kentaro Posted December 20, 2019 Share Posted December 20, 2019 Hi, because I find in 4r dont see any topic to talk more about change ramdisk as increase or decrease, so I make this cmt, hope somebody help me know + How to resize for ramdisk, and how to using sd card as ramdisk and swap file, so emmc size will be have more space, because I want install kali into + If using bionic desktop, and only install kali tool for pentest, will bionic running ok ? or I must build and install kali as root ? Hope someone can help me know it. Thank you so much Link to comment Share on other sites More sharing options...
Igor Posted December 21, 2019 Share Posted December 21, 2019 11 hours ago, kentaro said: will bionic running ok Much better than Kali since Armbian low level support is unprecedentedly better. Build-in 3rd party wireless drivers (Realtek 881xAU, 8188EUS) provides full hacking possibilities, monitor mode and frame injection while the rest are scripts and apps which you install according to your need. Perhaps you should stick to Debian based Armbian since Kali is derived from Debian. 11 hours ago, kentaro said: how to using sd card as ramdisk and swap file This would be the most stupid thing to do. Just use system as is. A lot of knowledge is behind this default setup. 1 Link to comment Share on other sites More sharing options...
