mbruck Posted May 23, 2016 Posted May 23, 2016 Hi! I have Banana PI and LVDS 5" with touch screen. I installed latest image and folow procedure to enable it: ln -sf /boot/bin/bananapilcd5.bin /boot/script.bin and modify /etc/module to support touch screen, But I find out there is no bananapilcd5.bin in /boot/bin folder. Then I had downloaded banana_pi_5lcd.bin from lemakaer page (https://github.com/LeMaker/fex_configuration/tree/master/bin), and execute above line again (first rename it and put into bin folder). LCD Screen is now working but I have no touch screem Am I missing something ?
zgoda_j Posted July 1, 2016 Posted July 1, 2016 What is required & missing to support this display with vanilla kernel?
Igor Posted July 1, 2016 Posted July 1, 2016 AFAIK init of display is done in U-boot, config example for some other display: CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:18,pclk_khz:33000,le:45,ri:209,up:22,lo:22,hs:1,vs:1,sync:3,vmode:0" CONFIG_VIDEO_LCD_POWER="PH8" CONFIG_VIDEO_LCD_BL_EN="PH7" CONFIG_VIDEO_LCD_BL_PWM="PB2" touch part is here (untested): https://github.com/igorpecovnik/lib/blob/master/patch/kernel/sunxi-next/bananapipro_lemaker_lcd.patch.disabled
