Zaxter Posted June 15, 2016 Posted June 15, 2016 (edited) Hi All, I'm using Armbian_5.10_Micro_Debian_jessie_3.4.112 on a custom A20 board with NAND based off the Olimex A20 Micro. I don't see /dev/nand on it. $ zgrep NAND /proc/config.gz CONFIG_SUNXI_NAND_PARTITION=y CONFIG_SUNXI_NAND=y # CONFIG_SUNXI_NAND_COMPAT_DEV is not set # CONFIG_SUNXI_NAND_TEST is not set I even tried to Livesuite an Android NAND image, but it also failed. I'm pasting the logs below. What does it generally mean to have a missing /dev/nand? Thanks. $ sudo ./LiveSuit.shStarting x86-64/LiveSuit.library file path: /home/asrolabe/Downloads/sunxi-livesuite/x86-64/plgvector.dlllibrary file path: /home/asrolabe/Downloads/sunxi-livesuite/x86-64/LangPlg.dllLoadFile 24Open 274: Language file format is UTF-8library file path: /home/asrolabe/Downloads/sunxi-livesuite/x86-64/LiveProc.Plglibrary file path: /home/asrolabe/Downloads/sunxi-livesuite/x86-64/plgvector.dlllibrary file path: /home/asrolabe/Downloads/sunxi-livesuite/x86-64/luaeFex.dllRegister./luaBase.dll l_RegAllFun Sucess!Register./luaeFex.dll l_RegAllFun Sucess!Register./luadec.dll l_RegAllFun Sucess!IMAGEWTYItemTableSize = 1048576Closing image now!Clos image OK!Register./luaBase.dll l_RegAllFun Sucess!Register./luaeFex.dll l_RegAllFun Sucess!Register./luadec.dll l_RegAllFun Sucess!IMAGEWTYItemTableSize = 1048576Closing image now!Clos image OK!Register./luaBase.dll l_RegAllFun Sucess!Register./luaeFex.dll l_RegAllFun Sucess!Register./luadec.dll l_RegAllFun Sucess!IMAGEWTYItemTableSize = 1048576Closing image now!Clos image OK!Dev Plugin The Device Path is: /dev/aw_efex0Register./luaBase.dll l_RegAllFun Sucess!Register./luaeFex.dll l_RegAllFun Sucess!Register./luadec.dll l_RegAllFun Sucess!IMAGEWTYItemTableSize = 1048576Closing image now!Clos image OK!Register./luaBase.dll l_RegAllFun Sucess!Register./luaeFex.dll l_RegAllFun Sucess!Register./luadec.dll l_RegAllFun Sucess!IMAGEWTYItemTableSize = 1048576Closing image now!Clos image OK![Tl_Msg]Init : imgFilePath=/home/asrolabe/Documents/ACD/A20_android_422_TS_USB_UART_I2C_WIFI_LAN_HDMI_LCD_1024x600_release_3.img, imgLen=[0, 532252672], workMode=8IMAGEWTYItemTableSize = 1048576./buffer.cpp, pBuffer = 0x7f2f7020a9e4, nLen = 16380, crc32 = 4120441415[Tl_Msg]Down index[1] start[Tl_Msg]partName=bootloader, pktSubType=BOOTLOADER_FEX00, verifyFile=VBOOTLOADER_FEX0[Tl_Msg]partAddrHigInSec=0x0, partAddrLowInSec=0x8000, partSzHigInSec=0x0, partSzLowInSec=0x8000[Tl_Msg]isEncrypt=false, toVerify=true[Tl_Msg]Down index[1] end[Tl_Msg]Down index[2] start[Tl_Msg]partName=env, pktSubType=ENV_FEX000000000, verifyFile=VENV_FEX00000000[Tl_Msg]partAddrHigInSec=0x0, partAddrLowInSec=0x10000, partSzHigInSec=0x0, partSzLowInSec=0x8000[Tl_Msg]isEncrypt=false, toVerify=true[Tl_Msg]Down index[2] end[Tl_Msg]Down index[3] start[Tl_Msg]partName=boot, pktSubType=BOOT_FEX00000000, verifyFile=VBOOT_FEX0000000[Tl_Msg]partAddrHigInSec=0x0, partAddrLowInSec=0x18000, partSzHigInSec=0x0, partSzLowInSec=0x8000[Tl_Msg]isEncrypt=false, toVerify=true[Tl_Msg]Down index[3] end[Tl_Msg]Down index[4] start[Tl_Msg]partName=system, pktSubType=SYSTEM_FEX000000, verifyFile=VSYSTEM_FEX00000[Tl_Msg]partAddrHigInSec=0x0, partAddrLowInSec=0x20000, partSzHigInSec=0x0, partSzLowInSec=0x100000[Tl_Msg]isEncrypt=false, toVerify=true[Tl_Msg]Down index[4] end[Tl_Msg]Down index[5] start[Tl_Msg]partName=recovery, pktSubType=RECOVERY_FEX0000, verifyFile=VRECOVERY_FEX000[Tl_Msg]partAddrHigInSec=0x0, partAddrLowInSec=0x228000, partSzHigInSec=0x0, partSzLowInSec=0x10000[Tl_Msg]isEncrypt=false, toVerify=true[Tl_Msg]Down index[5] end[Tl_Msg]Down index[6] start[Tl_Msg]partName=UDISK, pktSubType=DISKFS_FEX000000, verifyFile=[Tl_Msg]partAddrHigInSec=0x0, partAddrLowInSec=0x3c0000, partSzHigInSec=0x0, partSzLowInSec=0x0[Tl_Msg]isEncrypt=false, toVerify=false[Tl_Msg]Down index[6] end[Tl_Msg]Down number is 