haajee Posted April 16, 2020 Posted April 16, 2020 Hi all, So if a lot of you maybe know is a heatsink and fan a must for the OrangePi 4. With my temporarly installed fan makes a lot of noise i maked yesterday the step to order a Noctua NF-A4x20 5V PWM. The price was arround €17,- not the cheapest but te reviews are amazing. Even on full speed its a lot more silence then the 20x20 mini fan but with a good air flow. But as you could read did i choose for a PWM variant so i could control the rpm´s with a PWM GPIO pin. And amazingly it did work! I have the PWM pin connected to pin 7 of the OrangePi 4. Commands to start pwm for the first time: cd /sys/class/pwm/pwmchip1/ echo 0 > export echo 1000000 > pwmchip1/pwm0/period echo 500000 > pwm0/duty_cycle #and with this step the fan goes on a lower speed echo 1 > pwm0/enable #and back on full speed without PWM echo 0 > pwm0/enable So it´s really nice. And i found a nice script for the Nanopi M4 with also a RK3399 chip from @mar0ni in this topic To make it complete i paste also here the script from @mar0n 1
haajee Posted April 16, 2020 Author Posted April 16, 2020 Just now, haajee said: Hi all, So if a lot of you maybe know is a heatsink and fan a must for the OrangePi 4. With my temporarly installed fan makes a lot of noise i maked yesterday the step to order a Noctua NF-A4x20 5V PWM. The price was arround €17,- not the cheapest but te reviews are amazing. Even on full speed its a lot more silence then the 20x20 mini fan but with a good air flow. But as you could read did i choose for a PWM variant so i could control the rpm´s with a PWM GPIO pin. And amazingly it did work! I have the PWM pin connected to pin 7 of the OrangePi 4. Commands to start pwm for the first time: cd /sys/class/pwm/pwmchip1/ echo 0 > export echo 1000000 > pwmchip1/pwm0/period echo 500000 > pwm0/duty_cycle #and with this step the fan goes on a lower speed echo 1 > pwm0/enable #and back on full speed without PWM echo 0 > pwm0/enable So it´s really nice. And i found a nice script for the Nanopi M4 with also a RK3399 chip from @mar0ni in this topic To make it complete i paste also here the script from @mar0ni #!/bin/bash if [ ! -d /sys/class/pwm/pwmchip1/pwm0 ]; then echo 0 > /sys/class/pwm/pwmchip1/export fi sleep 1 while [ ! -d /sys/class/pwm/pwmchip1/pwm0 ]; do sleep 1 done ISENABLE=`cat /sys/class/pwm/pwmchip1/pwm0/enable` if [ $ISENABLE -eq 1 ]; then echo 0 > /sys/class/pwm/pwmchip1/pwm0/enable fi echo 50000 > /sys/class/pwm/pwmchip1/pwm0/period echo 1 > /sys/class/pwm/pwmchip1/pwm0/enable # max speed run 5s echo 0 > /sys/class/pwm/pwmchip1/pwm0/duty_cycle sleep 5 echo 49994 > /sys/class/pwm/pwmchip1/pwm0/duty_cycle declare -a CpuTemps=(75000 63000 58000 52000 48000 0) declare -a PwmDutyCycles=(25000 37000 48300 49250 49300 49994) while true do temp=$(cat /sys/class/thermal/thermal_zone0/temp) for i in 0 1 2 3 4 5; do if [ $temp -gt ${CpuTemps[$i]} ]; then DUTY=${PwmDutyCycles[$i]} echo $DUTY > "/sys/class/pwm/pwmchip1/pwm0/duty_cycle"; #echo "temp: $temp, target: ${CpuTemps[$i]}, duty: $DUTY" break fi done sleep 2s; done I saved the file in my home dir as pwm-fan.sh and run it as administrator with bash ./pwm-fan.sh And the fan spins up full speed but after that it stops running. Even when the temperature is over the 30 degrees celsius. I have changed 48000 in the above script to 30000. So i think there is also something else to change but i have no idea what. Who could help me? 1
haajee Posted April 16, 2020 Author Posted April 16, 2020 Oh i see now there is a # for the echo temperature. Deleted and worked. #echo "temp: $temp, target: ${CpuTemps[$i]}, duty: $DUTY"
VyacheslavS Posted April 17, 2020 Posted April 17, 2020 This is great! What version of the kernel does this script run on?
