On 12/25/2019 at 9:48 AM, Igor said:
 I added support and images for model B, but I don't own this hardware ...  https://dl.armbian.com/pineh64-b/
@TonyMac32 You got this board? You have gears and time to make a hires photo?
This is AWESOME. I was using the regular pineh64 images, and most things were working except my NIC kept shutting off about 33-34s after boot every time.
Turns out, if I use the pineh64-b image, my gigabit link stays active and everything seems to be pretty great!
My only issue now is that booting with a USB3 SSD attached directly to the device seems not to work very well. Maybe the SSD is trying to pull too much power at boot? It worked fine when I plugged it in directly after the system was booted from microSD, but cold boots always fail with direct attachment. It's booting 100% reliably for me with my rootfs on SSD if I attach the SSD to a powered USB3 hub, but I'd like it if it didn't need any extra hardware to boot.
Well, I think you probably already figured it out for yourself. ;)
I moved your post and updated the title.
Maybe check the links in my sig if you haven't already.
I would guess it is a power issue. For boards like this I designed myself a 3A power supply HAT that sends power directly to the GPIO. I haven't used it with the H64B however
