Hi to All!
Currently i am using 3.4.107-cubietruck #14 SMP PREEMPT Wed Apr 29 11:57:42 CEST 2015 armv7l GNU/Linux including a WLAN USB Adapter AWUS036AC from ALFA.
First question: Does anybody got this adapter to work with a cubietruck as a WLAN-AP?
Second question: If yes, what driver did you use for the successful implementation?
Third: How to disable the onboard WLAN?
I want to use it as a 5GHZ (AC-standard) WLAN-AP!
Many thanks in advance.
Regards, Ireng
Hi Igor,
thank you for your reply and support!
Since I opened this subject already twice on cubieforums.com, I thin we should discuss the issue here and in the other two threads should refere to her!
I tried the ALFA driver, and it is a complete mess. Currently I try get the adapter to work with  the rtl8812au-linux driver. However, I'll give your reference https://github.com/gnab/rtl8812au a trial as well and will report back here later.
Thanks for your help, support and references. I'll keep this thread updated!
regards, Ireng
Hi Igor,
at the moment the WLAN AP is working in 802.11.a mode(5 GHZ) including the current installed driver (rtl8812au-linux).
However I still can not connect with my TAB S or Glaxay mobile phone.
/usr/sbin/hostapd-rt /etc/hostapd.conf-rt starts the WALN-AP.
Please have a look at the enclosed hostapd.conf-rt, maybe I made some mistakes or overlooked an option:
ctrl_interface=/var/run/hostapd
ctrl_interface_group=0
interface=wlx00c0ca8184e0
bssid=00:c0:ca:81:84:e0
ssid=Office5
channel=44
noscan=1
wpa=2
wpa_passphrase=XXXXXXXXXXXXXXX
bridge=br0
wmm_enabled=1
#driver=rtl8821au
#driver=rtl8821au
#driver=8812au
#driver=rtl8812au
#driver=RTL871X
#driver=nl80211
beacon_int=100
hw_mode=a
#ieee80211d=1
ieee80211n=1
#ieee80211ac=1
country_code=DE
wme_enabled=1
ht_capab=[sHORT-GI-40][sHORT-GI-40][HT40+]
#ht_capab=[HT40+]
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
wpa_group_rekey=86400
### hostapd event logger configuration
logger_syslog=127
logger_syslog_level=2
logger_stdout=127
logger_stdout_level=2
the strange looking WLAN devices name was derived from the driver rinstallation.
ifconfig results into the following output:
br0       Link encap:Ethernet  HWaddr 00:c0:ca:81:84:e0
          inet addr:192.168.XXX.YYY  Bcast:192.168.175.255  Mask:255.255.255.0
          inet6 addr: fe80::2c0:caff:fe81:84e0/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:5558 errors:0 dropped:0 overruns:0 frame:0
          TX packets:715 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:617108 (602.6 KiB)  TX bytes:81552 (79.6 KiB)
eth0      Link encap:Ethernet  HWaddr 02:05:06:c0:f8:68
          inet addr:192.168.XXX.ZZ  Bcast:192.168.175.255  Mask:255.255.255.0
          RX packets:10877 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1734 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:1725206 (1.6 MiB)  TX bytes:134456 (131.3 KiB)
          Interrupt:117 Base address:0xc000
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:528 errors:0 dropped:0 overruns:0 frame:0
          TX packets:528 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:52632 (51.3 KiB)  TX bytes:52632 (51.3 KiB)
wlx00c0ca8184e0 Link encap:Ethernet  HWaddr 00:c0:ca:81:84:e0
          RX packets:36 errors:0 dropped:0 overruns:0 frame:0
          TX packets:879 errors:0 dropped:1250 overruns:0 carrier:0
          RX bytes:840 (840.0 B)  TX bytes:104805 (102.3 KiB)
Thanks for your help and support!
regards, Ireng
Hard to comment on this. If you can't connect it's not working ;) Try open mode - without password. The config looks fine but I guess the driver is probably not capable of AP @5Ghz Try the suggested driver. I think it's the best we have than check / open an issue.
I know. Pity :(
P.S.
I have two sample hostapd.config for my hostapd binary. Have you tried that?
and
/etc/hostapd.conf
Thanks, Igor for your advice.
Checking the MAkefile I found 2 otions for the ARM Architecture:
CONFIG_PLATFORM_ARM_SUNxI = n
CONFIG_PLATFORM_ARM_SUN6I = n
Which one is the right one for the cubietruck to set??
