i own a Libre Computer Le Potato (AML-S905X-CC) board and i would like to compile my own customized kernel to try patches for bug fixing and experimenting unstable "features", like lima driver.
The problem is that i currently use this board as daily driver and i would like the possibility to have a backup kernel (a stable one) in case something goes wrong.
So the question is: it is possible to have multiple installed kernel and decide which one boot (like GRUB behaviour) using the uboot bootloader?
If it is impossible, i'm sorry for the stupid question. I don't know how exactly the boot sequence works, from a low level point of view.
Thanks a lot for the attention and the dedicated time.
not sure how you'd manage the .debs for it.. but as u-boot... its just pointing to a symlinks to the different active versions.. so you can just modify symlinks
lane@cranbone:/boot$ ls -l
total 37442
-rw-r--r-- 1 root root      166 Feb 19 14:13 armbianEnv.txt
-rw-r--r-- 1 root bin         0 Nov 20  2018 armbianEnv.txt.out
-rw-r--r-- 1 root root     1536 Nov 18  2018 armbian_first_run.txt.template
-rw-r--r-- 1 root root     2970 Nov 18  2018 boot.cmd
-rw-rw-r-- 1 root root     3042 Nov 18  2018 boot.scr
-rw-r--r-- 1 root root   168792 Dec 22 09:31 config-5.4.6-sunxi64
lrwxrwxrwx 1 root root       17 Dec 28 17:27 dtb -> dtb-5.4.6-sunxi64
drwxr-xr-x 2 root root     1024 Dec 28 17:06 dtb-5.3.9-sunxi64
drwxr-xr-x 3 root root     1024 Dec 28 17:06 dtb-5.4.6-sunxi64
lrwxrwxrwx 1 root root       17 Nov 23 19:03 dtb.old -> dtb-5.3.9-sunxi64
lrwxrwxrwx 1 root root       21 Dec 28 17:27 Image -> vmlinuz-5.4.6-sunxi64
-rw-r--r-- 1 root root  9418877 Feb 19 14:00 initrd.img-5.4.6-sunxi64
drwx------ 2 root root    12288 Nov 18  2018 lost+found
-rw-r--r-- 1 root root  3381515 Dec 22 09:31 System.map-5.4.6-sunxi64
lrwxrwxrwx 1 root root       21 Feb 19 14:01 uInitrd -> uInitrd-5.4.6-sunxi64
-rw-r--r-- 1 root root  9418941 Feb 19 14:01 uInitrd-5.4.6-sunxi64
-rwxr-xr-x 1 root root 15685640 Dec 22 09:31 vmlinuz-5.4.6-sunxi64
4 hours ago, UniformBuffer said:
We just pushed a few updates. you may want to download the latest lepotato image we posted today.
lane@lepotato:/sys/class/leds$ lsmod
Module                  Size  Used by
rtl8192cu              77824  0
rtl_usb                20480  1 rtl8192cu
rtl8192c_common        53248  1 rtl8192cu
rtlwifi                90112  3 rtl8192c_common,rtl_usb,rtl8192cu
mac80211              544768  3 rtl_usb,rtl8192cu,rtlwifi
cfg80211              405504  2 rtlwifi,mac80211
libarc4                16384  1 mac80211
rpcsec_gss_krb5        36864  0
fuse                  126976  3
rfkill                 32768  3 cfg80211
cpufreq_powersave      20480  0
cpufreq_conservative    16384  1
zstd                   16384  4
snd_soc_hdmi_codec     16384  1
dw_hdmi_i2s_audio      16384  0
snd_soc_meson_aiu_i2s_fifo    16384  1
snd_soc_meson_aiu_spdif_fifo    16384  0
snd_soc_meson_gx_sound_card    16384  0
snd_soc_meson_aiu_fifo    16384  2 snd_soc_meson_aiu_i2s_fifo,snd_soc_meson_aiu_spdif_fifo
snd_soc_meson_card_utils    16384  3 snd_soc_meson_gx_sound_card
snd_soc_meson_aiu_spdif_encode    16384  0
snd_soc_meson_aiu_i2s_encode    16384  1
meson_vdec             81920  0
snd_soc_core          208896  7 snd_soc_meson_aiu_spdif_encode,snd_soc_hdmi_codec,snd_soc_meson_aiu_i2s_fifo,snd_soc_meson_aiu_fifo,snd_soc_meson_aiu_spdif_fifo,snd_soc_meson_card_utils,snd_soc_meson_aiu_i2s_encode
snd_pcm_dmaengine      16384  1 snd_soc_core
snd_pcm               122880  8 snd_soc_meson_aiu_spdif_encode,snd_soc_hdmi_codec,snd_soc_meson_aiu_i2s_fifo,snd_soc_meson_aiu_fifo,snd_soc_core,snd_soc_meson_aiu_spdif_fifo,snd_soc_meson_aiu_i2s_encode,snd_pcm_dmaengine
meson_dw_hdmi          24576  0
snd_timer              45056  1 snd_pcm
v4l2_mem2mem           32768  1 meson_vdec
meson_drm              57344  2 meson_dw_hdmi
dw_hdmi                45056  2 meson_dw_hdmi,dw_hdmi_i2s_audio
snd                    94208  8 snd_soc_hdmi_codec,snd_timer,snd_soc_core,snd_pcm
videobuf2_dma_contig    24576  1 meson_vdec
lima                   45056  1
drm_kms_helper        200704  6 meson_dw_hdmi,meson_drm,dw_hdmi
videobuf2_v4l2         32768  2 meson_vdec,v4l2_mem2mem
gpu_sched              28672  1 lima
videobuf2_memops       20480  1 videobuf2_dma_contig
soundcore              16384  1 snd
drm                   536576  8 gpu_sched,meson_dw_hdmi,meson_drm,drm_kms_helper,lima,dw_hdmi
ac97_bus               16384  1 snd_soc_core
videobuf2_common       61440  3 meson_vdec,videobuf2_v4l2,v4l2_mem2mem
videodev              258048  4 meson_vdec,videobuf2_v4l2,videobuf2_common,v4l2_mem2mem
drm_panel_orientation_quirks    20480  1 drm
mc                     61440  4 videodev,videobuf2_v4l2,videobuf2_common,v4l2_mem2mem
meson_rng              16384  0
meson_ir               16384  0
rng_core               16384  1 meson_rng
meson_canvas           16384  2 meson_drm,meson_vdec
ao_cec                 20480  0
snd_soc_meson_aiu_bus    16384  0
meson_gxbb_wdt         16384  0
scpi_hwmon             16384  0
zram                   36864  2
ip_tables              32768  0
x_tables               49152  1 ip_tables
meson_gxl              20480  1
dwmac_generic          16384  0
dwmac_meson8b          16384  0
