I want to create an image file with yocto. There is no orangepilite in the link "https://github.com/linux-sunxi/meta-sunxi" .  I created an image file for orangepione. kernel did not stand up.
then I downloaded the metalayer in the link https://github.com/abradianu/meta-orangepi/
I made the following changes.
                                                      ../conf/local.conf/
MACHINE ??= "orangepi-lite"
                                                    ../conf/bblayers.conf
  /home/e2das//Desktop/yocto/poky/meta-orangepi \
then I ran the bitbake core-image-base
       ERROR: /home/e2das/Desktop/yocto/poky/meta/recipes-sato/images/core-image-sato.bb: Deprecated variable(s) found: "IMAGE_DEPENDS_sunxi-sdimg". Use do_image_<type>[depends] += "<recipe>:<task>" instead--:--
       ERROR: /home/e2das/Desktop/yocto/poky/meta/recipes-sato/images/core-image-sato-sdk.bb: Deprecated variable(s) found: "IMAGE_DEPENDS_sunxi-sdimg". Use do_image_<type>[depends] += "<recipe>:<task>" instead
        ERROR: /home/e2das/Desktop/yocto/poky/meta/recipes-sato/images/core-image-sato-sdk-ptest.bb: Deprecated variable(s) found: "IMAGE_DEPENDS_sunxi-sdimg". Use do_image_<type>[depends] += "<recipe>:<task>" instead
       ERROR: /home/e2das/Desktop/yocto/poky/meta/recipes-rt/images/core-image-rt.bb: Deprecated variable(s) found: "IMAGE_DEPENDS_sunxi-sdimg". Use do_image_<type>[depends] += "<recipe>:<task>" instead
      ERROR: /home/e2das/Desktop/yocto/poky/meta/recipes-rt/images/core-image-rt-sdk.bb: Deprecated variable(s) found: "IMAGE_DEPENDS_sunxi-sdimg". Use do_image_<type>[depends] += "<recipe>:<task>" instead
      ERROR: /home/e2das/Desktop/yocto/poky/meta/recipes-sato/images/core-image-sato-dev.bb: Deprecated variable(s) found: "IMAGE_DEPENDS_sunxi-sdimg". Use do_image_<type>[depends] += "<recipe>:<task>" instead
      ERROR: Failed to parse recipe: /home/e2das/Desktop/yocto/poky/meta/recipes-sato/images/core-image-sato-sdk.bb
what should I do.
Ask at Yocto's place for help? Not sure how Armbian community can help in this case...
