nullpointer Posted May 12, 2020 Posted May 12, 2020 (edited) 6.960880] zram1: detected capacity change from 0 to 506638336 [ 7.108492] asoc-simple-card soc:sound: i2s-hifi <-> 1c22800.i2s mapping ok [ 7.821162] random: crng init done [ 7.821171] random: 7 urandom warning(s) missed due to ratelimiting [ 7.897054] Adding 494760k swap on /dev/zram1. Priority:5 extents:1 across:494760k SSFS [ 7.995324] zram0: detected capacity change from 0 to 52428800 [ 8.134498] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard [ 11.299194] dwmac-sun8i 1c30000.ethernet eth0: PHY [0.1:01] driver [Generic PHY] [ 11.299222] dwmac-sun8i 1c30000.ethernet eth0: phy: setting supported 00,00000000,000062cf advertising 00,00000000,000062cf [ 11.300604] dwmac-sun8i 1c30000.ethernet eth0: No Safety Features support found [ 11.300617] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available [ 11.300625] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW [ 11.300635] dwmac-sun8i 1c30000.ethernet eth0: configuring for phy/mii link mode [ 11.300651] dwmac-sun8i 1c30000.ethernet eth0: phylink_mac_config: mode=phy/mii/Unknown/Unknown adv=00,00000000,000062cf pause=10 link=0 an=1 [ 11.302998] dwmac-sun8i 1c30000.ethernet eth0: phy link up mii/100Mbps/Full [ 11.303050] dwmac-sun8i 1c30000.ethernet eth0: phylink_mac_config: mode=phy/mii/100Mbps/Full adv=00,00000000,00000000 pause=0f link=1 an=0 [ 11.303072] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx [ 11.303108] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 15.291957] fuse: init (API version 7.31) [ 33.782064] vcc3v0: disabling [ 33.782075] vcc5v0: disabling [ 33.782079] usb0-vbus: disabling [89489.157381] dwmac-sun8i 1c30000.ethernet eth0: phy link down mii/Unknown/Unknown [89489.157430] dwmac-sun8i 1c30000.ethernet eth0: Link is Down [89494.828035] dwmac-sun8i 1c30000.ethernet eth0: phy link up mii/100Mbps/Full [89494.828082] dwmac-sun8i 1c30000.ethernet eth0: phylink_mac_config: mode=phy/mii/100Mbps/Full adv=00,00000000,00000000 pause=0f link=1 an=0 [89494.828112] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx Ethernet connection disappears after a while, I unplug and plug in the Ethernet cable and the problem is solved. May 11 11:01:06 localhost kernel: [ 11.299194] dwmac-sun8i 1c30000.ethernet eth0: PHY [0.1:01] dri ver [Generic PHY] May 11 11:01:06 localhost kernel: [ 11.299222] dwmac-sun8i 1c30000.ethernet eth0: phy: setting sup ported 00,00000000,000062cf advertising 00,00000000,000062cf May 11 11:01:06 localhost kernel: [ 11.300604] dwmac-sun8i 1c30000.ethernet eth0: No Safety Featur es support found May 11 11:01:06 localhost kernel: [ 11.300617] dwmac-sun8i 1c30000.ethernet eth0: No MAC Managemen t Counters available May 11 11:01:06 localhost kernel: [ 11.300625] dwmac-sun8i 1c30000.ethernet eth0: PTP not supporte d by HW May 11 11:01:06 localhost kernel: [ 11.300635] dwmac-sun8i 1c30000.ethernet eth0: configuring for phy/mii link mode May 11 11:01:06 localhost kernel: [ 11.300651] dwmac-sun8i 1c30000.ethernet eth0: phylink_mac_conf ig: mode=phy/mii/Unknown/Unknown adv=00,00000000,000062cf pause=10 link=0 an=1 May 11 11:01:06 localhost kernel: [ 11.302998] dwmac-sun8i 1c30000.ethernet eth0: phy link up mii/ 100Mbps/Full May 11 11:01:06 localhost kernel: [ 11.303050] dwmac-sun8i 1c30000.ethernet eth0: phylink_mac_conf ig: mode=phy/mii/100Mbps/Full adv=00,00000000,00000000 pause=0f link=1 an=0 May 11 11:01:06 localhost kernel: [ 11.303072] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100 Mbps/Full - flow control rx/tx May 11 11:01:06 localhost kernel: [ 11.303108] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes r eady Jan 4 01:35:02 localhost kernel: [ 15.291957] fuse: init (API version 7.31) May 11 11:01:28 localhost kernel: [ 33.782064] vcc3v0: disabling May 11 11:01:28 localhost kernel: [ 33.782075] vcc5v0: disabling May 11 11:01:28 localhost kernel: [ 33.782079] usb0-vbus: disabling Jan 5 02:35:33 localhost kernel: [89489.157381] dwmac-sun8i 1c30000.ethernet eth0: phy link down mi i/Unknown/Unknown Jan 5 02:35:33 localhost kernel: [89489.157430] dwmac-sun8i 1c30000.ethernet eth0: Link is Down Jan 5 02:35:39 localhost kernel: [89494.828035] dwmac-sun8i 1c30000.ethernet eth0: phy link up mii/ 100Mbps/Full Jan 5 02:35:39 localhost kernel: [89494.828082] dwmac-sun8i 1c30000.ethernet eth0: phylink_mac_conf ig: mode=phy/mii/100Mbps/Full adv=00,00000000,00000000 pause=0f link=1 an=0 Jan 5 02:35:39 localhost kernel: [89494.828112] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100 Mbps/Full - flow control rx/tx Edited May 12, 2020 by nullpointer