VyacheslavS Posted April 19, 2020 Posted April 19, 2020 @haajee, I have for some reason does not work, there is no signal from the 7 pin. Kernel 5.6.3 Buster. What else do I need to do to make it work?
haajee Posted July 8, 2020 Author Posted July 8, 2020 On 4/19/2020 at 6:25 AM, VyacheslavS said: @haajee, I have for some reason does not work, there is no signal from the 7 pin. Kernel 5.6.3 Buster. What else do I need to do to make it work? Oh sorry i didn´t saw your post. My fan script is now: #!/bin/bash if [ ! -d /sys/class/pwm/pwmchip1/pwm0 ]; then echo 0 > /sys/class/pwm/pwmchip1/export fi sleep 1 while [ ! -d /sys/class/pwm/pwmchip1/pwm0 ]; do sleep 1 done ISENABLE=`cat /sys/class/pwm/pwmchip1/pwm0/enable` if [ $ISENABLE -eq 1 ]; then echo 0 > /sys/class/pwm/pwmchip1/pwm0/enable fi echo 50000 > /sys/class/pwm/pwmchip1/pwm0/period echo 1 > /sys/class/pwm/pwmchip1/pwm0/enable # max speed run 60s echo 0 > /sys/class/pwm/pwmchip1/pwm0/duty_cycle sleep 5 echo 50000 > /sys/class/pwm/pwmchip1/pwm0/duty_cycle declare -a CpuTemps=(45000 40000 38000 30000 28000 0) declare -a PwmDutyCycles=(1000 5000 10000 15000 30000) while true do temp=$(cat /sys/class/thermal/thermal_zone0/temp) for i in 0 1 2 3 4 5; do if [ $temp -gt ${CpuTemps[$i]} ]; then DUTY=${PwmDutyCycles[$i]} echo $DUTY > "/sys/class/pwm/pwmchip1/pwm0/duty_cycle"; echo "temp: $temp, target: ${CpuTemps[$i]}, duty: $DUTY" break fi done sleep 1s; done Do you see something if you go to /sys/class/pwm/pwmchip1? And do you have installed wiring orangepi from: https://github.com/orangepi-xunlong/wiringOP ?? what does the command gpio readall shows? 1
VyacheslavS Posted July 10, 2020 Posted July 10, 2020 On 7/9/2020 at 2:45 AM, haajee said: what does the command gpio readall shows? $ gpio readall shows +------+-----+----------+------+---+OrangePi 4+---+---+--+----------+-----+------+ | GPIO | wPi | Name | Mode | V | Physical | V | Mode | Name | wPi | GPIO | +------+-----+----------+------+---+----++----+---+------+----------+-----+------+ | | | 3.3V | | | 1 || 2 | | | 5V | | | | 64 | 0 | I2C2_SDA | IN | 0 | 3 || 4 | | | 5V | | | | 65 | 1 | I2C2_SCL | IN | 0 | 5 || 6 | | | GND | | | | 150 | 2 | PWM1 | ALT2 | 1 | 7 || 8 | 1 | ALT2 | I2C3_SCL | 3 | 145 | | | | GND | | | 9 || 10 | 1 | ALT2 | I2C3_SDA | 4 | 144 | | 33 | 5 | GPIO1_A1 | IN | 0 | 11 || 12 | 1 | IN | GPIO1_C2 | 6 | 50 | | 35 | 7 | GPIO1_A3 | OUT | 1 | 13 || 14 | | | GND | | | | 92 | 8 | GPIO2_D4 | IN | 0 | 15 || 16 | 0 | IN | GPIO1_C6 | 9 | 54 | | | | 3.3V | | | 17 || 18 | 0 | IN | GPIO1_C7 | 10 | 55 | | 40 | 11 | SPI1_TXD | ALT3 | 0 | 19 || 20 | | | GND | | | | 39 | 12 | SPI1_RXD | ALT3 | 1 | 21 || 22 | 0 | IN | GPIO1_D0 | 13 | 56 | | 41 | 14 | SPI1_CLK | ALT3 | 1 | 23 || 24 | 1 | ALT3 | SPI1_CS | 15 | 42 | | | | GND | | | 25 || 26 | 0 | IN | GPIO4_C5 | 16 | 149 | | 64 | 17 | I2C2_SDA | IN | 0 | 27 || 28 | 0 | IN | I2C2_SCL | 18 | 65 | | | | I2S0_RX | | | 29 || 30 | | | GND | | | | | | I2S0_TX | | | 31 || 32 | | | I2S_CLK | | | | | | I2S0_SCK | | | 33 || 34 | | | GND | | | | | | I2S0_SI0 | | | 35 || 36 | | | I2S0_SO0 | | | | | | I2S0_SI1 | | | 37 || 38 | | | I2S0_SI2 | | | | | | GND | | | 39 || 40 | | | I2S0_SI3 | | | +------+-----+----------+------+---+----++----+---+------+----------+-----+------+ | GPIO | wPi | Name | Mode | V | Physical | V | Mode | Name | wPi | GPIO | +------+-----+----------+------+---+OrangePi 4+---+---+--+----------+-----+------+ On 7/9/2020 at 2:45 AM, haajee said: Do you see something if you go to /sys/class/pwm/pwmchip1? $ ls /sys/class/pwm/pwmchip1 device export npwm power subsystem uevent unexport I don't have a pwm0 folder. On 7/9/2020 at 2:45 AM, haajee said: And do you have installed wiring orangepi from: https://github.com/orangepi-xunlong/wiringOP ?? Yes.
VyacheslavS Posted July 11, 2020 Posted July 11, 2020 @haajee , This is a problem with my cooler. It starts rotating with 3.3 V. If the tension is less, then silence. I took voltage measurements from 7 pin. The voltage on this pin is: min=1.0 V, max=2.9 V. Tell me please did you connect Noctua NF-A4x20 5V PWM directly or via MOSFET? In Noctua cooler with 4 pins or 3 pins?
haajee Posted August 1, 2020 Author Posted August 1, 2020 On 7/11/2020 at 2:25 PM, VyacheslavS said: @haajee , This is a problem with my cooler. It starts rotating with 3.3 V. If the tension is less, then silence. I took voltage measurements from 7 pin. The voltage on this pin is: min=1.0 V, max=2.9 V. Tell me please did you connect Noctua NF-A4x20 5V PWM directly or via MOSFET? In Noctua cooler with 4 pins or 3 pins? Very sorry for my always late anwsers. I have my nf-a4x20-5v-pwm directly connected to gnd and 5V pin on the orange pi. The PWM pin do i have connected to pin 7. The RPM pin did i have not connected. I have bought the Noctua in a local internet store for arround €12,- without shipping. The fan is also on full speed so much silent than al the fans i got. I am a really Fanboy now of Noctua I could advice you to buy. more specifications are here https://noctua.at/en/products/fan/nf-a4x20-5v-pwm All what you post is exactly the same what i have... I don´t see a different.