6[Tl_Msg]sec[platform][Tl_Msg]sec[card2_boot_para]0x7f2f7020a9e0, 541, 4, =40x7f2f7020a9e0, 540, 2, =2[Tl_Msg]sec[card_boot][Tl_Msg]sec[target][Tl_Msg]sec[dram_para][Tl_Msg]sec[DllInfo][Tl_Msg]sec[uart_para][Tl_Msg][platform][Tl_Msg]eraseflag = 0x0[Tl_Msg][Tl_Msg][card2_boot_para][Tl_Msg]sdc_clk = port:PC7<3><1>[Tl_Msg]card_line = 0x4[Tl_Msg]sdc_d0 = port:PC8<3><1>[Tl_Msg]card_ctrl = 0x2[Tl_Msg]sdc_cmd = port:PC6<3><1>[Tl_Msg]sdc_d2 = port:PC10<3><1>[Tl_Msg]sdc_d3 = port:PC11<3><1>[Tl_Msg]card_high_speed = 0x1[Tl_Msg]sdc_d1 = port:PC9<3><1>[Tl_Msg][Tl_Msg][card_boot][Tl_Msg]logical_start = 0xa000[Tl_Msg][Tl_Msg][target][Tl_Msg]storage_type = 0xffffffffffffffff[Tl_Msg][Tl_Msg][dram_para][Tl_Msg]dram_baseaddr = 0x40000000[Tl_Msg]dram_chip_density = 0x1000[Tl_Msg]dram_size = 0x400[Tl_Msg]dram_rank_num = 0x1[Tl_Msg]dram_io_width = 0x10[Tl_Msg]dram_tpr0 = 0x42d899b7[Tl_Msg]dram_cas = 0x9[Tl_Msg]dram_odt_en = 0x0[Tl_Msg]dram_tpr1 = 0xa090[Tl_Msg]dram_zq = 0x7f[Tl_Msg]dram_bus_width = 0x20[Tl_Msg]dram_tpr4 = 0x0[Tl_Msg]dram_emr3 = 0x0[Tl_Msg]dram_clk = 0x180[Tl_Msg]dram_emr2 = 0x10[Tl_Msg]dram_emr1 = 0x4[Tl_Msg]dram_tpr5 = 0x0[Tl_Msg]dram_tpr3 = 0x0[Tl_Msg]dram_type = 0x3[Tl_Msg]dram_tpr2 = 0x22a00[Tl_Msg][Tl_Msg][DllInfo][Tl_Msg][Tl_Msg][uart_para][Tl_Msg]uart_debug_rx = port:PB23<2><1><default><default>[Tl_Msg]uart_debug_port = 0x0[Tl_Msg]uart_debug_tx = port:PB22<2><1><default><default>[Tl_Msg][Tl_Msg]Init end[Tl_Msg]fel in: dev[/dev/aw_efex0][Tl_Msg]platform id checked OK[Tl_Msg]To down sys para[Tl_Msg]To down and Run fes1-1[Tl_Msg]To clear fes aide log[Tl_Msg]To down and Run fes1-2[Tl_Msg]To clear fes aide log[Tl_Msg]OK test fel Down and Up in len=8192[Tl_Msg]OK to test dram[Tl_Msg]Update dram size to 1024MBytes[Tl_Msg]nMsgRet=1[Tl_Msg]To down fes2_1[Tl_Msg]To down fes2_2[Tl_Msg]To clear fes aide log[Tl_Msg]not hasRetLog[Tl_Msg]Fel endFel Thread Finished!Dev Plugout The Device Path is: /dev/aw_efex0Dev Plugout The Device Path is: /dev/aw_efex0Dev Plugout The Device Path is: /dev/aw_efex0 Edited June 15, 2016 by Zaxter added spoiler tags / please improve the output / use http://pastebin.com/ please
wildcat_paris Posted June 15, 2016 Posted June 15, 2016 question: does /dev/nand exist on Debian/Armbian? "ls /dev/mmc*" ?
Igor Posted June 15, 2016 Posted June 15, 2016 eMMC and NAND are both supported on kernel 3.4 but you need to have a proper board configuration script.bin (.fex) configuration for your board. On recent boards you can find an eMMC on board storage which acts as a second SD card which naming / location was already pointed out by wildcat.
Zaxter Posted June 15, 2016 Author Posted June 15, 2016 Thanks for your replies @wildcat and @igor. I think my fex config is alright. I use the same fex with another board and the nand device shows up straight away. I also don't get why Livesuite fails to write to the nand. Quick question: Would the nand device (i.e. /dev/nand) show up even if it was never partitioned / pre-written with an Android NAND image? 1
Igor Posted June 15, 2016 Posted June 15, 2016 Thanks for your replies @wildcat and @igor. I think my fex config is alright. I use the same fex with another board and the nand device shows up straight away. I also don't get why Livesuite fails to write to the nand. Quick question: Would the nand device (i.e. /dev/nand) show up even if it was never partitioned / pre-written with an Android NAND image? If Livesuite can't access NAND can also indicate hardware problem. Yes, it must be detected even if not partitioned, but of course not with fdisk, parted or similar. You can see it under /proc/nand
Zaxter Posted June 15, 2016 Author Posted June 15, 2016 There's no /proc/nand either. I have tried a lot of different images here and I have the same problem. I'll check to see if there's something wrong on the hardware side. Thank you again for your help @igor. 1
