Hi all,
I have a problem with current DEV kernel. On some boards, everything works nicely, and after booting the kernel network is stable,
on some other C2 boards, I get error messages on the eth0 dwmac, and no network:
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.3.15-meson64 (root@skylake) (gcc version 7.4.1 20181213 [linaro-7.4-2019.02 revision 56ec6f6b99cc167ff0c2f8e1a2eed33b1edc85d4] (Linaro GCC 7.4-2019.02)) #5.99 SMP PREEMPT Thu Dec 12 11:12:47 CET 2019
[    0.000000] Machine model: Hardkernel ODROID-C2
[    0.000000] Reserved memory: created CMA memory pool at 0x000000006d800000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] On node 0 totalpages: 518912
[    0.000000]   DMA32 zone: 8128 pages used for memmap
[    0.000000]   DMA32 zone: 0 pages reserved
[    0.000000]   DMA32 zone: 518912 pages, LIFO batch:63
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv0.2 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] percpu: Embedded 22 pages/cpu s51224 r8192 d30696 u90112
[    0.000000] pcpu-alloc: s51224 r8192 d30696 u90112 alloc=22*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] CPU features: detected: ARM erratum 843419
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 510784
[    0.000000] Kernel command line: root=UUID=30fa8d3c-2777-46bb-ac53-01c9512f2f27 rootwait rootfstype=ext4 panic=10 console=ttyAML0,115200 console=tty1 consoleblank=0 coherent_pool=2M loglevel=1 ubootpart=e5be0000-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u usbcore.autosuspend=-1  cgroup_enable=memory swapaccount=1
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 1749708K/2075648K available (11134K kernel code, 746K rwdata, 3388K rodata, 576K init, 399K bss, 63796K reserved, 262144K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[    0.000000]  Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] irq_meson_gpio: 133 to 8 gpio interrupt mux initialized
[    0.000000] random: get_random_bytes called from start_kernel+0x2f4/0x488 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000003] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000238] Console: colour dummy device 80x25
[    0.000246] printk: console [tty1] enabled
[    0.000271] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.000276] pid_max: default: 32768 minimum: 301
[    0.000323] LSM: Security Framework initializing
[    0.000380] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.000393] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.000723] *** VALIDATE proc ***
[    0.000888] *** VALIDATE cgroup1 ***
[    0.000893] *** VALIDATE cgroup2 ***
[    0.024007] ASID allocator initialised with 32768 entries
[    0.032000] rcu: Hierarchical SRCU implementation.
[    0.048018] smp: Bringing up secondary CPUs ...
[    0.080712] Detected VIPT I-cache on CPU1
[    0.080751] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.112719] Detected VIPT I-cache on CPU2
[    0.112739] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.144750] Detected VIPT I-cache on CPU3
[    0.144767] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.144811] smp: Brought up 1 node, 4 CPUs
[    0.144814] SMP: Total of 4 processors activated.
