Igor Posted April 6, 2017 Share Posted April 6, 2017 I guess there is bcmdhd modile in /etc/modules ... and it loads automatically - remove it and reboot if you want to "modprobe bcmdhd op_mode=2" ... It looks that you properly enabled AP mode since you won't get this in first place: nl80211: Could not re-add multicast membership for vendor events: -2 (No such file or directory) Using interface wlan1 with hwaddr 94:a1:a2:ca:17:d8 and ssid "BPi-M2P" wlan1: interface state UNINITIALIZED->ENABLED wlan1: AP-ENABLED According to this log, AP mode is working, while the network part, when removing op_mode=2 from interfaces file, should also be fine. Not two things: this driver is shit and you will get some errors and driver might crash on unloading, so you need to reboot each time you need to load it with different settings. BTW. The kernel is not ours while I assume nothing vital has been changed. Link to comment Share on other sites More sharing options...
dony71 Posted April 6, 2017 Share Posted April 6, 2017 2 minutes ago, Igor said: I guess there is bcmdhd modile in /etc/modules ... and it loads automatically - remove it and reboot if you want to "modprobe bcmdhd op_mode=2" ... It looks that you properly enabled AP mode since you won't get this in first place: nl80211: Could not re-add multicast membership for vendor events: -2 (No such file or directory) Using interface wlan1 with hwaddr 94:a1:a2:ca:17:d8 and ssid "BPi-M2P" wlan1: interface state UNINITIALIZED->ENABLED wlan1: AP-ENABLED According to this log, AP mode is working, while the network part, when removing op_mode=2 from interfaces file, should also be fine. Not two things: this driver is shit and you will get some errors and driver might crash on unloading, so you need to reboot each time you need to load it with different settings. BTW. The kernel is not ours while I assume nothing vital has been changed. yes, this is retrorangpie kernel which based on armbian 5.23 (http://www.retrorangepi.org/) i don't get it what you mean ... so how to fix this since i don't see AP SSID Link to comment Share on other sites More sharing options...
Igor Posted April 6, 2017 Share Posted April 6, 2017 I am running out of ideas. Try changing channel, change SSID ... When you got this at running hostapd: wlan1: AP-ENABLED You should see your AP even your network settings are wrong. Those must be correct only when you are trying to connect. Link to comment Share on other sites More sharing options...
dony71 Posted April 7, 2017 Share Posted April 7, 2017 On 4/6/2017 at 0:39 AM, Igor said: I am running out of ideas. Try changing channel, change SSID ... When you got this at running hostapd: wlan1: AP-ENABLED You should see your AP even your network settings are wrong. Those must be correct only when you are trying to connect. change channel and SSID, but still same problem, SSID is not shown what is this message below referring to?nl80211: Could not re-add multicast membership for vendor events: -2 (No such file or directory) Link to comment Share on other sites More sharing options...
Igor Posted April 7, 2017 Share Posted April 7, 2017 8 minutes ago, dony71 said: nl80211: Could not re-add multicast membership for vendor events: -2 (No such file or directory) Don't know. I know there were some problems with WiFi chips on BPi M2 and they replace this chip. I have no idea if this is related somehow. I'll try to reproduce on my M2+ Link to comment Share on other sites More sharing options...
Igor Posted April 7, 2017 Share Posted April 7, 2017 1 hour ago, Igor said: I'll try to reproduce on my M2+ I did and also did't saw AP. Than I try the same on Friendly ARM M1+ which uses the same wireless chip and it's working. Than I used nanopim1plus.bin on Banana M2+ and it's working there too ... which means stock board configuration is messed up. Link to comment Share on other sites More sharing options...
dony71 Posted April 7, 2017 Share Posted April 7, 2017 2 hours ago, Igor said: I did and also did't saw AP. Than I try the same on Friendly ARM M1+ which uses the same wireless chip and it's working. Than I used nanopim1plus.bin on Banana M2+ and it's working there too ... which means stock board configuration is messed up. Manage to get nanopim2plus fex at https://github.com/igorpecovnik/lib/blob/master/config/fex/nanopim1plus.fex I compare and found differences only in bluetooth gpio pin assignment below It should not affect any function on wifi, but you mentioned using nanopim1plus.bin on bpim2+ then AP shows up? strange ..... [bt_para] bt_used = 1 bt_uart_id = 3 bt_uart_baud = 115200 bt_rst_n = port:PG13<1><default><default><0> bt_wake = port:PA08<1><default><default><0> bt_host_wake = port:PA07<0><default><default><0> bt_host_wake_invert = 0 Link to comment Share on other sites More sharing options...
Igor Posted April 8, 2017 Share Posted April 8, 2017 I just checked again and it's working, also with stock config and connecting to AP. There is a typo / syntax error in one of the guides. This is correct way: echo 'options dhd op_mode=2' >/etc/modprobe.d/ap6212.conf I guess this is the problem ? 1 Link to comment Share on other sites More sharing options...
dony71 Posted April 8, 2017 Share Posted April 8, 2017 5 hours ago, Igor said: I just checked again and it's working, also with stock config and connecting to AP. There is a typo / syntax error in one of the guides. This is correct way: echo 'options dhd op_mode=2' >/etc/modprobe.d/ap6212.conf I guess this is the problem ? This is it !!! Thank you for your support 1 Link to comment Share on other sites More sharing options...
dony71 Posted April 9, 2017 Share Posted April 9, 2017 @Igor /etc/init.d/hostapd systemv script is not working properly. ssid is not showing after reboot, most likely modprobe op_mode=2 is not executed yet before hostapd init.d is being called. i don't know how to fix the script, so i just do restart hostapd in /etc/rc.local Link to comment Share on other sites More sharing options...
Igor Posted April 9, 2017 Share Posted April 9, 2017 4 hours ago, dony71 said: so i just do restart hostapd in /etc/rc.local That's good enough workaround. I guess we need to create a proper systemd compatible startup script. I'll try to implement it to general configuration, now that I know about this problem. Link to comment Share on other sites More sharing options...
