Hi guys,
maybe you can give an advice. I have setup a NAS with my cubietruck, works like a charm with a single HDD3.5 sata connected.
I have an usb hub for two HDD 3., this one:
https://www.amazon.it/SALCAR-Docking-ottimizzato-compreso-Aluminum/dp/B01LZFH7NO/ref=sr_1_6?__mk_it_IT=%C3%85M%C3%85%C5%BD%C3%95%C3%91&dchild=1&keywords=salcar&qid=1588877559&sr=8-6
it's a 3.0 usb with external power, it works perfectly on my desktop pc: I can see both the disk, but nothing if connected to cubietruck USB port. It is externally powered up.
This is my cubitruk lsusb:
root@cubietruck:~# lsusb
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
And dmesg | grep usb:
root@cubietruck:~# dmesg | grep usb
[    0.000000] Kernel command line: root=UUID=09c47a69-3f67-4fa2-afcf-7c3abb0c17aa rootwait rootfstype=ext4 console=ttyS0,115200 console=tty1 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 consoleblank=0 loglevel=1 ubootpart=e988e4f0-01 ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1
[    1.321384] usbcore: registered new interface driver usbfs
[    1.321436] usbcore: registered new interface driver hub
[    1.321513] usbcore: registered new device driver usb
[    3.711349] usbcore: registered new interface driver usb-storage
[    3.777804] usbcore: registered new interface driver usbhid
[    3.777808] usbhid: USB HID core driver
[    5.031900] axp20x-usb-power-supply axp20x-usb-power-supply: DMA mask not set
[   16.041899] ehci-platform 1c14000.usb: EHCI Host Controller
[   16.041944] ehci-platform 1c14000.usb: new USB bus registered, assigned bus number 1
[   16.048877] ehci-platform 1c14000.usb: irq 33, io mem 0x01c14000
[   16.064658] ehci-platform 1c14000.usb: USB 2.0 started, EHCI 1.00
[   16.065028] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[   16.065040] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   16.065047] usb usb1: Product: EHCI Host Controller
[   16.065054] usb usb1: Manufacturer: Linux 5.4.35-sunxi ehci_hcd
[   16.065060] usb usb1: SerialNumber: 1c14000.usb
[   16.067326] ehci-platform 1c1c000.usb: EHCI Host Controller
[   16.067371] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 2
[   16.067864] ehci-platform 1c1c000.usb: irq 38, io mem 0x01c1c000
[   16.080568] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
[   16.085059] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[   16.085087] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   16.085100] usb usb2: Product: EHCI Host Controller
[   16.085113] usb usb2: Manufacturer: Linux 5.4.35-sunxi ehci_hcd
[   16.085121] usb usb2: SerialNumber: 1c1c000.usb
[   16.087695] ohci-platform 1c14400.usb: Generic Platform OHCI controller
[   16.087742] ohci-platform 1c14400.usb: new USB bus registered, assigned bus number 3
[   16.088243] ohci-platform 1c14400.usb: irq 34, io mem 0x01c14400
[   16.153009] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
[   16.153027] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   16.153035] usb usb3: Product: Generic Platform OHCI controller
[   16.153042] usb usb3: Manufacturer: Linux 5.4.35-sunxi ohci_hcd
[   16.153048] usb usb3: SerialNumber: 1c14400.usb
[   16.155112] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
[   16.155152] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 4
[   16.155575] ohci-platform 1c1c400.usb: irq 39, io mem 0x01c1c400
[   16.216894] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
[   16.216910] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   16.216918] usb usb4: Product: Generic Platform OHCI controller
[   16.216924] usb usb4: Manufacturer: Linux 5.4.35-sunxi ohci_hcd
[   16.216931] usb usb4: SerialNumber: 1c1c400.usb
[   16.219264] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[   16.220098] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[   16.220135] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 5
[   16.222034] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[   16.222051] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   16.222058] usb usb5: Product: MUSB HDRC host driver
[   16.222065] usb usb5: Manufacturer: Linux 5.4.35-sunxi musb-hcd
[   16.222072] usb usb5: SerialNumber: musb-hdrc.1.auto
[   35.963846] usb0-vbus: disabling
Any advice??
Thanks!
Ok I think that just reading first page of Cubietruck armbian image I found the issue. I am powering the board via USB so it seems that host is not powered up! Will try to power supply from jack...
This is the problem which would be clear at once if you told us ;)  Moved to "SD card and PSU issues" subforum.