Thanks in advance for your advice!
regards, Ireng
Very simple ;) You don't need to edit anything.
git clone https://github.com/gnab/rtl8812au
cd rtl8812au
make ARCH=arm
insmod 8812au.ko
Plug-in WiFi adapter and voila.
AP mode @2.4 working out of the box, I can try 5G tomorrow.
Kernel is 4.0.5, board Orange Pi.
Can you paste your network configuration. Maybe there is a problem?
Hi Igor!
Thanks for your answer:
Enclosed you'll find my network configuration from /etc/network/interfaces:
#Loopback device
    auto lo
    iface lo inet loopback
#LAN Device eth0
    auto eth0
    iface eth0 inet static
    address 192.168.175.25
        netmask 255.255.255.0
    broadcast 192.168.175.255
    network 192.168.175.0/24
    gateway 192.168.175.1
    nameserver 192.168.175.1
#WLAN Device 1 (USB Adapter ALFA  AWUS036AC)
        auto wlx00c0ca8184e0
    allow-hotplug wlx00c0ca8184e0
    iface wlx00c0ca8184e0 inet manual
    address 0.0.0.0
##Bridge br0 fuer Interfaces ETH0 und wlx00c0ca8184e0
    auto br0
    iface br0 inet static
    address 192.168.175.191
        bridge_ports eth0 wlx00c0ca8184e0
        bridge_fd 0
        bridge_stp n
At this time I even can not access the net!
Enclosed you'll find a screenshot from my router! strange, that br0 and cubie5 share the same IP address!
ifconfig:
          inet addr:192.168.175.191  Bcast:192.168.175.255  Mask:255.255.255.0
          RX packets:1968 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1428 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:155003 (151.3 KiB)  TX bytes:244568 (238.8 KiB)
          inet addr:192.168.175.25  Bcast:192.168.175.255  Mask:255.255.255.0
          RX packets:2391 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1577 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:273843 (267.4 KiB)  TX bytes:270930 (264.5 KiB)
          RX packets:105 errors:0 dropped:0 overruns:0 frame:0
          TX packets:105 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:10200 (9.9 KiB)  TX bytes:10200 (9.9 KiB)
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:44 errors:0 dropped:34 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:6320 (6.1 KiB)
regards, Ireng
Cubie5 is the system in trouble!  :-)
Now the Infor in the router changed (without my interaction)
But still no access to the net!
regards, Ireng
Not much but look what I did.
- latest fresh image 4.1.2
- git clone https://github.com/gnab/rtl8812au
- make and load driver
- use default hostapd-rt.conf and hostapd-rt binnary
- use interfaces.hostapd
it works normally. Not tested for 5ghz.. busy @moment.
Hi Igor!
Thanks for your support. The current configuration and driver shows a 5 GHz WLAN available. The only problem is, that I can not connect from my  mobile phone or tab to the AP. It always refused the connection. Perhaps a misconfiguration of the network?? The mobile devices are ac capable devices.
Regards, Ireng
PS. The  reason why I want to use 5 GHZ network  is because the 2,4 GHZ is over crowded in my location. Nobody is using  5 GHZ.
Output fro iw list:
cubie5:~# iw list
Wiphy phy1
    Band 1:
        Capabilities: 0x1862
            HT20/HT40
            Static SM Power Save
            RX HT20 SGI
            RX HT40 SGI
            No RX STBC
            Max AMSDU length: 7935 bytes
            DSSS/CCK HT40
        Maximum RX AMPDU length 65535 bytes (exponent: 0x003)
        Minimum RX AMPDU time spacing: 16 usec (0x07)
        HT TX/RX MCS rate indexes supported: 0-15, 32
        Frequencies:
            * 2412 MHz [1] (20.0 dBm)
            * 2417 MHz [2] (20.0 dBm)
            * 2422 MHz [3] (20.0 dBm)
            * 2427 MHz [4] (20.0 dBm)
            * 2432 MHz [5] (20.0 dBm)
            * 2437 MHz [6] (20.0 dBm)
            * 2442 MHz [7] (20.0 dBm)
            * 2447 MHz [8] (20.0 dBm)
            * 2452 MHz [9] (20.0 dBm)
            * 2457 MHz [10] (20.0 dBm)
            * 2462 MHz [11] (20.0 dBm)
            * 2467 MHz [12] (20.0 dBm) (no IR)
            * 2472 MHz [13] (20.0 dBm) (no IR)
            * 2484 MHz [14] (20.0 dBm) (no IR)
        Bitrates (non-HT):
            * 1.0 Mbps
            * 2.0 Mbps
            * 5.5 Mbps
            * 11.0 Mbps
            * 6.0 Mbps