[    0.144817] CPU features: detected: 32-bit EL0 Support
[    0.144820] CPU features: detected: CRC32 instructions
[    0.145083] CPU: All CPU(s) started at EL2
[    0.145095] alternatives: patching kernel code
[    0.145664] devtmpfs: initialized
[    0.149787] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.149801] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.155452] xor: measuring software checksum speed
[    0.192225]    8regs     :  2948.000 MB/sec
[    0.232247]    32regs    :  3624.000 MB/sec
[    0.272272]    arm64_neon:  3173.000 MB/sec
[    0.272275] xor: using function: 32regs (3624.000 MB/sec)
[    0.272284] pinctrl core: initialized pinctrl subsystem
[    0.273197] NET: Registered protocol family 16
[    0.273500] audit: initializing netlink subsys (disabled)
[    0.273574] audit: type=2000 audit(0.272:1): state=initialized audit_enabled=0 res=1
[    0.276950] cpuidle: using governor menu
[    0.277149] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.277887] DMA: preallocated 2048 KiB pool for atomic allocations
[    0.277974] Serial: AMBA PL011 UART driver
[    0.287994] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.288001] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.288004] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.288007] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.289931] cryptd: max_cpu_qlen set to 1000
[    0.360488] raid6: neonx8   gen()  2112 MB/s
[    0.428564] raid6: neonx8   xor()  1962 MB/s
[    0.496609] raid6: neonx4   gen()  1942 MB/s
[    0.564648] raid6: neonx4   xor()  1850 MB/s
[    0.632722] raid6: neonx2   gen()  1498 MB/s
[    0.700757] raid6: neonx2   xor()  1551 MB/s
[    0.768849] raid6: neonx1   gen()   935 MB/s
[    0.836910] raid6: neonx1   xor()  1104 MB/s
[    0.904937] raid6: int64x8  gen()  1259 MB/s
[    0.972974] raid6: int64x8  xor()   961 MB/s
[    1.041059] raid6: int64x4  gen()  1334 MB/s
[    1.109095] raid6: int64x4  xor()   981 MB/s
[    1.177181] raid6: int64x2  gen()   871 MB/s
[    1.245217] raid6: int64x2  xor()   775 MB/s
[    1.313300] raid6: int64x1  gen()   569 MB/s
[    1.381343] raid6: int64x1  xor()   569 MB/s
[    1.381345] raid6: using algorithm neonx8 gen() 2112 MB/s
[    1.381347] raid6: .... xor() 1962 MB/s, rmw enabled
[    1.381349] raid6: using neon recovery algorithm
[    1.382590] SCSI subsystem initialized
[    1.382831] usbcore: registered new interface driver usbfs
[    1.382859] usbcore: registered new interface driver hub
[    1.382919] usbcore: registered new device driver usb
[    1.383203] pps_core: LinuxPPS API ver. 1 registered
[    1.383206] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.383220] PTP clock support registered
[    1.384106] clocksource: Switched to clocksource arch_sys_counter
[    1.384237] VFS: Disk quotas dquot_6.6.0
[    1.384275] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.384324] *** VALIDATE hugetlbfs ***
[    1.388373] thermal_sys: Registered thermal governor 'step_wise'
[    1.388377] thermal_sys: Registered thermal governor 'power_allocator'
[    1.388641] NET: Registered protocol family 2
[    1.388978] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[    1.389003] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    1.389086] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    1.389249] TCP: Hash tables configured (established 16384 bind 16384)
[    1.389338] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    1.389370] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    1.389490] NET: Registered protocol family 1
[    1.389768] RPC: Registered named UNIX socket transport module.
[    1.389770] RPC: Registered udp transport module.
[    1.389772] RPC: Registered tcp transport module.
[    1.389774] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.389896] Trying to unpack rootfs image as initramfs...
[    1.606274] Freeing initrd memory: 6976K
[    1.606857] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    1.607092] kvm [1]: IPA Size Limit: 40bits
[    1.607413] kvm [1]: vgic interrupt IRQ1
[    1.607493] kvm [1]: Hyp mode initialized successfully
