stroess Posted April 7, 2020 Posted April 7, 2020 Hi. Can someone please kindly shed a light on Armbian / Debian / Sunxi release information that is confusing me: I run Armbian Buster on two Cubietruck systems - one was freshly installed, the other upgraded from a previous installation. Both systems were apt-updated/apt-upgraded most recently with identical /etc/apt/sources.list, and subsequently rebooted. Both systems report identical "uname -a" (=Linux ... 5.4.30-sunxi #20.02.9 SMP) and /etc/debian_version (=10.3) information. The /boot folders have identical zImage resp. uInitrd links pointing to identical targets. Still the /etc/armbian-release resp. /etc/armbian-image-release infos differ: VERSION=20.02.1 vs. VERSION=5.90 resp. VERSION=20.02.0-rc0 vs. VERSION=5.75 Are both systems running the same Armbian as indicated by identical "uname -a" and /etc/debian_version, /boot files, and complete apt-get update/apt-get upgrade .... or are they still running somehow differing OSes as indicated by the different /etc/armbian-release files ? In latter case: what needs to be done to get them identical (aside from cloning the OS installation) if apt-get update/upgrade don't fix these assumed differences. Help kindly appreciated - Thx in advance - Regards - Robert (attached a side-by-side comparision of the all version infos) relinfoFetching info...
Tido Posted April 8, 2020 Posted April 8, 2020 Hi, Just to make sure before trying: -You already read the FAQ on the download page for your device? -You already looked at the Documentation? // sent from mobile phone //
stroess Posted April 8, 2020 Author Posted April 8, 2020 Thx for yr response. Yes, I checked docs and FAQ, and googled - I still do not comprehend why for identical hardware boards the apt-get update/upgrade of an earlier Armbian release for the board leads to a different content of the /etc/armbian-release file, compared to a fresh installation of the Armbian provided for this board (in the above case the 5.90 stamp shown is from 7/2019 according to the Armbian changelog doc, the 20.02.1 from 2/2020). I am aware that an apt-get update/upgrade is a complex operation, but at least in respect to the resulting version identification of Armbian after the update/upgrade it should be unambiguous, compared to a fresh installation of the newest board Armbian image. Also, I do not comprehend why there is a difference between /etc/armbian-release and /etc/armbian-image-release, in the fresh installation case as well as in the update/upgrade case (see previous post). Plz note that both installations are running perfectly, so it is not an urgent problem - just a nagging confusion on my side regarding unique unambiguous version identifications. Regards - Robert
Werner Posted April 8, 2020 Posted April 8, 2020 Armbian changed his release model and versioning not long ago and I guess what you experience are some side effects while upgrading.
Tido Posted April 8, 2020 Posted April 8, 2020 On 4/8/2020 at 5:25 AM, Werner said: his release model and versioning Expand apart from that.. On 4/7/2020 at 11:51 PM, stroess said: one was freshly installed, the other upgraded from a previous installation Expand As OP wrote this. To get Armbian more stable it will not update a stable system kernel wise IIRC. However, IIRC within armbian-config you can change this behavior and Igor will correct me if I was wrong.
