donj Posted June 12, 2016 Posted June 12, 2016 I have a cubieboard2 (A20 - sunxi 7i) and i have attached an Foresee EMMC to it and i am able to boot a customised Sunxi-Kernel (3.4.104) from it. I also have an SDCARD with Armbian (Legacy) Jessie which also boots fine. My question is what do i need to do in order to get Armbian (legacy) Jessie to be able to mount the emmc? When i boot up Armbian via the sdcard, i can't see the emmc. Am i doing something wrong, or do i need to make some changes to the .fex file? Should i use the Armbian tool to make changes to the .fex file and roll a new u-boot, if so, can you guide me as to what changes i need to make in order to see both the sdcard and emmc flash devices from Armbian. By the way, I love Armbian (you guys have done a brilliant job), i think it is awesome and i want to use it as my default os on my emmc.
Igor Posted June 13, 2016 Posted June 13, 2016 Usually you need to add support to u-boot. If this is done the same way as on Lime2, than take a look on this patch: https://github.com/igorpecovnik/lib/blob/master/patch/u-boot/u-boot-default/add-emmc-lime2.patch.disabled Thanks
zador.blood.stained Posted June 13, 2016 Posted June 13, 2016 For booting from eMMC u-boot patch is needed, assuming it is connected as MMC2. For mounting eMMC (while booting system from SD) in OS you only need to enable it in .fex/.bin configuration with proper detection flags, after that check your dmesg for any SD/MMC errors if new device node did not appear in /dev
donj Posted June 16, 2016 Author Posted June 16, 2016 Hi Gents, Thanks for your help with this. Your feedback is exactly what i needed. I have 2 questions, because i don't want to mess this up: 1. What is the best way to apply the patch (https://github.com/igorpecovnik/lib/blob/master/patch/u-boot/u-boot-default/add-emmc-lime2.patch.disabled) 2. What changes do i need to make to .fex/.bin configuration and what are the proper detection flags if i did want to mount eMMC while booting system from SD. Thanks in advance.
Igor Posted June 21, 2016 Posted June 21, 2016 Edit your board configuration, located in /boot/bin/cubieboard2.bin You need to convert it from bin to fex (bin2fex cubieboard2.bin cubiboard2.fex), edit, and convert back (fex2bin cubieboard2.fex cubiboard2.bin). I think you need to disable NAND and enable eMMC: [mmc2_para] sdc_used = 1 [nand_para] nand_used = 0 If you want to boot from this eMMC than, you need to patch u-boot, add the same parameters, and hope they work: https://github.com/igorpecovnik/lib/blob/master/patch/u-boot/u-boot-default/add-emmc-lime2.patch.disabled to cubieboard2 config, recompile u-boot, install it and install system on eMMC. In theory you should be able to boot from it.
