Armbianmonitor:
Hello everyone,
odroid xu4 user here with buster minimal 5.4 from https://dl.armbian.com/odroidxu4/Buster_current_minimal
please have a look at the following output
May 19 12:58:11 localhost kernel: [ 1581.893003] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 100000Hz, actual 100000HZ div = 250)
May 19 12:58:12 localhost kernel: [ 1582.352546] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63)
May 19 12:58:12 localhost kernel: [ 1582.389396] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 300000Hz, actual 297619HZ div = 84)
May 19 12:58:12 localhost kernel: [ 1582.426230] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 200000Hz, actual 200000HZ div = 125)
This messages repeat multiple times every second.
Board is running fine except the messages spamming my log
Kernel 5.x for Odroid XU4 is still considered experimental, not fully supported yet. There will be troubles here, troubles there. In case you worry about, use stock K4.14.y
Hello
Hello! :)
Hi Igor,
thank you for your blazing fast answer!
Unfortunately, I can only post once, every 24 hours?
I downgraded the kernel via
sudo apt-get install armbian-config
result:
Linux odroidxu4 4.14.150-odroidxu4 #2 SMP PREEMPT Mon Oct 28 08:07:45 CET 2019 armv7l GNU/Linux
This seemed to help for like one reboot, the messages are back now.
reinstalled using https://dl.armbian.com/odroidxu4/Buster_legacy
running kernel
Linux odroidxu4 4.14.180-odroidxu4 #16 SMP PREEMPT Wed May 20 19:58:06 CEST 2020 armv7l GNU/Linux
still the same issue.
updated diagnosis
I think it has something to do with the empty emmc slot:
SD Card:
cat /sys/kernel/debug/mmc1/ios
clock:          200000000 Hz
actual clock:   200000000 Hz
vdd:            16 (2.8 ~ 2.9 V)
bus mode:       2 (push-pull)
chip select:    0 (don't care)
power mode:     2 (on)
bus width:      2 (4 bits)
timing spec:    6 (sd uhs SDR104)
signal voltage: 1 (1.80 V)
driver type:    0 (driver type B)
MMC slot:
clock:          0 Hz
vdd:            7 (1.65 - 1.95 V)
power mode:     1 (up)
bus width:      0 (1 bits)
timing spec:    0 (legacy)
but it keeps bouncing between different values:
MMC Slot with a different reading:
clock:          100000 Hz
actual clock:   100000 Hz
power mode:     2 (on)
I tried to swap my 64 gig samsung "pro plus Class 10 U3" card for a more generic Sandisk 64 gig Class 10 UHS 1 card, also no difference..
