q4a Posted March 22, 2020 Posted March 22, 2020 Hi. I installed Armbian_20.02.1_Tinkerboard_bionic_current_5.4.20_desktop on my TinkerBoard (not S) and get weird screen state (white, then growing black circle in the middle). I tried Armbian_20.02.1_Tinkerboard_bionic_legacy_4.4.213_desktop and it works very good, but I still want to test vulkan driver, so I updated only kernel to 4.19 (install linux-image-next-rockchip, linux-header-next-rockchip, linux-dtb-next-rockchip and delete 3 old packages). After reboot I got same screen. Is it known bug? Can it be related, that I'm using HDMI-to-VGA adapter? Can you help me to fix it or get usefull logs?
Myy Posted March 29, 2020 Posted March 29, 2020 Can you take a photo of the issue ? Also, I'd highly recommend to try getting a SSH access on the board and provide some logs (dmesg at least). That said, if you could avoid using the HDMI-to-VGA adapter, or at least try a few minutes with a direct HDMI connection, that could help determine if that's the adapter causing some issues (or the Rockchip driver not able to deal with the adapter configuration). Also, understand that the only Mali Midgard user-space vulkan driver for RK3288 boards, that works on Linux, is tailored towards the fbdev display API, which might require some very specific kernel configurations (or a very old kernel).
q4a Posted April 2, 2020 Author Posted April 2, 2020 So, I downloaded Armbian_20.02.7_Tinkerboard_bionic_current_5.4.28_desktop.7z for clean test and here screens: At start screen almost white. Then black "thing" in the middle grow - screen 1. And then screen become almost black - screen 2 (white spot in center - is flash light). I know - it's wired, but I installed armbian or TinkerOS (Debian based) with 4.4 kernel - all works fine. Android works fine too. I still would like to use lastest kernel and hope to help Panfrost (open source user land mali driver) with testing. How can I get SSH access? Is there any instruction?
Igor Posted April 2, 2020 Posted April 2, 2020 18 minutes ago, q4a said: with 4.4 kernel On 3/22/2020 at 5:03 PM, q4a said: Can it be related, that I'm using HDMI-to-VGA adapter? With this TV you can probably only use Armbian with 4.4. kernel due to HDMI 2 VGA adaptor. Modern kernel is also slightly more power hungry which could make troubles. A device for 1 USD http://amzn.to/2wbNkLp would safe us hundreds. Get one and show boot logs on console.
Myy Posted April 2, 2020 Posted April 2, 2020 Try to get a 4.4 kernel on this board and we'll try to analyze the HDMI (PLL) frequencies used by this kernel, and then see if we can replicate them on modern 5.x kernels. It seems that PLL configuration for HDMI resolutions other than 720p, 1080p, 1440p and 2160p are still not mainlined... However, I don't own any screen that differs from these resolutions, making it really hard to test.
q4a Posted April 3, 2020 Author Posted April 3, 2020 9 hours ago, Myy said: Try to get a 4.4 kernel on this board and we'll try to analyze the HDMI (PLL) frequencies used by this kernel I have working SD card with 4.4 kernel armbian. What should I check? PS I'm using this monitor for main PC with ubuntu eoan amd64 with 5.3.0-40 kernel. Default monitor resolution is 1600x900 60 Hz. And when I 1st time booted in TinkerOS with 4.4 kernel - monitor says that I booted in unsupported resolution like 1920x1080, but still shows desktop and I can change resolution to 1600x900. (Then I swiched to armbian, and I like it) PSS my monitor is Samsung SyncMaster P2050:https://www.samsung.com/ph/support/model/LS20LRZKU/XP/
Myy Posted April 4, 2020 Posted April 4, 2020 Could you do this on the working part : cat /sys/devices/platform/display-subsystem/drm/card0/card0-HDMI-A-1/modes Also, by default, if you can connect the board via Ethernet to a DHCP server and then access tthat DHCP server (if you connect it directly to a box, check the box web UI, it generally has information about connected machines), you might be able to connect the Tinkerboard running a mainline kernel using : ssh root@ip_of_the_tinkerboard The default password is 1234
q4a Posted April 5, 2020 Author Posted April 5, 2020 Here is output from working 4.4 kernel: q@tinkerboard:~$ cat /sys/devices/platform/display-subsystem/drm/card0/card0-HDMI-A-1/modes 1600x900p60 1920x1080p60 1920x1080p60 1280x1024p60 1440x900p60 1280x800p60 1280x720p60 1280x720p60 1024x768p60 800x600p60 800x600p56 q@tinkerboard:~$ I have router with DHCP and I can connect to tinkerboard with 5.5 kernel: root@tinkerboard:~# cat /sys/devices/platform/display-subsystem/drm/card0/card0-HDMI-A-1/modes 1600x900 1920x1080 1920x1080 1280x1024 1280x720 1280x720 1024x768 800x600 800x600 720x480 720x480 720x480
Myy Posted April 5, 2020 Posted April 5, 2020 Hmm, I'll try to extract and test this patch, see if that doesn't generate issues with standard HDMI screens. Then see how to let you test it on your adapter. https://github.com/jernejsk/LibreELEC.tv/blob/updates/projects/Rockchip/patches/linux/default/linux-0006-experimental.patch#L610 I'm surprised by the outstanding amount of HDMI patches that LibreELEC.tv has for Rockchip. This might need an entire directory specific for HDMI patches at this point.
Myy Posted April 7, 2020 Posted April 7, 2020 I extracted the HDMI patch and added it to my repository. Tested it with my screen and it works... However, as I said, I got a very standard screen (1080p) So... now, the whole idea is how to make you test this patch. @TonyMac32 do you have some time this week to prepare a kernel with this patch ?
Myy Posted April 19, 2020 Posted April 19, 2020 Yes, the patch is being tested currently : https://github.com/armbian/build/pull/1887
