Armbianmonitor:
Hi
I want use spi in slave mode, how i can enable slave?
cat /boot/armbianEnv.txt
verbosity=1
console=serial
overlay_prefix=sun50i-h5
overlays=spi-add-cs1 spi-jedec-nor spi-spidev
param_spidev_spi_bus=0
param_spidev_max_freq=100000000
rootdev=UUID=47313251-44b3-4a77-aef5-c53397e3a685
rootfstype=ext4
depends on your solution - but typically for h5, kernel is master on SPI...
https://linux-sunxi.org/SPIdev
You'll probably need to rebuild the kernel to enable, and you'll need to have specifics on the bus from the master.
best of luck, you're likely beyond the redline given current info on how folks can assist.
6 minutes ago, RuslanGennadievich said:
I have NanoPi NEO Core2, this SoC has slave capable?
Unfortunately, although the H5 hardware is capable, Linux kernel driver doesn't support slave mode.
Thanks, i don't knows it.
On first at this topic, sfx2000 say about rebuild kernel...
I readed this link and check my kernel config, so i have this options
CONFIG_SPI_SUN4I=y
CONFIG_SPI_SUN6I=y
CONFIG_SPI=y
CONFIG_SPI_MASTER=y
CONFIG_EXPERIMENTAL=y
CONFIG_SPI_SPIDEV=y
CONFIG_SPI_SLAVE=y
CONFIG_SPI_SLAVE_TIME=m
CONFIG_SPI_SLAVE_SYSTEM_CONTROL=m
it's ok.
But next, i dont't understund...
Yes, i have /dev/spidev1.0 and /sys/class/spi_slave
So, how i can use my /dev/spidev1.0 as slave?
I try change my dts: (convert /boot/sun50i-h5-nanopi-neo-core2.dtb to /boot/sun50i-h5-nanopi-neo-core2.dts, edit, and compile again to dtb)
In dts i added "spi-slave;"
                        spi0 {
                                pins = "PC0", "PC1", "PC2", "PC3";
                                function = "spi0";
                                linux,phandle = <0x21>;
                                phandle = <0x21>;
                                spi-slave;
                        spi1 {
                                pins = "PA15", "PA16", "PA14", "PA13";
                                function = "spi1";
                                linux,phandle = <0x23>;
                                phandle = <0x23>;
                                spi-slave;
But i can't see anything change in my system.
martinayotte, tell me please,  how i can reconfigure or rebuild linux kernel driver to support slave?
As I said, kernel driver for AllWinner SoC doesn't support "slave" mode.
8 minutes ago, RuslanGennadievich said:
My ultimate goal is to test SPI baud rate :)
What do you mean by testing baud rate ?
If you wish to measure/verify the clock, you can take a oscilloscope...
Maybe you know how add slave support to driver?
Yes, on oscilloscope i verify clock line on "slave soc" and see some signal, but in slave mode it's wrong
No, it is too complex task ...
I don't understand what you mean ...
Ok thankyou, and last question
If i have /sys/class/spi_slave on Armbian, does this mean that the kernel has support spi slave?
From my knowledge/understanding, it only mean that kernel has been compiled with CONFIG_SPI_SLAVE enabled, but no hardware is attached to it since neither drivers/spi/spi-sun4i.c and drivers/spi/spi-sun6i.c provide such functionalities.
EDIT: you have probably seen that this /sys/class/spi_slave folder is empty ...
Yes, you are right. My /sys/class/spi_slave folder is empty ...
Okey, thankyou for help!
SPI on most SoC's - it's pretty much what the vendor qualifies - it's when one is in a mixed environment where things get interesting - master determines the rate based on the periphs configured.
There are a lot of things that can be on the SPI bus, so sit back and consider what peripherals are in use on your circuit design.
