Hi,
yesterday i did as usual an apt-get update/upgrade on my Armbian 19.11.3 (on a good old and always well working Bananapi M1).
After that the desktop starts, but without showing the taskbar anymore. It was some kind of invisible, when i clicked the the upper left corner, the menu drops down. Unfortunately nearly nothing starts by clicking. The preferences are shown without any icons.
Ok, time for a fresh install. I took the latest stable image Armbian Bionic 19.11.6 and put it on a SD card. System starts in console mode, i did all the setup stuff and installed the desktop.
But the fresh installed desktop also started without the taskbar. Same issue as with the predecessor installation.
Here ist the diagnostic information: http://ix.io/27OW
Any hints? I saw, that with the last apt-get update some desktop stuff (armbian-desktop) has been updated. Maybe some bugs there?
Thank you in advance.
Regards, Thorsten
30 minutes ago, dl9sec said:
Let me know if you need furher infos/logs...
It's a kernel bug. Probably you see the same in the logs:
------------[ cut here ]------------
[   64.877064] WARNING: CPU: 0 PID: 410 at include/linux/dma-fence.h:533 drm_sched_main+0x219/0x23c [gpu_sched]
[   64.877067] Modules linked in: fuse input_leds sun4i_gpadc_iio zram snd_soc_simple_card snd_soc_simple_card_utils snd_soc_spdif_tx brcmfmac brcmutil evdev axp20x_usb_power axp20x_battery axp20x_adc lima industrialio gpu_sched sun4i_codec sun4i_ts sun4i_spdif sun4i_gpadc snd_soc_core snd_pcm_dmaengine cfg80211 snd_pcm snd_timer snd soundcore sunxi_cir pwm_sun4i rfkill sun4i_ss uio_pdrv_genirq uio cpufreq_dt sch_fq_codel ip_tables x_tables pinctrl_axp209 pwrseq_simple realtek
[   64.877142] CPU: 0 PID: 410 Comm: pp Tainted: G        W         5.4.11-sunxi #19.11.8.014
[   64.877146] Hardware name: Allwinner sun7i (A20) Family
[   64.877164] [<c010da8d>] (unwind_backtrace) from [<c010a0b1>] (show_stack+0x11/0x14)
[   64.877175] [<c010a0b1>] (show_stack) from [<c09366ef>] (dump_stack+0x6f/0x7c)
[   64.877189] [<c09366ef>] (dump_stack) from [<c011b57b>] (__warn+0xb7/0xb8)
[   64.877201] [<c011b57b>] (__warn) from [<c011b80b>] (warn_slowpath_fmt+0x43/0x74)
[   64.877216] [<c011b80b>] (warn_slowpath_fmt) from [<bf96fcd1>] (drm_sched_main+0x219/0x23c [gpu_sched])
[   64.877233] [<bf96fcd1>] (drm_sched_main [gpu_sched]) from [<c0134035>] (kthread+0x109/0x10c)
[   64.877243] [<c0134035>] (kthread) from [<c01010f9>] (ret_from_fork+0x11/0x38)
[   64.877248] Exception stack(0xed399fb0 to 0xed399ff8)
[   64.877255] 9fa0:                                     00000000 00000000 00000000 00000000
[   64.877264] 9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   64.877271] 9fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[   64.877309] ---[ end trace f26705536fbda605 ]---
[   64.877536] ------------[ cut here ]------------
Try images with legacy 4.19.y kernel.
Edit: I don't have this problem with a self build image which means it will be fixed soon. Desktop is up and running as expected: http://ix.io/27Pd
Hmmm, didn't spot such a warning message neither in dmesg nor in syslog.
Can i simply switch to such a kernel through the "Other" menu in armbian-config? -> Yes, I can :)
Ok, installed the legacy 4.19-84-sunxi kernel and the taskbar reappeared :thumbup:
Nevertheless some things are strange.
When I try to start the "Terminal Emulator" or "Armbian config" from the menu, nothing happens and syslog gave the following messages:
Jan 19 15:39:30 localhost dbus-daemon[1451]: [session uid=1000 pid=1451] Activating via systemd: service name='org.gnome.Terminal' unit='gnome-terminal-server.service' requested by ':1.47' (uid=1000 pid=2102 comm="/usr/bin/gnome-terminal.real ")
Jan 19 15:39:30 localhost systemd[1327]: Starting GNOME Terminal Server...
Jan 19 15:39:30 localhost gnome-terminal-server[2105]: Non UTF-8 locale (ANSI_X3.4-1968) is not supported!
Jan 19 15:39:30 localhost systemd[1327]: gnome-terminal-server.service: Main process exited, code=exited, status=8/n/a
Jan 19 15:39:30 localhost systemd[1327]: gnome-terminal-server.service: Failed with result 'exit-code'.
Jan 19 15:39:30 localhost systemd[1327]: Failed to start GNOME Terminal Server.
Jan 19 15:42:16 localhost dbus-daemon[1451]: [session uid=1000 pid=1451] Activating via systemd: service name='org.gnome.Terminal' unit='gnome-terminal-server.service' requested by ':1.55' (uid=1000 pid=2153 comm="/usr/bin/gnome-terminal.real -- sudo armbian-confi")
Jan 19 15:42:16 localhost systemd[1327]: Starting GNOME Terminal Server...
Jan 19 15:42:16 localhost gnome-terminal-server[2156]: Non UTF-8 locale (ANSI_X3.4-1968) is not supported!
Jan 19 15:42:16 localhost systemd[1327]: gnome-terminal-server.service: Main process exited, code=exited, status=8/n/a
Jan 19 15:42:16 localhost systemd[1327]: gnome-terminal-server.service: Failed with result 'exit-code'.
Jan 19 15:42:16 localhost systemd[1327]: Failed to start GNOME Terminal Server.
It seems something is wrong with the locales. I generated de_DE.UTF-8 in armbian-config, but locale shows all other than de_DE.UTF-8...
Ok, used
sudo locale-gen
sudo update-locale LANG=de_DE.UTF-8
Now everything works fine again.
But it seems, that armbian-config does something wrong with the locales setting.
It shows emty brackets at "Personal -> Locales" although de_DE.UTF-8 is set.
Thank you for the valuable hint with the kernel bug.
Looking forward to the next version (hopefully running) :)
Regards, Thorsten
