abgenis Posted February 14, 2020 Posted February 14, 2020 Dears, We have 4 boards Nanopi Neo2, but when we connect to energy, they don't boot, leds of net port (green and yellow ones) and internal led (red) are on all time. We tried to access via serial port (using an usb-serial adapter), but they not show any boot process. We tried some different boot images on sd card. Nothing works. All four devices are in this situation (and they are new!). There is any thing we can do?
NicoD Posted February 14, 2020 Posted February 14, 2020 How did you burn the image, and on which media. SD-card or eMMC? What image did you use?
abgenis Posted February 14, 2020 Author Posted February 14, 2020 On 2/14/2020 at 8:49 PM, NicoD said: How did you burn the image, and on which media. SD-card or eMMC? What image did you use? Expand We burn official images from site http://wiki.friendlyarm.com/wiki/index.php/NanoPi_NEO2#Get_Started and we tried boot with sd -card. Image: nanopi-neo2_sd_friendlycore-xenial_4.14_arm64
martinayotte Posted February 14, 2020 Posted February 14, 2020 On 2/14/2020 at 8:54 PM, abgenis said: Image: nanopi-neo2_sd_friendlycore-xenial_4.14_arm64 Expand This is not an Armbian image ... Try one of those : https://dl.armbian.com/nanopineo2/ 1
NicoD Posted February 14, 2020 Posted February 14, 2020 On 2/14/2020 at 8:54 PM, abgenis said: We burn official images from site http://wiki.friendlyarm.com/wiki/index.php/NanoPi_NEO2#Get_Started Expand Those are not Armbian images. Try an Armbian image and see what it does.https://www.armbian.com/nanopi-neo-2/
martinayotte Posted February 14, 2020 Posted February 14, 2020 Also, don't mix up between NEO and NEO2, they are not the same processors, the first is a H3 and the second H5, so using the wrong image make them not booting at all ... 1
abgenis Posted February 17, 2020 Author Posted February 17, 2020 Thank you for your responses! I tried too with Armbian_19.11.6_Nanopineo2_buster_current_5.4.7.7z image, but that boards don't boot. I connect a serial/usb card for read boot process, but I don't se anything.
martinayotte Posted February 17, 2020 Posted February 17, 2020 On 2/17/2020 at 12:26 PM, abgenis said: I tried too with Armbian_19.11.6_Nanopineo2_buster_current_5.4.7.7z image, but that boards don't boot. Expand As I said, don't mix NEO and NEO2 images, they don't have the same CPU ! The picture you've provided shows that your board is a NEO not a NEO2, so, use the proper image ...
abgenis Posted February 17, 2020 Author Posted February 17, 2020 On 2/17/2020 at 1:46 PM, martinayotte said: As I said, don't mix NEO and NEO2 images, they don't have the same CPU ! The picture you've provided shows that your board is a NEO not a NEO2, so, use the proper image ... Expand Thank you very much, that was the problem. Using neo image they work correctly.