[    1.778993] Initialise system trusted keyrings
[    1.779093] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[    1.782785] zbud: loaded
[    1.784394] NFS: Registering the id_resolver key type
[    1.784413] Key type id_resolver registered
[    1.784415] Key type id_legacy registered
[    1.784422] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.784425] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    1.785178] JFS: nTxBlock = 8192, nTxLock = 65536
[    1.789873] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[    1.812515] Key type asymmetric registered
[    1.812521] Asymmetric key parser 'x509' registered
[    1.812581] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    1.812704] io scheduler mq-deadline registered
[    1.812707] io scheduler kyber registered
[    1.812835] io scheduler bfq registered
[    1.813917] GPIO line 501 (usb-hub-reset) hogged as output/high
[    1.824713] soc soc0: Amlogic Meson GXBB (S905) Revision 1f:c (0:1) Detected
[    1.825574] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.826845] c11084c0.serial: ttyAML1 at MMIO 0xc11084c0 (irq = 10, base_baud = 1500000) is a meson_uart
[    1.827188] c81004c0.serial: ttyAML0 at MMIO 0xc81004c0 (irq = 14, base_baud = 1500000) is a meson_uart
[    1.827225] printk: console [ttyAML0] enabled
[    1.829350] brd: module loaded
[    1.832420] loop: module loaded
[    1.833173] libphy: Fixed MDIO Bus: probed
[    1.833564] tun: Universal TUN/TAP device driver, 1.6
[    1.834341] meson8b-dwmac c9410000.ethernet: PTP uses main clock
[    1.834349] meson8b-dwmac c9410000.ethernet: no reset control found
[    1.834687] meson8b-dwmac c9410000.ethernet: User ID: 0x11, Synopsys ID: 0x37
[    1.834693] meson8b-dwmac c9410000.ethernet:         DWMAC1000
[    1.834698] meson8b-dwmac c9410000.ethernet: DMA HW capability register supported
[    1.834701] meson8b-dwmac c9410000.ethernet: RX Checksum Offload Engine supported
[    1.834705] meson8b-dwmac c9410000.ethernet: COE Type 2
[    1.834708] meson8b-dwmac c9410000.ethernet: TX Checksum insertion supported
[    1.834711] meson8b-dwmac c9410000.ethernet: Wake-Up On Lan supported
[    1.834733] meson8b-dwmac c9410000.ethernet: Normal descriptors
[    1.834736] meson8b-dwmac c9410000.ethernet: Ring mode enabled
[    1.834740] meson8b-dwmac c9410000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    1.834835] libphy: stmmac: probed
[    1.886865] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.886870] ehci-platform: EHCI generic platform driver
[    1.886956] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.886973] ohci-platform: OHCI generic platform driver
[    1.887237] usbcore: registered new interface driver usb-storage
[    1.888047] mousedev: PS/2 mouse device common for all mice
[    1.888327] i2c /dev entries driver
[    1.889917] sdhci: Secure Digital Host Controller Interface driver
[    1.889922] sdhci: Copyright(c) Pierre Ossman
[    1.889942] Synopsys Designware Multimedia Card Interface Driver
[    1.890854] meson-gx-mmc d0074000.mmc: allocated mmc-pwrseq
[    1.916719] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.917517] ledtrig-cpu: registered to indicate activity on CPUs
[    1.917782] meson-sm: secure-monitor enabled
[    1.917974] usbcore: registered new interface driver usbhid
[    1.917975] usbhid: USB HID core driver
[    1.918105] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered
[    1.920240] NET: Registered protocol family 10
[    1.920811] Segment Routing with IPv6
[    1.920848] NET: Registered protocol family 17
[    1.920897] Key type dns_resolver registered
[    1.921446] registered taskstats version 1
[    1.921449] Loading compiled-in X.509 certificates
[    1.921520] zswap: loaded using pool lzo/zbud
[    1.922274] Btrfs loaded, crc32c=crc32c-generic
[    1.939460] Key type encrypted registered
[    1.949162] dwc2 c9000000.usb: c9000000.usb supply vusb_d not found, using dummy regulator
[    1.949217] dwc2 c9000000.usb: c9000000.usb supply vusb_a not found, using dummy regulator
[    1.950401] phy phy-c0000000.phy.0: USB ID detect failed!