VyacheslavS Posted August 3, 2020 Posted August 3, 2020 On 8/2/2020 at 3:32 AM, haajee said: I have bought the Noctua in a local internet store for arround €12,- without shipping. I also bought the same one, about 15 Euros. I configured the script and now it starts to rotate from +35, the rotation speed is floating. The maximum spin speed starts at +60 . This cooler is really quiet and worth it money. 1
firedgje Posted August 8, 2020 Posted August 8, 2020 Another solution to avoid noise and fan management for orange pi 4 is to use a big heatsink (fanless solution): Orange Pi 4 Heatsink I tried it and it works well. The temperature can rise to 85°C in peak (and 82°C in average) when I tried to stress the cpu with benchmark or with high resolution youtube video, but I never stayed stuck due to a overheat. In normal use, I have more something between 58 to 65 °C. 1
usual user Posted August 9, 2020 Posted August 9, 2020 My device is only equipped with this tiny cooling set: Spoiler Even though all six cores run at 100% load, the fan only runs at full speed for two occasions: Spoiler Frequency scaling and DVFS haven't even begun yet. The kernel is handling the thermal system, no user space involved. Maybe time to collect tmon's log and investigate how the thermal system is performing.
haajee Posted August 9, 2020 Author Posted August 9, 2020 On 8/8/2020 at 11:47 AM, firedgje said: Another solution to avoid noise and fan management for orange pi 4 is to use a big heatsink (fanless solution): Orange Pi 4 Heatsink I tried it and it works well. The temperature can rise to 85°C in peak (and 82°C in average) when I tried to stress the cpu with benchmark or with high resolution youtube video, but I never stayed stuck due to a overheat. In normal use, I have more something between 58 to 65 °C. IMHO is 85 celsius really hot. I don´t also know how a big themalpad could work. Is the heatsink warm when you run? On 8/3/2020 at 2:04 PM, VyacheslavS said: I also bought the same one, about 15 Euros. I configured the script and now it starts to rotate from +35, the rotation speed is floating. The maximum spin speed starts at +60 . This cooler is really quiet and worth it money. Mine have i running really slow and the temperature is arround 32 degrees on normal day with normal load. Full speed about 50 degrees. But i need to say that i have also a heatsink on the CPU from an old Fritzbox router. But even on fullspeed is the fan really quiet and you need to listen very well to here it run. In my opinion is 15 euros a really good deal when i compare with a lot of noisie fans i have. The only problem is that the fan is a little bit bigger than the fan opening of the Geekworm case... So i din´t have the original cover on the case... 1
firedgje Posted August 11, 2020 Posted August 11, 2020 On 8/9/2020 at 10:06 PM, haajee said: IMHO is 85 celsius really hot. I don´t also know how a big themalpad could work. Is the heatsink warm when you run? Yes, the heatsink could be warm. But as I said globally always around 82°C with all cpus at 100%, (and decrease quickly when I stop). I think the processor limit ~85 °C. On 8/9/2020 at 10:06 PM, haajee said: Mine have i running really slow and the temperature is arround 32 degrees on normal day with normal load. Full speed about 50 degrees. But i need to say that i have also a heatsink on the CPU from an old Fritzbox router. But even on fullspeed is the fan really quiet and you need to listen very well to here it run. In my opinion is 15 euros a really good deal when i compare with a lot of noisie fans i have. The only problem is that the fan is a little bit bigger than the fan opening of the Geekworm case... So i din´t have the original cover on the case... I tested previously another solution with a little heatsink and a fan, the temperature was also around 50°C. It is a personal choice to change in order to have no noise, because I use it as pc and as media center.
firedgje Posted August 15, 2020 Posted August 15, 2020 On 8/11/2020 at 9:04 PM, firedgje said: Yes, the heatsink could be warm. But as I said globally always around 82°C with all cpus at 100%, (and decrease quickly when I stop). I think the processor limit ~85 °C. I tested previously another solution with a little heatsink and a fan, the temperature was also around 50°C. It is a personal choice to change in order to have no noise, because I use it as pc and as media center. I did a more complete temperature test with cpu sysbench during a long time: Temperature Test N°: T0°C T1°C 1: 79°C 79°C 2: 82°C 83°C 3: 83°C 83°C 4: 83°C 82°C 5: 83°C 83°C 6: 82°C 82°C 7: 83°C 83°C 8: 83°C 83°C 9: 83°C 83°C 10: 83°C 83°C 11: 83°C 83°C 12: 83°C 83°C 13: 83°C 83°C 14: 82°C 83°C 15: 83°C 83°C 16: 83°C 83°C 17: 83°C 83°C 18: 83°C 83°C 19: 82°C 83°C 20: 83°C 83°C The temperature never exceeds 83°C.
