a few months ago I wrote a tutorial to enable the 7" touch display for Banan Pi and Banana Pi Pro.
Unfortunately the files (*.dts e.g. sun7i-a20-bananapro.dts) have changed and I don't know how to integrate the patches in the current armbian version.
Does anybody know how to do it?
Is there already a overlay to enable it?
Thanks.
Steffen
Changes are not ours, but upstream. We are adjusting our patches all the time. (there you could also find some clues)
No, but I have some ideas how to proceed. First find out how references were changed - which is what makes most of the troubles here. Then make use of existing overlays and create one for this display - and search around before since it is possible someone already did it. Or for similar display.
U-boot integration - enable all by default or enable all but stuff in the config ... if things works normally with or without a display.
Hi Igor, hi all,
I invested some time in the problem over the weekend and was able to find a solution.
I also found a workaround for the shutdown/poweroff-issue.
Here is the link to the updated tutorial:
Now it would be nice to have a device tree overlay for this display.
@Igor, can you include the driver for the touchscreen by default (kernel config / not as module)?
Can anybody help to create a overlay?
Steffen
Sure - send a PR to all affected config(s). I assume it does not break anything.
BTW. Great job! I still have your display around. I might test it when possible ;)
