0
int.Reaction
change resolution / rotation / boot.cmd?
I've been looking for a way to rotate the display and change the resolution on the Hummingboard running the Debian image
I did this from the FAQ:
screen resolution:
nano /boot/boot.cmd
# example:
# change example from
# disp.screen0_output_mode=1920x1080p60
# to
# disp.screen0_output_mode=1280x720p60
mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr
somewhat blindly and I destroyed the boot.scr, further searching found that /boot/boot.cmd doesn't exist...
I've been messing with xorg with no avail. I think that this is the way to do, through the boot.scr, but there is not any good way to get that running..
The larger question, I guess, is what is the most effective way to rotate the display and change the resolution?
Share this post
Link to post
Share on other sites
For default kernel 3.14.x
https://github.com/igorpecovnik/lib/blob/next/config/boot-cubox.cmd
Others: https://github.com/igorpecovnik/lib/tree/next/config
boot*.cmd
For rotation try this:
Rotation
You can rotate the framebuffer by supplying fbcon=rotate:<n> kernel parameter, where n can be one of the following.
0 - normal orientation (0 degree)
1 - clockwise orientation (90 degrees)
2 - upside down orientation (180 degrees)
3 - counterclockwise orientation (270 degrees)
This is how it's done on Allwinner. I haven't try this with HB but it might work.
Share this post
Link to post
0
