Hi, I have a sunvell Qplus TV Box with Allwinner H6
I write the img by  @balbes150 into SD Cards
And I use the dtb by @hexdump
The Qplus Box boot into Armbian but failed connect  to the Ethernet of WIfi (found no device)
So is there anyway to make it fine?
Thanks!
this dtb is very old and will most probably no longer work with the latest images - just try all the h6 dtbs which are part of the images - the qplus is quite a standard box, so it should work with one of them, but on the other side the qplus hardware seems to vary quite a bit so it might also not work at all due to memory initializing problems or something like this
good luck and best wishes - hexdump
  • Werner locked this topic