[    1.950408] phy phy-c0000000.phy.0: phy poweron failed --> -22
[    1.950426] ------------[ cut here ]------------
[    1.950477] WARNING: CPU: 0 PID: 59 at drivers/regulator/core.c:2036 _regulator_put.part.8+0xc0/0xc8
[    1.950479] Modules linked in: realtek
[    1.950489] CPU: 0 PID: 59 Comm: kworker/0:1 Not tainted 5.3.15-meson64 #5.99
[    1.950491] Hardware name: Hardkernel ODROID-C2 (DT)
[    1.950500] Workqueue: events deferred_probe_work_func
[    1.950505] pstate: 60000005 (nZCv daif -PAN -UAO)
[    1.950508] pc : _regulator_put.part.8+0xc0/0xc8
[    1.950512] lr : _regulator_put.part.8+0xc0/0xc8
[    1.950514] sp : ffff000011143b10
[    1.950516] x29: ffff000011143b10 x28: 0000000000000000
[    1.950520] x27: 0000000000000000 x26: ffff000010db0638
[    1.950523] x25: 0000000000000000 x24: 0000000000000009
[    1.950527] x23: ffff000011143bd8 x22: ffff80007f37c810
[    1.950530] x21: ffff000010f59000 x20: ffff80006afa9500
[    1.950534] x19: ffff80006afa9500 x18: ffffffffffffffff
[    1.950538] x17: 0000000059297a1e x16: 000000003bf859fc
[    1.950541] x15: ffff000010f74000 x14: 00000000fffffff0
[    1.950545] x13: ffff000011015952 x12: ffff000010f74000
[    1.950548] x11: 0000000000000000 x10: 0000000000000000
[    1.950552] x9 : 0000000000000001 x8 : 00000000000000cc
[    1.950555] x7 : 0000000000000000 x6 : 0000000005ec36f1
[    1.950559] x5 : 0000000000000000 x4 : 0000000000000000
[    1.950562] x3 : 00000000ffffffff x2 : db06fa2975df1f00
[    1.950565] x1 : 0000000000000000 x0 : 0000000000000024
[    1.950569] Call trace:
[    1.950574]  _regulator_put.part.8+0xc0/0xc8
[    1.950577]  regulator_put+0x34/0x50
[    1.950581]  regulator_bulk_free+0x30/0x50
[    1.950585]  devm_regulator_bulk_release+0x18/0x20
[    1.950589]  release_nodes+0x138/0x228
[    1.950592]  devres_release_all+0x34/0x60
[    1.950596]  really_probe+0x194/0x2c8
[    1.950600]  driver_probe_device+0x58/0x100
[    1.950603]  __device_attach_driver+0x90/0xb0
[    1.950607]  bus_for_each_drv+0x64/0xc8
[    1.950610]  __device_attach+0xd8/0x138
[    1.950614]  device_initial_probe+0x10/0x18
[    1.950617]  bus_probe_device+0x90/0x98
[    1.950621]  deferred_probe_work_func+0x74/0xb0
[    1.950626]  process_one_work+0x1e0/0x338
[    1.950630]  worker_thread+0x240/0x468
[    1.950634]  kthread+0x124/0x128
[    1.950639]  ret_from_fork+0x10/0x18
[    1.950641] ---[ end trace c674df8d9494f10d ]---
[    1.950680] ------------[ cut here ]------------
[    1.950709] WARNING: CPU: 0 PID: 59 at drivers/regulator/core.c:2036 _regulator_put.part.8+0xc0/0xc8
[    1.950711] Modules linked in: realtek
[    1.950716] CPU: 0 PID: 59 Comm: kworker/0:1 Tainted: G        W         5.3.15-meson64 #5.99
[    1.950718] Hardware name: Hardkernel ODROID-C2 (DT)
[    1.950722] Workqueue: events deferred_probe_work_func
[    1.950726] pstate: 60000005 (nZCv daif -PAN -UAO)
[    1.950730] pc : _regulator_put.part.8+0xc0/0xc8
[    1.950733] lr : _regulator_put.part.8+0xc0/0xc8
[    1.950735] sp : ffff000011143b10
[    1.950737] x29: ffff000011143b10 x28: 0000000000000000
[    1.950741] x27: 0000000000000000 x26: ffff000010db0638
[    1.950744] x25: 0000000000000000 x24: 0000000000000009
[    1.950748] x23: ffff000011143bd8 x22: ffff80007f37c810
[    1.950751] x21: ffff000010f59000 x20: ffff80006afa9600
[    1.950755] x19: ffff80006afa9600 x18: 0000000000000016
[    1.950758] x17: 0000000059297a1e x16: 000000003bf859fc
[    1.950762] x15: ffff000010f74000 x14: 00000000fffffff0
[    1.950766] x13: ffff000011015952 x12: ffff000010f74000
