droid001 Posted November 29, 2019 Posted November 29, 2019 I've got a CuBox i4P with an external SSD connected via eSata and has an external power supply. The 960GB SSD isn't recognised on the system: df -aTh Filesystem Type Size Used Avail Use% Mounted on sysfs sysfs 0 0 0 - /sys proc proc 0 0 0 - /proc udev devtmpfs 869M 0 869M 0% /dev devpts devpts 0 0 0 - /dev/pts tmpfs tmpfs 202M 8.1M 194M 5% /run /dev/mmcblk1p1 ext4 15G 1.2G 14G 8% / securityfs securityfs 0 0 0 - /sys/kernel/security selinuxfs selinuxfs 0 0 0 - /sys/fs/selinux tmpfs tmpfs 1007M 0 1007M 0% /dev/shm tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock tmpfs tmpfs 1007M 0 1007M 0% /sys/fs/cgroup cgroup2 cgroup2 0 0 0 - /sys/fs/cgroup/unified cgroup cgroup 0 0 0 - /sys/fs/cgroup/systemd pstore pstore 0 0 0 - /sys/fs/pstore bpf bpf 0 0 0 - /sys/fs/bpf cgroup cgroup 0 0 0 - /sys/fs/cgroup/pids cgroup cgroup 0 0 0 - /sys/fs/cgroup/perf_event cgroup cgroup 0 0 0 - /sys/fs/cgroup/net_cls,net_prio cgroup cgroup 0 0 0 - /sys/fs/cgroup/cpu,cpuacct cgroup cgroup 0 0 0 - /sys/fs/cgroup/freezer cgroup cgroup 0 0 0 - /sys/fs/cgroup/memory cgroup cgroup 0 0 0 - /sys/fs/cgroup/cpuset cgroup cgroup 0 0 0 - /sys/fs/cgroup/devices cgroup cgroup 0 0 0 - /sys/fs/cgroup/blkio systemd-1 - - - - - /proc/sys/fs/binfmt_misc debugfs debugfs 0 0 0 - /sys/kernel/debug mqueue mqueue 0 0 0 - /dev/mqueue configfs configfs 0 0 0 - /sys/kernel/config tmpfs tmpfs 1007M 12K 1007M 1% /tmp /dev/mmcblk1p1 ext4 15G 1.2G 14G 8% /var/log.hdd /dev/zram0 ext4 49M 12M 34M 26% /var/log tracefs - - - - - /sys/kernel/debug/tracing tmpfs tmpfs 202M 0 202M 0% /run/user/1000 binfmt_misc binfmt_misc 0 0 0 - /proc/sys/fs/binfmt_misc ...and I get the following error in dmesg error: 43.261482] ata1: hard resetting link [ 43.728472] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300) [ 43.728946] ata1.00: supports DRM functions and may not be fully accessible [ 43.729942] ata1.00: Trusted Computing capability qword not valid! [ 43.730657] ata1.00: supports DRM functions and may not be fully accessible [ 43.731534] ata1.00: Trusted Computing capability qword not valid! [ 43.731571] ata1.00: configured for UDMA/133 [ 43.731696] sd 0:0:0:0: [sda] tag#22 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE [ 43.731724] sd 0:0:0:0: [sda] tag#22 Sense Key : Illegal Request [current] [ 43.731754] sd 0:0:0:0: [sda] tag#22 Add. Sense: Unaligned write command [ 43.731781] sd 0:0:0:0: [sda] tag#22 CDB: Read(10) 28 00 6f c8 17 20 00 00 08 00 [ 43.731808] blk_update_request: I/O error, dev sda, sector 1875384096 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0 [ 43.731972] ata1: EH complete [ 74.226892] ata1.00: exception Emask 0x0 SAct 0x80000010 SErr 0x0 action 0x6 frozen [ 74.226918] ata1.00: failed command: READ FPDMA QUEUED [ 74.226956] ata1.00: cmd 60/08:20:80:17:4b/00:00:6f:00:00/40 tag 4 ncq dma 4096 in res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 74.226970] ata1.00: status: { DRDY } [ 74.226991] ata1.00: failed command: READ FPDMA QUEUED [ 74.227025] ata1.00: cmd 60/08:f8:80:17:c8/00:00:6f:00:00/40 tag 31 ncq dma 4096 in res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 74.227037] ata1.00: status: { DRDY } [ 74.227058] ata1: hard resetting link [ 84.261316] ata1: softreset failed (device not ready) [ 84.261336] ata1: hard resetting link [ 84.729328] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300) The SSD mounts with no problem on my Ubuntu laptop. The disk is formatted with GParted to ext4. Futhermore I got the following error when running smartctl: Pending Defects log (GP Log 0x0c) not supported SATA Phy Event Counters (GP Log 0x11) ID Size Value Description 0x0001 4 0 Command failed due to ICRC error 0x000a 4 10 Device-to-host register FISes sent due to a COMRESET smartctl_log
Igor Posted December 26, 2019 Posted December 26, 2019 Finally got time to test. It works just fine: ____ _ _ ____ __ __ ___ _ _ / ___| _| |__ _____ __ (_)___ \ ___\ \/ / / (_) || | | | | | | | '_ \ / _ \ \/ / | | __) / _ \\ / / /| | || |_ | |__| |_| | |_) | (_) > < | |/ __/ __// \ / / | |__ _| \____\__,_|_.__/ \___/_/\_\ |_|_____\___/_/\_\/_/ |_| |_| Welcome to Armbian buster with Linux 5.4.6-imx6 System load: 0.58 0.49 0.22 Up time: 4 min Memory usage: 5 % of 2012MB IP: xxxxxxxxx CPU temp: 51°C Usage of /: 2% of 58G Boot logs: http://ix.io/25y3 Speed test on that sata drive: iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2 random random kB reclen write rewrite read reread read write 102400 4 14105 25617 24673 24661 16592 25200 102400 16 40494 60439 49956 49628 40556 59324 102400 512 96742 100605 64642 64973 63858 100737 102400 1024 114171 115773 85964 96297 95376 114819 102400 16384 166729 166941 132473 131880 129415 161593
