Gossamer Posted April 20, 2020 Posted April 20, 2020 Hi people. My ubuntu machine serves as a samba and openvpn servers. Sometimes it hangs and I'm unable to connect using ssh/openvpn. I've been searching the logs syslog and dmesg, but I'm stil unable to find the cause. Could you point where I should search for the problem? Or help me to troubleshoot and find the problem? Thanks in advance
Gossamer Posted April 20, 2020 Author Posted April 20, 2020 file attached armbianmonitor -u.txtFetching info...
Werner Posted April 20, 2020 Posted April 20, 2020 You should get an up to date kernel/image at first. Yours is quite outdated. IMAGE_TYPE=user-built Therefore unsupported anyway.
Gossamer Posted April 20, 2020 Author Posted April 20, 2020 On 4/20/2020 at 4:26 PM, Werner said: You should get an up to date kernel/image at first. Yours is quite outdated. IMAGE_TYPE=user-built Therefore unsupported anyway. Expand This is the image from the balbes TVBOX Amlogic 905X release. If you could help me troubleshoot the problem your help would be very appreciated.