[    1.950769] x11: 0000000000000000 x10: 0000000000000000
[    1.950772] x9 : 0000000000000001 x8 : 00000000000000f9
[    1.950776] x7 : 0000000000000000 x6 : 0000000005ec36f1
[    1.950779] x5 : 0000000000000000 x4 : 0000000000000000
[    1.950783] x3 : 00000000ffffffff x2 : db06fa2975df1f00
[    1.950786] x1 : 0000000000000000 x0 : 0000000000000024
[    1.950789] Call trace:
[    1.950793]  _regulator_put.part.8+0xc0/0xc8
[    1.950796]  regulator_put+0x34/0x50
[    1.950799]  regulator_bulk_free+0x30/0x50
[    1.950802]  devm_regulator_bulk_release+0x18/0x20
[    1.950805]  release_nodes+0x138/0x228
[    1.950809]  devres_release_all+0x34/0x60
[    1.950812]  really_probe+0x194/0x2c8
[    1.950816]  driver_probe_device+0x58/0x100
[    1.950819]  __device_attach_driver+0x90/0xb0
[    1.950822]  bus_for_each_drv+0x64/0xc8
[    1.950826]  __device_attach+0xd8/0x138
[    1.950829]  device_initial_probe+0x10/0x18
[    1.950833]  bus_probe_device+0x90/0x98
[    1.950836]  deferred_probe_work_func+0x74/0xb0
[    1.950839]  process_one_work+0x1e0/0x338
[    1.950842]  worker_thread+0x240/0x468
[    1.950846]  kthread+0x124/0x128
[    1.950849]  ret_from_fork+0x10/0x18
[    1.950852] ---[ end trace c674df8d9494f10e ]---
[    1.950899] dwc2: probe of c9000000.usb failed with error -22
[    1.951163] dwc2 c9100000.usb: c9100000.usb supply vusb_d not found, using dummy regulator
[    1.951196] dwc2 c9100000.usb: c9100000.usb supply vusb_a not found, using dummy regulator
[    1.990928] mmc0: new HS200 MMC card at address 0001
[    1.991874] mmcblk0: mmc0:0001 AJNB4R 14.6 GiB
[    1.992588] mmcblk0boot0: mmc0:0001 AJNB4R partition 1 4.00 MiB
[    1.993263] mmcblk0boot1: mmc0:0001 AJNB4R partition 2 4.00 MiB
[    1.993394] mmcblk0rpmb: mmc0:0001 AJNB4R partition 3 4.00 MiB, chardev (245:0)
[    2.002093]  mmcblk0: p1
[    2.016304] dwc2 c9100000.usb: DWC OTG Controller
[    2.016323] dwc2 c9100000.usb: new USB bus registered, assigned bus number 1
[    2.016351] dwc2 c9100000.usb: irq 35, io mem 0xc9100000
[    2.016485] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.03
[    2.016489] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.016494] usb usb1: Product: DWC OTG Controller
[    2.016497] usb usb1: Manufacturer: Linux 5.3.15-meson64 dwc2_hsotg
[    2.016501] usb usb1: SerialNumber: c9100000.usb
[    2.016794] hub 1-0:1.0: USB hub found
[    2.016816] hub 1-0:1.0: 1 port detected
[    2.017647] meson-gx-mmc d0072000.mmc: Got CD GPIO
[    2.045350] scpi_protocol scpi: SCP Protocol legacy pre-1.0 firmware
[    2.048828] hctosys: unable to open rtc device (rtc0)
[    2.048930] of_cfs_init
[    2.049016] of_cfs_init: OK
[    2.051034] Freeing unused kernel memory: 576K
[    2.076745] Run /init as init process
[    2.269662] spidev0@0 enforce active low on chipselect handle
[    2.269688] spidev0@1 enforce active low on chipselect handle
[    2.301074] spidev spi0.0: probing from DT
[    2.301294] spidev spi0.1: probing from DT
[    2.306475] random: fast init done
[    2.416486] usb 1-1: new high-speed USB device number 2 using dwc2
[    2.627160] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=32.98
[    2.627228] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    2.627280] usb 1-1: Product: USB2.0 Hub
[    2.630920] hub 1-1:1.0: USB hub found
[    2.631594] hub 1-1:1.0: 4 ports detected
[    2.807236] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[    3.058942] systemd[1]: System time before build time, advancing clock.
