haajee Posted February 1, 2020 Posted February 1, 2020 Hello Everyone, Yesterday Domoticz released a new version but requires now GLIBC-2.28. Armbian Bionic has GLIBC-2.27. Users with a Raspberry Pi need to upgrade from Debian Stretch to Buster. But what i know is Armbian for the OrangePi One plus based of Ubuntu 18.04 what is based on Debian Buster. So in my opinion it should be possible to run GLIBC-2.28 instead of GLIBC-2.27. But the question is: how could i fix that?? Thank you for all help!
Werner Posted February 2, 2020 Posted February 2, 2020 Quote released a new version Version of what? Quote But what i know is Armbian for the OrangePi One plus based of Ubuntu 18.04 Armbian exists in two common flavors: Ubuntu 18.04 and Debian Buster Quote what is based on Debian Buster Since Buster was released way AFTER Ubuntu Bionic this makes virtually no sense. When Ubuntu creates a new releases what they basically do is copy Debians Sid or Experimental tree, put some fancy stuff in and call it stable. That's it. Nevertheless this is an issue that is not related to Armbian itself. The only thing that differs Armbian from Buster/Bionic is the kernel to run on varios SBCs like your OPi1+. Therefore ask Ubuntu themselves to bump glibc to 2.28.
haajee Posted February 3, 2020 Author Posted February 3, 2020 The problem is with Domoticz. The developer has made a fault and after that it didn´t work anymore. Off course it´s not a Armbian problem. And i am real angry about the way Domoticz made this crash... See https://www.domoticz.com/forum/viewtopic.php?f=6&t=31157 But the tips are all for Raspbery Pi so that[´s no solution...
Werner Posted February 3, 2020 Posted February 3, 2020 There seems to be a quite simple solution: Quote My advice is not to update to latest Beta when you are on Debian stretch or earlier until issue is fixed. It is generally a good advice to not use any non-stable releases unless you know what you are doing
WoodPaker Posted April 1, 2020 Posted April 1, 2020 I have solved this problem on OPi here https://www.domoticz.com/forum/viewtopic.php?f=6&t=31770&p=240476#p240476
