PieGuy314 Posted March 27, 2020 Posted March 27, 2020 Hi all, Successfully Installed Armbian_20.02.1_Nanopineo2black_buster_current_5.4.20.img on a NanoPi Neo2 Black using an SD Card. The board is fitted with a 16GB eMMC card via the optional adapter. Ran apt-update && apt-upgrade && armbian-config (“Install” “Install to/update boot loader” -> Install/Update the bootloader on SD/eMMC" - that was the only option available.) Proceeded with 'nand-sata-install' only to be presented with the same 'Install/Update the bootloader on SD/eMMC' and nothing else. Poked about, no mention of the eMMC card during boot (via dmesg) and no '/dev/mmbblk1' - which I thought might be the appropriate device. Checked the eMMC card using a microSD adaptor on another machine - shows up as a device so suspect it's okay for use. Have scanned the forum and found similar instances where eMMC support hasn't been enabled. Patches are available for those systems and look to have been implemented. Was wondering is someone far more knowledgeable than myself could confirm if eMMC support is enabled in the image I installed and if not, outline the steps needed to enable it. Thanks in advance, -- Adrian
Igor Posted March 27, 2020 Posted March 27, 2020 Providing logs with armbianmonitor -u significantly raises chances that issue is getting addressed. It works for me.
PieGuy314 Posted March 27, 2020 Author Posted March 27, 2020 9 minutes ago, Igor said: Providing logs with armbianmonitor -u significantly raises chances that issue is getting addressed. It works for me. Many thanks. Very new here. Will post the output asap.
PieGuy314 Posted March 27, 2020 Author Posted March 27, 2020 30 minutes ago, Igor said: Providing logs with armbianmonitor -u significantly raises chances that issue is getting addressed. It works for me. The output is listed here. This is from 1st boot on a fresh SD card.
Igor Posted March 27, 2020 Posted March 27, 2020 This image: https://dl.armbian.com/nanopineo2black/archive/Armbian_20.02.1_Nanopineo2black_buster_current_5.4.20.7z eMMC is normally recognized. cat /proc/partitions major minor #blocks name 179 0 62367744 mmcblk0 179 1 61739968 mmcblk0p1 179 32 30535680 mmcblk2 179 33 30226224 mmcblk2p1 252 0 51200 zram0 252 1 506600 zram1 Perhaps your eMMC is dead / not compatible? 1
PieGuy314 Posted March 27, 2020 Author Posted March 27, 2020 1 hour ago, Igor said: eMMC is normally recognized. It is when you insert it for the third time and you get a confirmatory click as the connector engages! Things are now looking more promising. mmcblk2 now appears (still unpartitioned so no mmcblk2p1.) Thank you for your help especially being able to demonstrate that the current release does support eMMC. 1