[    3.082394] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    3.082764] systemd[1]: Detected architecture arm64.
[    3.088265] systemd[1]: Set hostname to <odroidc2>.
[    3.089851] systemd[1]: Failed to bump fs.file-max, ignoring: Invalid argument
[    3.363692] random: systemd: uninitialized urandom read (16 bytes read)
[    3.369423] random: systemd: uninitialized urandom read (16 bytes read)
[    3.369857] systemd[1]: Listening on Journal Socket (/dev/log).
[    3.370613] random: systemd: uninitialized urandom read (16 bytes read)
[    3.370799] systemd[1]: Listening on Journal Audit Socket.
[    3.373027] systemd[1]: Listening on Syslog Socket.
[    3.373444] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    3.373778] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    3.375531] systemd[1]: Created slice User and Session Slice.
[    3.458949] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[    3.628356] systemd-journald[1243]: Received request to flush runtime journal from PID 1
[    3.957481] Driver for 1-wire Dallas network protocol.
[    3.992885] debugfs: Directory 'c1105400.audio' with parent 'regmap' already present!
[    4.008325] zram: Added device: zram0
[    4.016474] zram: Added device: zram1
[    4.016840] zram: Added device: zram2
[    4.021849] Registered IR keymap rc-empty
[    4.021958] rc rc0: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0
[    4.022056] input: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0/input0
[    4.026616] random: crng init done
[    4.026625] random: 7 urandom warning(s) missed due to ratelimiting
[    4.029073] meson-ir c8100580.ir: receiver initialized
[    4.047838] zram1: detected capacity change from 0 to 1033936896
[    4.096275] Adding 1009700k swap on /dev/zram1.  Priority:5 extents:1 across:1009700k SSFS
[    4.111309] lima d00c0000.gpu: bus rate = 166666667
[    4.111327] lima d00c0000.gpu: mod rate = 744000000
[    4.115381] lima d00c0000.gpu: gp - mali450 version major 0 minor 0
[    4.115420] lima d00c0000.gpu: pp0 - mali450 version major 0 minor 0
[    4.115463] lima d00c0000.gpu: pp1 - mali450 version major 0 minor 0
[    4.115494] lima d00c0000.gpu: pp2 - mali450 version major 0 minor 0
[    4.115530] lima d00c0000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
[    4.115536] lima d00c0000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
[    4.126836] [drm] Initialized lima 1.0.0 20190217 for d00c0000.gpu on minor 0
[    4.131609] meson-drm d0100000.vpu: Queued 2 outputs on vpu
[    4.173385] ina2xx 0-0046: power monitor ina219 (Rshunt = 100000 uOhm)
[    4.174415] ina2xx 0-0045: power monitor ina219 (Rshunt = 100000 uOhm)
[    4.175485] ina2xx 0-0044: power monitor ina219 (Rshunt = 100000 uOhm)
[    4.179090] ina2xx 0-0043: power monitor ina219 (Rshunt = 100000 uOhm)
[    4.181286] ina2xx 0-0042: power monitor ina219 (Rshunt = 100000 uOhm)
[    4.183479] ina2xx 0-0041: power monitor ina219 (Rshunt = 100000 uOhm)
[    4.190420] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    4.190427] [drm] No driver support for vblank timestamp query.