            * 9.0 Mbps
            * 12.0 Mbps
            * 18.0 Mbps
            * 24.0 Mbps
            * 36.0 Mbps
            * 48.0 Mbps
            * 54.0 Mbps
    Band 2:
            HT20/HT40
            RX HT20 SGI
            RX HT40 SGI
            No RX STBC
            DSSS/CCK HT40
        Frequencies:
            * 5170 MHz [34] (disabled)
            * 5180 MHz [36] (20.0 dBm) (no IR)
            * 5190 MHz [38] (20.0 dBm) (no IR)
            * 5200 MHz [40] (20.0 dBm) (no IR)
            * 5210 MHz [42] (20.0 dBm) (no IR)
            * 5220 MHz [44] (20.0 dBm) (no IR)
            * 5230 MHz [46] (20.0 dBm) (no IR)
            * 5240 MHz [48] (20.0 dBm) (no IR)
            * 5260 MHz [52] (disabled)
            * 5280 MHz [56] (disabled)
            * 5300 MHz [60] (disabled)
            * 5320 MHz [64] (disabled)
            * 5500 MHz [100] (disabled)
            * 5520 MHz [104] (disabled)
            * 5540 MHz [108] (disabled)
            * 5560 MHz [112] (disabled)
            * 5580 MHz [116] (disabled)
            * 5600 MHz [120] (disabled)
            * 5620 MHz [124] (disabled)
            * 5640 MHz [128] (disabled)
            * 5660 MHz [132] (disabled)
            * 5680 MHz [136] (disabled)
            * 5700 MHz [140] (disabled)
            * 5745 MHz [149] (20.0 dBm) (no IR)
            * 5765 MHz [153] (20.0 dBm) (no IR)
            * 5785 MHz [157] (20.0 dBm) (no IR)
            * 5805 MHz [161] (20.0 dBm) (no IR)
            * 5825 MHz [165] (20.0 dBm) (no IR)
            * 5920 MHz [184] (disabled)
            * 5940 MHz [188] (disabled)
            * 5960 MHz [192] (disabled)
            * 5980 MHz [196] (disabled)
            * 6000 MHz [200] (disabled)
            * 6020 MHz [204] (disabled)
            * 6040 MHz [208] (disabled)
            * 6060 MHz [212] (disabled)
            * 6080 MHz [216] (disabled)
        Bitrates (non-HT):
            * 6.0 Mbps
            * 9.0 Mbps
            * 12.0 Mbps
            * 18.0 Mbps
            * 24.0 Mbps
            * 36.0 Mbps
            * 48.0 Mbps
            * 54.0 Mbps
    max # scan SSIDs: 9
    max scan IEs length: 2304 bytes
    Retry short limit: 7
    Retry long limit: 4
    Coverage class: 0 (up to 0m)
    Supported Ciphers:
        * WEP40 (00-0f-ac:1)
        * WEP104 (00-0f-ac:5)
        * TKIP (00-0f-ac:2)
        * CCMP (00-0f-ac:4)
    Available Antennas: TX 0 RX 0
    Supported interface modes:
         * IBSS
         * managed
         * AP
         * monitor
         * P2P-client
         * P2P-GO
    software interface modes (can always be added):
         * monitor
    interface combinations are not supported
    Supported commands:
         * new_interface
         * set_interface
         * new_key
         * start_ap
         * new_station
         * set_bss
         * join_ibss
         * set_pmksa
         * del_pmksa
         * flush_pmksa
         * remain_on_channel
         * frame
         * set_channel
         * connect
         * disconnect
    Supported TX frame types:
         * IBSS: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
         * managed: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
         * AP: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
         * AP/VLAN: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
         * P2P-client: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
         * P2P-GO: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
    Supported RX frame types:
         * IBSS: 0xd0
         * managed: 0x40 0xd0
         * AP: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
         * AP/VLAN: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
         * P2P-client: 0x40 0xd0
         * P2P-GO: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
I am having a similar situation but failed to find appropriate / cheap 5Ghz AP. I own three dual band wifi devices (2 x mPCI 1 x USB) and this one is the only one that it (almost?) work. Others, Atheros 9382 doesn't work at all and Intel 7260AC simply does not support AP in 5Ghz.
You'll need to ask driver maintainer for additional help & tips:
https://github.com/gnab/rtl8812au/issues