usual user Posted August 15, 2020 Posted August 15, 2020 2 hours ago, firedgje said: I did a more complete temperature test with cpu sysbench Out of curiosity, I'm interested in how your thermal system works during the test. Can you by chance provide a tmon.log? To collect one, start "tmon -dl", perform your thermal stress test and after round about 15 minutes kill the tmon process. Now post the resulting /var/tmp/tmon.log.
firedgje Posted August 16, 2020 Posted August 16, 2020 On 8/15/2020 at 5:57 PM, usual user said: Out of curiosity, I'm interested in how your thermal system works during the test. Can you by chance provide a tmon.log? To collect one, start "tmon -dl", perform your thermal stress test and after round about 15 minutes kill the tmon process. Now post the resulting /var/tmp/tmon.log. Sorry, tmon package seems not to be available.... but I can give you my simple test script: #!/bin/bash clear echo "Temperature Test" echo " " echo "N°: T0°C T1°C" for i in {1..50} do a=$(expr $(cat /sys/devices/virtual/thermal/thermal_zone0/temp) / 1000) b=$(expr $(cat /sys/devices/virtual/thermal/thermal_zone1/temp) / 1000) echo "$i: $a°C $b°C" sysbench cpu --cpu-max-prime=1000000 --threads=$(nproc) run > /dev/null done a=$(expr $(cat /sys/devices/virtual/thermal/thermal_zone0/temp) / 1000) b=$(expr $(cat /sys/devices/virtual/thermal/thermal_zone1/temp) / 1000) echo "$i: $a°C $b°C" exit 0
usual user Posted August 20, 2020 Posted August 20, 2020 On 8/16/2020 at 9:33 PM, firedgje said: but I can give you my simple test script: I've run it three times in a row. This is the visualization of the tmon log, which shows how my thermal system is performing: Spoiler
pepper Posted June 22, 2021 Posted June 22, 2021 (edited) Hi all, This is my upgrade. Mean temperature Epoch PWM FAN regulator for Orange Pi 4/4B for Noctua NF-A4x10 5V PWM, Noctua NF-A4x20 5V PWM. $ sudo systemctl status fanepoch ● fanepoch.service - Mean temperature Epoch PWM FAN regulator Loaded: loaded (/etc/systemd/system/fanepoch.service; enabled; vendor preset: enabled) Active: active (running) since Tue 2021-06-22 21:24:01 CEST; 2min 28s ago Main PID: 13074 (epochpwmfan_op4) Tasks: 2 (limit: 4459) Memory: 516.0K CGroup: /system.slice/fanepoch.service ├─13074 /bin/bash /usr/local/sbin/epochpwmfan_op4 -e 10 └─13374 /usr/bin/sleep 10 čen 22 21:25:11 NAS epochpwmfan_op4[13074]: [0]53333 [1]55000 [2]53333 [3]59444 [4]53333 [5]55000 [6]52777 čen 22 21:25:11 NAS epochpwmfan_op4[13074]: Calculate and create RPM list from DutyCycles array čen 22 21:25:11 NAS epochpwmfan_op4[13074]: RPMLIST[0]: temp 82, duty_cycle 0, rpm 5000 čen 22 21:25:11 NAS epochpwmfan_op4[13074]: RPMLIST[1]: temp 80, duty_cycle 4705, rpm 4415 čen 22 21:25:11 NAS epochpwmfan_op4[13074]: RPMLIST[2]: temp 75, duty_cycle 12549, rpm 3440 čen 22 21:25:11 NAS epochpwmfan_op4[13074]: RPMLIST[3]: temp 65, duty_cycle 20392, rpm 2466 čen 22 21:25:11 NAS epochpwmfan_op4[13074]: RPMLIST[4]: temp 55, duty_cycle 23529, rpm 2062 čen 22 21:25:11 NAS epochpwmfan_op4[13074]: RPMLIST[5]: temp 45, duty_cycle 28235, rpm 1478 čen 22 21:25:11 NAS epochpwmfan_op4[13074]: RPMLIST[6]: temp 0, duty_cycle 32000, rpm 1004 čen 22 21:25:11 NAS epochpwmfan_op4[13074]: temp 51, epoch 54, target 45, duty 28235, rpm 1478 Bash script epochpwmfan_op4 with installation instructions in systemd, but also works via init.d, etc... Spoiler #!