hdmimode' must be one of below to configure display resolution within for USB DROIDC2-UBOOT-CONFIG setenv dtbaddr 0x1000000 setenv loadaddr 0x20000000 usb start fatload usb 0 loadaddr boot.scr source loadaddr # Resolution Configuration # 'hdmimode' must be one of below to configure display resolution within for Sd + USB DROIDC2-UBOOT-CONFIG setenv dtbaddr 0x1000000 setenv loadaddr 0x20000000 usb start fatload usb 0 loadaddr boot.scr source loadaddr fatload mmc 1 loadaddr boot.scr source loadaddr # Resolution Configuration # 'hdmimode' must be one of below to configure display resolution within
dante6913 Posted May 10, 2020 Posted May 10, 2020 29 minutes ago, balbes150 said: If you have u-boot to eMMC, you don't need to write u-boot to SD. To run ArmbianTV from an SD card or USB drive, you just need to edit (boot.ini) on eMMC. Add these lines after the first line. for SD DROIDC2-UBOOT-CONFIG setenv dtbaddr 0x1000000 setenv loadaddr 0x20000000 fatload mmc 1 loadaddr boot.scr source loadaddr # Resolution Configuration # 'hdmimode' must be one of below to configure display resolution within for USB DROIDC2-UBOOT-CONFIG setenv dtbaddr 0x1000000 setenv loadaddr 0x20000000 usb start fatload usb 0 loadaddr boot.scr source loadaddr # Resolution Configuration # 'hdmimode' must be one of below to configure display resolution within for Sd + USB DROIDC2-UBOOT-CONFIG setenv dtbaddr 0x1000000 setenv loadaddr 0x20000000 usb start fatload usb 0 loadaddr boot.scr source loadaddr fatload mmc 1 loadaddr boot.scr source loadaddr # Resolution Configuration # 'hdmimode' must be one of below to configure display resolution within No luck just boots directly in android
balbes150 Posted May 10, 2020 Author Posted May 10, 2020 11 minutes ago, dante6913 said: No luck just boots directly in android Do you have a UART console ? What media do you use for Armbian ? Try changing the string. fatload mmc 1 loadaddr boot.scr source loadaddr to fatload mmc 1 loadaddr boot.scr autoscr loadaddr and fatload mmc 0 loadaddr boot.scr.aw autoscr loadaddr and fatload mmc 0 loadaddr s905_autoscript autoscr loadaddr I think the launch is possible, but you need to find the right parameters for your conditions.
dante6913 Posted May 10, 2020 Posted May 10, 2020 7 minutes ago, balbes150 said: Do you have a UART console ? What media do you use for Armbian ? Try changing the string. fatload mmc 1 loadaddr boot.scr source loadaddr to fatload mmc 1 loadaddr boot.scr autoscr loadaddr and fatload mmc 0 loadaddr boot.scr.aw autoscr loadaddr and fatload mmc 1 loadaddr s905_autoscript autoscr loadaddr Using a scandisk ultra 32GB HC1 class or scandisk ultra 64 GB XC1 class 10 A1 USB scandisk Ultra 3.0 16GB
dante6913 Posted May 10, 2020 Posted May 10, 2020 1 minute ago, dante6913 said: Using a scandisk ultra 32GB HC1 class or scandisk ultra 64 GB XC1 class 10 A1 USB scandisk Ultra 3.0 16GB I don't have a UART console
balbes150 Posted May 10, 2020 Author Posted May 10, 2020 12 minutes ago, dante6913 said: USB scandisk Ultra 3.0 16GB Does this flash drive have an indicator that blinks when you access it ?
dante6913 Posted May 10, 2020 Posted May 10, 2020 14 minutes ago, balbes150 said: Does this flash drive have an indicator that blinks when you access it ? Yes the blue ligth of the usb drive blinks Tried all conbinations of boot.ini, they all boot directly to android
balbes150 Posted May 10, 2020 Author Posted May 10, 2020 5 minutes ago, dante6913 said: Yes the blue ligth of the usb drive blinks Tried all conbinations of boot.ini, they all boot directly to android Do you edit (boot.ini ) from Android?
dante6913 Posted May 10, 2020 Posted May 10, 2020 1 minute ago, balbes150 said: Do you edit (boot.ini ) from Android? No, from my laptop (ubuntu)
balbes150 Posted May 10, 2020 Author Posted May 10, 2020 3 minutes ago, dante6913 said: No, from my laptop (ubuntu) So you remove the eMMC module, connect it to a PC, and edit it on a PC ?
dante6913 Posted May 10, 2020 Posted May 10, 2020 Just now, balbes150 said: So you remove the eMMC module, connect it to a PC, and edit it on a PC ? Yes, thats what I do
balbes150 Posted May 10, 2020 Author Posted May 10, 2020 Make a backup copy (boot.ini) on your PC, and try removing it from eMMC. If Android starts, it means that it uses other settings to start.
dante6913 Posted May 10, 2020 Posted May 10, 2020 5 minutes ago, balbes150 said: So you remove the eMMC module, connect it to a PC, and edit it on a PC ? Should sd card with armbian whithout emmc aplied with uboot boot?
balbes150 Posted May 10, 2020 Author Posted May 10, 2020 Connect only the eMMC module, you need to check whether it uses the edited one (boot.ini) or uses other data.
dante6913 Posted May 10, 2020 Posted May 10, 2020 1 minute ago, balbes150 said: Connect only the eMMC module, you need to check whether it uses the edited one (boot.ini) or uses other data. eMMc module without sd card and usb card boots So is it using another boot.ini?
nm2042 Posted May 10, 2020 Posted May 10, 2020 I found an issue on with armbian on khadas wim2 when WOL is enabled in u-boot using kbi. When I power off the unit, it actually reboots instead of shutting down. Issue doesn't appear if I disable WOL. image used: Armbian_20.05.2_Arm-64_buster_current_5.7.0-rc1_20200418
dante6913 Posted May 10, 2020 Posted May 10, 2020 Just now, dante6913 said: eMMc module without sd card and usb card boots So is it using another boot.ini? The only thing since the bigining of editing boot,ini, is the HardKernel logo that is messed out
