MarekBelisko Posted January 20, 2020 Share Posted January 20, 2020 Hi, I'm trying to build debian kernel but using mainline 5.4.12 + patches from patch/kernel/sunxi-current. I took non disabled patches and apply patch -p1 for all of them and it fails at patch 0010-general-h6-add-dma-i2c-ir-spi-uart.patch in first hunk because opp node in dts doesn't exists. It's not in mainline not in patches. I have no idea how this works though. Is this patch then skipped or? Thanks. Marek Link to comment Share on other sites More sharing options...
Igor Posted January 20, 2020 Share Posted January 20, 2020 27 minutes ago, MarekBelisko said: I have no idea how this works though. Is this patch then skipped or? Thanks. Experienced person might need some time to move from this heavily patched mainline kernel + patches to pure mainline + (more) patches which has to be properly sorted and not loose functionality ... Kernel sources must be the same, from this or another procedure, patches cleaned as much as possible and you are done. Link to comment Share on other sites More sharing options...
