7-Segment LED Display Module (HT16K33)
jps
Is it even possible to run the 7-segment HT16K33 module with Armbian and Orange Pi?
I'm trying with I2C and SMBus2 but can not make it work. I can see the module, but it is imposible to communicate with it:
sudo i2cdetect -y 0
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: 70 -- -- -- -- -- -- --
Any help will be apreciated. Thank you in advance.
Link to comment
Share on other sites
I tried this one based on micropython but when i install trought pip returns many errors:
sudo -H pip3 install adafruit-circuitpython-ht16k33
 error: invalid command 'bdist_wheel'
  Failed building wheel for Adafruit-Blinka
  Running setup.py clean for Adafruit-Blinka
  Running setup.py bdist_wheel for adafruit-circuitpython-busdevice ... error
  Failed building wheel for adafruit-circuitpython-busdevice
And many more. Also it needs busio and board but can't find it. Also i installed adafruit-blinka alone (https://pypi.org/project/Adafruit-Blinka/) what have busio and board drivers, but it doesn't work either. The instalations is success, but after that the code can't find busio or board:
sudo -H pip3 install adafruit-blinka
Requirement already satisfied: adafruit-blinka in /usr/local/lib/python3.6/dist-packages
Requirement already satisfied: Adafruit-PlatformDetect>=2.11.1 in /usr/local/lib/python3.6/dist-packages (from adafruit-blinka)
Requirement already satisfied: Adafruit-PureIO>=1.1.5 in /usr/local/lib/python3.6/dist-packages (from adafruit-blinka)
Requirement already satisfied: pyftdi>=0.40.0 in /usr/local/lib/python3.6/dist-packages (from adafruit-blinka)
Requirement already satisfied: sysv_ipc in /usr/local/lib/python3.6/dist-packages (from adafruit-blinka)
Requirement already satisfied: pyusb>=1.0.0 in /usr/local/lib/python3.6/dist-packages (from pyftdi>=0.40.0->adafruit-blinka)
Requirement already satisfied: pyserial>=3.0 in /usr/local/lib/python3.6/dist-packages (from pyftdi>=0.40.0->adafruit-blinka)
orangepi@orangepiplus2e:~$python3 -m pip install -U --user pip gpiod
Collecting pip
  Downloading https://files.pythonhosted.org/packages/43/84/23ed6a1796480a6f1a2d38f2802901d078266bda38388954d01d3f2e821d/pip-20.1.1-py2.py3-none-any.whl (1.5MB)
    100% |████████████████████████████████| 1.5MB 185kB/s
Collecting gpiod
  Downloading https://files.pythonhosted.org/packages/8e/9c/3818182fa32fd5db2a42be9c340d3d6accf8c256befc741c0a59d61d582c/gpiod-1.2.5.tar.gz
Building wheels for collected packages: gpiod
  Running setup.py bdist_wheel for gpiod ... error
  Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-kdvfombf/gpiod/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/tmpkfkkyv80pip-wheel- --python-tag cp36:
  usage: -c [global_opts] cmd1 [cmd1_opts] [cmd2 [cmd2_opts] ...]
     or: -c --help [cmd1 cmd2 ...]
     or: -c --help-commands
     or: -c cmd --help
  Failed building wheel for gpiod
  Running setup.py clean for gpiod
Failed to build gpiod
Installing collected packages: pip, gpiod
  Running setup.py install for gpiod ... done
Successfully installed gpiod-1.2.5 pip-20.1.1
orangepi@orangepiplus2e:~$ sudo python3 ddd.py
Traceback (most recent call last):
  File "ddd.py", line 9, in <module>
    import board
  File "/home/orangepi/.local/lib/python3.6/site-packages/board.py", line 93, in <module>
    from adafruit_blinka.board.orangepi.orangepipc import *
  File "/home/orangepi/.local/lib/python3.6/site-packages/adafruit_blinka/board/orangepi/orangepipc.py", line 3, in <module>
    from adafruit_blinka.microcontroller.allwinner.h3 import pin
  File "/home/orangepi/.local/lib/python3.6/site-packages/adafruit_blinka/microcontroller/allwinner/h3/pin.py", line 4, in <module>
    PA0 = Pin(0)
  File "/home/orangepi/.local/lib/python3.6/site-packages/adafruit_blinka/microcontroller/generic_linux/libgpiod_pin.py", line 34, in __init__
    self._chip = gpiod.Chip("gpiochip0", gpiod.Chip.OPEN_BY_NAME)
AttributeError: module 'gpiod' has no attribute 'Chip'
I think i tried everithing... I don't know where to go....
Thank you for your response.
Link to comment
Or this one:
https://www.raspberrypi-spy.co.uk/2018/11/raspberry-pi-7-segment-led-display-module-using-python/
orangepi@orangepiplus2e:~/Adafruit_Python_LED_Backpack$ sudo python3 7segment_counter.py
  File "7segment_counter.py", line 32, in <module>
    display.begin()
  File "/home/orangepi/Adafruit_Python_LED_Backpack/Adafruit_LED_Backpack/HT16K33.py", line 53, in begin
    self._device.writeList(HT16K33_SYSTEM_SETUP | HT16K33_OSCILLATOR, [])
  File "/usr/local/lib/python3.6/dist-packages/Adafruit_GPIO-1.0.4-py3.6.egg/Adafruit_GPIO/I2C.py", line 129, in writeList
  File "/home/orangepi/.local/lib/python3.6/site-packages/Adafruit_PureIO/smbus.py", line 364, in write_i2c_block_data
    self._device.write(data)
OSError: [Errno 6] No such device or address
And this one based on SMBus that i installed previously:
https://github.com/emcconville/HT16K33
sudo python3 clo.py
    ! Unable to load SMBus            !
    ! Switching to terminal emulation !
  File "clock.py", line 9, in <module>
    from _HT16K33 import FourDigit
ImportError: cannot import name 'FourDigit'
But does not work either.
Link to comment