[    4.192667] meson-drm d0100000.vpu: CVBS Output connector not available
[    4.224226] meson-dw-hdmi c883a000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    4.229713] meson-dw-hdmi c883a000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    4.230079] meson-drm d0100000.vpu: bound c883a000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[    4.230512] [drm] Initialized meson 1.0.0 20161109 for d0100000.vpu on minor 1
[    4.230607] [drm] Cannot find any crtc or sizes
[    4.329506] zram0: detected capacity change from 0 to 52428800
[    4.444296] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
[    4.458663] asoc-simple-card sound: i2s-hifi <-> meson-aiu-i2s.0.auto mapping ok
[    7.388753] meson8b-dwmac c9410000.ethernet eth0: PHY [stmmac-0:00] driver [RTL8211F Gigabit Ethernet]
[    7.400202] meson8b-dwmac c9410000.ethernet eth0: No Safety Features support found
[    7.400218] meson8b-dwmac c9410000.ethernet eth0: PTP not supported by HW
[    7.400226] meson8b-dwmac c9410000.ethernet eth0: configuring for phy/rgmii link mode
[    9.005268] meson8b-dwmac c9410000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[    9.005357] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[    9.026763] meson8b-dwmac c9410000.ethernet eth0: Link is Down
[    9.076402] meson8b-dwmac c9410000.ethernet eth0: PHY [stmmac-0:00] driver [RTL8211F Gigabit Ethernet]
[    9.184144] meson8b-dwmac c9410000.ethernet: Failed to reset the dma
[    9.184158] meson8b-dwmac c9410000.ethernet eth0: stmmac_hw_setup: DMA engine initialization failed
[    9.184164] meson8b-dwmac c9410000.ethernet eth0: stmmac_open: Hw setup failed
[   33.764229] TFLASH_VDD: disabling
[   33.764251] TF_IO: disabling
I tried with the same eMMC card on different boards.
Board who fail with DEV kernel work with NEXT kernel, this one I checked, so I assume we have a problem in DEV kernel with C2 dwmac.
Any ideas?
EDIT: seems only to affect rev0.2_2017114 boards. rev0.2_20160226 seems to work. Can anyone crosscheck this behaviour with a dev/buster image?
So far, Michael
28 minutes ago, martinayotte said:
Michael was asking me in a PM where the MAC address is persisted during "first boot" ...
[mention=4652]TonyMac32[/mention] are you aware of the persisted address file location ?
I'm afraid not. :-/
@mboehmer you say only the later board revision? Very odd.
[edit]
https://wiki.odroid.com/odroid-c2/hardware/hardware
EL-1709	rev0.2 20170830	The schematic is 100% identical to rev0.2 20160226. however, PCB manufacturers are different
and some signal patterns were reinforced and modifed to improve productivity.
EL-1801	rev0.2 20171114	Added a 0Ω between USB Hub IC and load switches.
To disable the USB over-current protection, you need to remove the 0Ω resistor.
I don't know what this would have to do with the eth0 interface.
For the MAC persisting issue, I think he mentioned on all revs, but not sure.
It is very strange. Boards failing with dev kernel work with next kernel. The board rev is the only feature so far which seems to make a difference.
I will return for the time being to NEXT kernel, and add the necessary patches to device tree there.
The MAC issue I think can be solved. Apparently the /usr/bin/armbian/armbian_firstrun takes the (by uBoot correctly set) MAC address and uses nmcli to fix it in software (which seems pretty useless for me, as it is stored in efuse anyhow in each board).
Manually removing the "cloned-mac-address" line in NetworkManager config file (/etc/NetworkManager/system-connections/*) forces the eth0 to use the uBoot provided MAC again.
Edit: I think this line
# varios temporary hardware workarounds
[[ $LINUXFAMILY == meson64 ]] && set_fixed_mac
should be changed accordingly to not tinker with C2 MAC address anymore.
Update: compiled a new image (Armbian_19.11.9_Odroidc2_buster_current_5.4.16), and this one is working again on C2 rev 0.2 201171114 - eth0 is online.
uSD card also seems to work as expected.
