xwalter Posted June 15, 2016 Posted June 15, 2016 Hello guys ! 1) New SD card 16 Gb 2) Install on it armbian 5_14 desktop 3) Install apache 2 reboot ---> OK 4) install mysql server and client reboot ---> OK 5) install php5 reboot ---> OK 6) install phpmyadmin reboot ---> OK 7) install java8 reboot ---> OK 8) install netbeans 8.1 + plugins reboot ---> OK 9) install other programs and services reboot ---> OK 10) install igorpecovnik/hostapd reboot ---> Problem as I told in other post This happens three times today , to be sure before write that. So pratically this is the price to pay if I want an access point ? :( What I have to do ? I want insist because Igor and Tkaiser wrote me is a small issue , just remove and play with the SD card and else . This is a bug or not ? I'm using armbian on orangepi plus 2 , maybe the igorpecovnik/hostapd is only for other version ? ciao Walter
xwalter Posted June 15, 2016 Author Posted June 15, 2016 any idea? Guys , I don't want you waste time but I think this is a serious bug to fix . I did this test several times before to wrote above ,I hope you are interested
Igor Posted June 16, 2016 Posted June 16, 2016 You don't need to recompile hostapd since you got latest already with armbian by default. It works out of the box.
xwalter Posted June 16, 2016 Author Posted June 16, 2016 Really? So , with armbian 5_14 I just have to lint /etc/interfaces to /etc/interfaces.hostapd or else?
Igor Posted June 16, 2016 Posted June 16, 2016 That's all. If you want an auto start, than you uncomment and put path to your conf file: DAEMON_CONF="/etc/hostapd.conf" in /etc/default/hostapd
xwalter Posted June 16, 2016 Author Posted June 16, 2016 ok thanks Igor. i will do this job for the next SD card after burn this one .....
