"starts playing late" means that you missing the first seconds?
on some board the amplifier has to be "started" from the system (because it is using a art of power-save for the sound).
This will take up to 3 seconds where you will get no sound....and the system will shut off the amplifier after some seonds with a small "poff"-sound....
I did read about a "switch" in a config-file (like on WiFi powersave) - but I dont know it now from my mind.
Got this also on my OPi Zero....
What I mean is in this thread:
Put the following line at the end of /boot/cmdline.txt
snd-soc-core.pmdown_time=-1
OR
echo -1> /sys/devices/platform/soc/1c22c00.codec/cdc/pmdown_time
Maybe that will help you recover the start of your sound?
Hmm there seems something changed:
root@opi-zero(192.168.6.99):~# echo -1> /sys/devices/platform/soc/1c22c00.codec/cdc/pmdown_time
/sys/devices/platform/soc/1c22c00.codec/cdc/pmdown_time:
Permission denied
root@opi-zero(192.168.6.99):~# ls -l /sys/devices/platform/soc/1c22c00.codec/cdc/pmdown_time
ls: cannot access '/sys/devices/platform/soc/1c22c00.codec/cdc/pmdown_time':
No such file or directory
root@opi-zero(192.168.6.99):~# ls -l /sys/devices/platform/soc/1c22c00.codec/cdc/power
total 0
-rw-r--r-- 1 root root 4096 May 29 19:16 autosuspend_delay_ms
-rw-r--r-- 1 root root 4096 May 29 19:16 control
-r--r--r-- 1 root root 4096 May 29 19:16 runtime_active_time
-r--r--r-- 1 root root 4096 May 29 19:16 runtime_status
-r--r--r-- 1 root root 4096 May 29 19:16 runtime_suspended_time
Maybe we have to set the autosuspend_delay_ms to -1 ?
But also
root@opi-zero(192.168.6.99):~# sudo echo -1 > /sys/devices/platform/soc/1c22c00.codec/cdc/power/autosuspend_delay_ms
echo: write error: Input/output error
Permission denied
total 0
But also
Thank you, but these were not the solution.
