Hi all,
Orange Pi One
Armbian_20.02.0-rc1_Orangepione_bionic_current_5.4.14
Enable  w1-gpio
/boot/ambianEnv.txt:
overlays=w1-gpio
param_w1_pin=PD14
param_w1_pin_int_pullup=1
 dmesg | grep -E 'w1|wire'
[    5.271798] Driver for 1-wire Dallas network protocol.
[    5.304021] gpio-110 (onewire@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file
What and where else needs to be done?
Expand
This is only a warning ...
Do you have something like that (change the 28-000003ebdd28 folder according to your device) :
cat /sys/bus/w1/devices/28-000003ebdd28/w1_slave
3b 01 4b 46 7f ff 05 10 54 : crc=54 YES
3b 01 4b 46 7f ff 05 10 54 t=19687
  On 2/5/2020 at 10:47 PM, briks said:
No,
Expand
Check around the "w1" lines in "dmesg", maybe there some hints there.
Also, I'm personally always using external pullups, it is more efficient then internal one.
Here is what I've in "dmesg" :
[    8.566391] Driver for 1-wire Dallas network protocol.
[    8.571927] gpio-111 (onewire@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    8.599634] w1_master_driver w1_bus_master1: Attaching one wire slave 28.000003ebdd28 crc 82
in "dmesg" only two lines, as I wrote before
i use external pullup
param_w1_pin_int_pullup = 1 and param_w1_pin_int_pullup = 0 do not affect the result
device worker, worked with arduino.
It stopped working when I connected to the Orange Pi One.
It turned out not a working connector. The connector is fixed, and it worked.
[    6.301655] Driver for 1-wire Dallas network protocol.
[    6.326682] gpio-20 (onewire@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    6.356384] w1_master_driver w1_bus_master1: Attaching one wire slave 28.0305977931ed crc 40
Thank you all for participating.
  On 2/6/2020 at 12:47 PM, briks said:
used
PA20(pin37), PA10(35). PD14(12). PC4(16), PC7(18). PA21(26)
no result
Expand
Hi briks,
please can you tell me where you got the informations to map the Pxn(n) nunbers to the pysical pins?
Regards
wollik