/bin/bash if [ $# -eq 0 ]; then cat << EOF Mean temperature Epoch PWM FAN regulator for Orange Pi 4/4B - peepr for Noctua NF-A4x10 5V PWM, Noctua NF-A4x20 5V PWM Syntax: epochpwmfan_op4 <[-c <N sec> : Classic ||-e <N sec> : Epoch]> Info: -e Define interval durations between temperature measuring and update/control PWM in second. One epoch contains 7 intervals. Default interval is 1s. Recommended for control PWM with mean Epochs is 3s(= 3x7=21s) to 10s(= 10x7=70s), etc.. My recommendation is -e 10, ideal for heavy load, at ambient temperature air 21°C the CPU temperature will not exceed 62°C. Examples: epochpwmfan_op4 -e 10 Installation instructions: look in the code EOF exit 0 fi #INSTALLATION INSTRUCTIONS: #sudo cp epochpwmfan_op4 /usr/local/sbin/epochpwmfan_op4 #sudo chmod 755 /usr/local/sbin/epochpwmfan_op4 #sudo geany /etc/systemd/system/fanepoch.service #--- START ---- insert this line (uncomment!) to fanepoch.service (you can change the switches here according to your preferences in ExecStart) #[Unit] #Description=Mean temperature Epoch PWM FAN regulator #After=syslog.target #[Service] #Type=simple #User=root #Restart=on-failure #RestartSec=5s #ExecStart=/usr/local/sbin/epochpwmfan_op4 -e 10 #[Install] #WantedBy=multi-user.target #--- END ----- #sudo chmod 644 /etc/systemd/system/fanepoch.service #sudo systemctl daemon-reload #sudo systemctl enable fanepoch #sudo systemctl start fanepoch #Check status: sudo systemctl status fanepoch if [ "$(id -u)" != "0" ]; then echo "[!] must be root." 1>&2 exit 1 fi declare -i PERIOD=40000 THA=false #no edit SLEEPTIME=1 #default declare -i temp=0 declare -i measuretemp=0 declare -i THAS=6 #temphistory_array_size THERMAL_ZONE0="/sys/class/thermal/thermal_zone0/temp" if [ $# -eq 2 ]; then SLEEPTIME=$2 fi #activation only with switch -e if [ "$1" == "-e" ]; then THA=true declare -a temphistory_array declare -i ACTUAL_EPOCH_MEAN_TEMP=0 echo "Create first Epoch array real temperature - duration $(($SLEEPTIME*(THAS+1))) sec, interval $SLEEPTIME sec" for i in $(eval echo "{0..$THAS}"); do temphistory_array+=($(cat $THERMAL_ZONE0)) echo -n "[$i]${temphistory_array[$i]} " /usr/bin/sleep $SLEEPTIME done echo "" #Calculation of the actual epoch mean ACTUAL_EPOCH_MEAN_TEMP=$(((${temphistory_array[@]/%/+}0)/($THAS+1))) fi #Enable PWM regulation if [ ! -d /sys/class/pwm/pwmchip1/pwm0 ]; then echo 0 > /sys/class/pwm/pwmchip1/export fi ISENABLE=`cat /sys/class/pwm/pwmchip1/pwm0/enable` if [ $ISENABLE -eq 1 ]; then echo 0 > /sys/class/pwm/pwmchip1/pwm0/enable fi # Noctua PWM specification: https://noctua.at/pub/media/wysiwyg/Noctua_PWM_specifications_white_paper.pdf # Range PWM - minimal: 21kHz (47618ns) to maximum: 28kHz (35714ns). RECOMMENDED is 25kHz (40000ns). # Convert kHz to ns: https://www.google.com/search?q=period+to+frequency+calculator echo $PERIOD > /sys/class/pwm/pwmchip1/pwm0/period echo 1 > /sys/class/pwm/pwmchip1/pwm0/enable declare -a CpuTemps=(82000 80000 75000 65000 55000 45000 0) # duty_cycle 40000 = the fan stop. My fan is Noctua NF-A4x10 5V PWM # - GPIO [yellow cable - +5V in pin2 or pin4, black cable - GND in pin6, blue cable - PWM Signal in pin7]. Look here - run "gpio readall" # - My fan spins up from off to 38200ns (~250-300rpm) but that can't realistically be used. declare -a DutyCycles=(0 4705 12549 20392 23529 28235 32000) #!Calculation formula +- only for Noctua NF-A4x10 5V PWM, Noctua NF-A4x20 5V PWM! #! - is only but informational and does not control anything ! echo "Calculate and create RPM list from DutyCycles array" #for speed up script - we avoid infinte counting in a loop :) declare -a RPMLIST for i in $(eval echo "{0..$THAS}"); do if [ ${DutyCycles[$i]} -ne $PERIOD ]; then RPMLIST[$i]=$(echo "scale=2;5000-((23.2/2)*60)*((${DutyCycles[$i]}/10000)/0.5568)" | bc | cut -d . -f1) else RPMLIST[$i]=0 fi echo "RPMLIST[$i]: temp $((${CpuTemps[$i]}/1000)), duty_cycle ${DutyCycles[$i]}, rpm ${RPMLIST[$i]}" done declare -i LOOPID=0 #max. N = THAS, LOOPID controls the array updates of temperature Epochs declare -i PREVDUTY=0 #Previous duty_cycle (for comparsion [show rows 133] - we only write a new value, it speeds up the script) #And we start walking in infinite circles, this part needs to be as fast in running and well thought out as possible :) while true do #Measure real temperature in the thermal_zone0 measuretemp=$(/usr/bin/cat $THERMAL_ZONE0) if $THA; then temp=$ACTUAL_EPOCH_MEAN_TEMP else temp=$measuretemp fi BRK=false for i in {0..6}; do if [ $BRK == false ] && [ $temp -gt ${CpuTemps[$i]} ]; then DUTY=${DutyCycles[$i]} #echo "DUTY_CYCLE=$DUTY, PREVDUTY_CYCLE=$PREVDUTY" #debug info if [ $PREVDUTY -ne $DUTY ]; then echo $DUTY > "/sys/class/pwm/pwmchip1/pwm0/duty_cycle" PREVDUTY=$DUTY #print info only change fan speed (ideal output for syslog) echo "temp $(($measuretemp/1000)), epoch $(($temp/1000)), target $((${CpuTemps[$i]}/1000)), duty $DUTY, rpm ${RPMLIST[$i]}" fi #uncomment and comment [rows 137] for print info every interval #echo "temp $(($measuretemp/1000)), epoch $(($temp/1000)), target $((${CpuTemps[$i]}/1000)), duty $DUTY, rpm ${RPMLIST[$i]}" BRK=true #break fi done if $THA; then #echo "LOOPID=$LOOPID" #debug info #echo "temphistory_array[$LOOPID] ${temphistory_array[$LOOPID]}" #debug info #Update "Epoch" array and actual and previous mean temphistory_array[$LOOPID]=$measuretemp ACTUAL_EPOCH_MEAN_TEMP=$(((${temphistory_array[@]/%/+}0)/($THAS+1))) if [ $LOOPID -lt $THAS ]; then LOOPID+=1 else LOOPID=0 fi fi #loop (measuring) interval: default is 1s [show row 54] /usr/bin/sleep $SLEEPTIME done Edited June 22, 2021 by pepper
