AlexAntao Posted March 14, 2020 Share Posted March 14, 2020 Hi, My ODROID-HC2 has just arrived and I flashed a SDCard with a fresh Armbian Sketcher fot it. Did the initial configuration, with apt-upgrade and then opened Armbian-config and selected to install OpenmediaVault (the only other things installed are SAMBA and Softether). The installation started whiteout any problem, but I got some errors the it tried to install openmediavault extras package. Since all logs were vanished after the install stopped, I cannot post here. But when I try to install again, I get this errors: Quote -2020-03-14 18:41:42-- https://packages.openmediavault.org/public/archive.key Resolvendo packages.openmediavault.org (packages.openmediavault.org)... 178.254.11.33 Conectando-se a packages.openmediavault.org (packages.openmediavault.org)|178.254.11.33|:443... conectado. A requisição HTTP foi enviada, aguardando resposta... 200 OK Tamanho: 3134 (3,1K) [application/pgp-keys] Salvando em: “/etc/apt/trusted.gpg.d/openmediavault-archive-keyring.asc” /etc/apt/trusted.gpg.d/openmediavault 100%[========================================================================>] 3,06K --.-KB/s in 0s 2020-03-14 18:41:43 (17,5 MB/s) - “/etc/apt/trusted.gpg.d/openmediavault-archive-keyring.asc” salvo [3134/3134] OK Executing: /tmp/apt-key-gpghome.8taowPGhes/gpg.1.sh --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys 7AA630A1EDEE7D73 gpg: key 7AA630A1EDEE7D73: "OpenMediaVault Plugin Developers <plugins@omv-extras.org>" not changed gpg: Total number processed: 1 gpg: unchanged: 1 /usr/sbin/softy: linha 627: [: 24222: esperava operador unário Now installing OMV packages. Be patient please (Lendo banco de dados ... 33503 ficheiros e directórios actualmente instalados.) A preparar para desempacotar .../tmp.m8ywFNK0OU/omv_extras.deb ... A descompactar openmediavault-omvextrasorg (4.1.16) sobre (4.1.16) ... /var/lib/dpkg/info/openmediavault-omvextrasorg.postrm: 22: .: Can't open /usr/share/openmediavault/scripts/helper-functions dpkg: aviso: sub-processo antigo script post-removal retornou estado de saída de erro 2 dpkg: em vez disso a tentar script do novo pacote ... /var/lib/dpkg/tmp.ci/postrm: 22: .: Can't open /usr/share/openmediavault/scripts/helper-functions dpkg: erro ao processar o arquivo /tmp/tmp.m8ywFNK0OU/omv_extras.deb (--install): sub-processo novo script post-removal retornou estado de saída de erro 2 /var/lib/dpkg/tmp.ci/postrm: 22: .: Can't open /usr/share/openmediavault/scripts/helper-functions dpkg: erro ao limpar: sub-processo novo script post-removal retornou estado de saída de erro 2 Erros foram encontrados durante o processamento de: /tmp/tmp.m8ywFNK0OU/omv_extras.deb /usr/sbin/softy: linha 653: /usr/share/openmediavault/scripts/helper-functions: Arquivo ou diretório não encontrado /usr/sbin/softy: linha 657: xmlstarlet: comando não encontrado /usr/sbin/softy: linha 658: xmlstarlet: comando não encontrado /usr/sbin/softy: linha 659: xmlstarlet: comando não encontrado /usr/sbin/softy: linha 660: xmlstarlet: comando não encontrado /usr/sbin/softy: linha 661: xmlstarlet: comando não encontrado /usr/sbin/softy: linha 662: xmlstarlet: comando não encontrado /usr/sbin/softy: linha 663: xmlstarlet: comando não encontrado /usr/sbin/softy: linha 664: xmlstarlet: comando não encontrado /usr/sbin/softy: linha 665: /usr/sbin/omv-rpc: Arquivo ou diretório não encontrado /usr/sbin/softy: linha 666: /usr/sbin/omv-rpc: Arquivo ou diretório não encontrado sed: não foi possível ler /etc/init.d/rrdcached: Arquivo ou diretório não encontrado Lendo listas de pacotes... Pronto Construindo árvore de dependências Lendo informação de estado... Pronto E: O pacote openmediavault-omvextrasorg precisa ser reinstalado, mas não foi possível encontrar um arquivo para o mesmo. /usr/sbin/softy: linha 698: /usr/sbin/i2cdetect: Arquivo ou diretório não encontrado --2020-03-14 18:42:23-- https://raw.githubusercontent.com/python/cpython/9cd7e17640a49635d1c1f8c2989578a8fc2c1de6/Lib/weakref.py Resolvendo raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.128.133, 151.101.192.133, 151.101.0.133, ... Conectando-se a raw.githubusercontent.com (raw.githubusercontent.com)|151.101.128.133|:443... conectado. A requisição HTTP foi enviada, aguardando resposta... 200 OK Tamanho: 20466 (20K) [text/plain] Salvando em: “/usr/lib/python3.5/weakref.py” /usr/lib/python3.5/weakref.py 100%[========================================================================>] 19,99K --.-KB/s in 0,03s 2020-03-14 18:42:24 (616 KB/s) - “/usr/lib/python3.5/weakref.py” salvo [20466/20466] /usr/sbin/softy: linha 749: /usr/sbin/omv-initsystem: Arquivo ou diretório não encontrado If I try to do an apt Upgrade I receive the following error: alexantao@NAS:~$ sudo apt upgrade Lendo listas de pacotes... Pronto Construindo árvore de dependências Lendo informação de estado... Pronto E: O pacote openmediavault-omvextrasorg precisa ser reinstalado, mas não foi possível encontrar um arquivo para o mesmo. (package openmediavault-emvextrasorg need to be reinstalled, but it was not possible to find a file for it). As I said, the system is new, did nothing but try to install Openmediavaultvault 4. Thanks.... Link to comment Share on other sites More sharing options...
Igor Posted March 15, 2020 Share Posted March 15, 2020 Installing OMV with armbian-config starting from Armbian from Buster is not supported anymore. https://github.com/armbian/config/issues/76 However OMV on Debian Stretch should work. If not, you better check on OMV forums. They are making changes to the install scripting and packages. Link to comment Share on other sites More sharing options...
AlexAntao Posted March 16, 2020 Author Share Posted March 16, 2020 These errors are from stretch version, downloaded from Armbian. I tried a lot of installation images and NONE worked, using armbian-config. Unfortunately, the Openmediavault Forum is closed. No help for a while. the only image that worked was the one on Openmediavault Download section named OMV_4_Odroid_XU4_HC1_HC2.img.xz . It installs correctly and works, BUT I cannot do any upgrade because it breaks all installation and I have to flash the sdcard again Is there another NAS solution (and more stable) I can try ? Thanks. Link to comment Share on other sites More sharing options...
