Single Armbian image for RK + AML + AW (aarch64 ARMv8)
That is, after deleting (boot.ini) from the /boot section of the eMMC module, Android started normally ?
2 minutes ago, dante6913 said:
The only thing since the bigining of editing boot,ini, is the HardKernel logo that is messed out
Not using that file, I deleted and it boots normaly
Try searching for files (boot.ini) on the eMMC module, there may still be a place where they are located
Its copied from some file, because after i deleted it, is allways restored
Run
grep -r "boot.ini" *
Should show the location where it is being restored from
11 minutes ago, balbes150 said:
Run
cp /system/etc/boot.ini.template /internal/boot.ini
gonna make a pause for lunch and edit /system/etc/boot.ini.template
Try using a USB flash drive and these lines in (boot.ini). By the way, after editing (boot.ini) and starting the system , what was changed is saved ?
DROIDC2-UBOOT-CONFIG
usb start
fatload usb 0 1020000 s905_autoscript
autoscr 1020000
usb start
autoscr 1020000
all boot.ini file is restored
all the changes that you make are reset when you power on C2 ?
It Worked, booted at in armbian, but its stucked at
finished daily man-db regeneration
usb start
autoscr 1020000
booted in armbian and stuck at finished daily man-db regeneration
I'm sorry, I didn't understand what it was stuck on. What is displayed on the screen ?
"Finished Daily man-db regeneration"
That is what is displayed on the screen
Managed to ssh and is and configured a new user
reboot and I was able to boot in armbian desktopt.
Is it possible to boot in sd card?
Try
usb start
autoscr 1020000
mmcinfo
fatload mmc 1 1020000 boot.scr
autoscr 1020000
By the way, I dug out my sample Odroid C2 and checked the launch of the latest version of Armbian 20.05.4. Recorded to the Android SD card. Added lines to (boot.ini), wrote Armbian to a USB flash drive, and configured (uEnv.txt). Everything starts normally from USB and you can configure the system without ssh. In the same mode, I checked the launch of Libreelec from USB, everything works. I don't have eMMC for C2, so I can't test working with SD+eMMC.
Try
usb start
autoscr 1020000
mmcinfo
autoscr 1020000
It boots if in the sd card if I have the usb dongle
It must be run from SD without an USB stick.
try
usb start
autoscr 1020000
mmcinfo
fatload mmc 1 1020000 boot-emmc.scr.aw
autoscr 1020000
now whith some scripts i can launch odroid from emmc or armbian from sd or Libreelec from USB
Thanks balbes150 for your patitence and time
By the way, the sound in Armbian not stutter much. I haven't found a way to fix it yet. In LE, this is solved by switching the sound setting to fixed mode and in LE, the sound works cleanly.
On 5/9/2020 at 4:46 AM, balbes150 said:
Contact the hardware manufacturer to develop and source the correct DTB for the mainline kernel with support for all devices for your models.
@balbes150 do you mean this is a hardware isse and it's just a matter of right mapping inside DTB?
Thanks.
This thing is completly killing me. installed LE on the usb stick and tried to boot edited boot.ini to
usb start
autoscr 1020000
but just booted on android
reverted all, tried again to boot to armbian but none of the configurations seem to work, I'm getting mad
What is the contents of the file (boot.ini) on eMMC ? I hope you didn't forget to make the settings in (uEnv.txt) the correct dtb and startup strings are correct ?
To fix the sound on s905 without stuttering, you need to add a parameter to the sound settings file.
 rate 48000
(the fix will be included in the next version of images).
using the first configuration
usb start
autoscr 1020000
made the cooret change uEnv.txt
puted now armbian debian in the usb stick
burned a image of my emmc card to an sd card tried to boot from the usb stick with armbian, with the boot.ini with
usb start
autoscr 1020000
but got the same result, just booted on android
Pay attention to one more nuance - the order of connected USB devices. In this change, the system is searched for on USB 0. If there are other devices, the number may change.
usb start
autoscr 1020000
Did I understand correctly that only the SD card is connected (eMMC is disabled) and the USB flash drive ?
yes you are right, but I'm tring what you said about the usb number because there where a lot of dongles and I have changed the order, so I'm going to try it with the usb armbian pen only
