i've cross-compiled all possible backported drivers for legacy 3.4.112 kernel
could someone who has some usb tuners or video grabbers test it?
download and untar http://d-h.st/k4kZ
cd there and run sudo make install
Hi Xer0,
I've installed them to my NanoPi Neo (http://www.armbian.com/nanopi-neo/). Besides tvheadend and the firmware for my tuner (dvbsky s960).
But it isn't being recognized.
dmesg:
[  821.219574] ehci_irq: highspeed device connect
[  821.490236] usb 4-1: new high-speed USB device number 4 using sunxi-ehci
lsusb:
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 005: ID 0572:6831 Conexant Systems (Rockwell), Inc. DVBSky S960 DVB-S2 tuner
lsmod is empty
So it seems, that it is not working?!? Or am I mistaken?
How did you compile it? Crosscompile?
Hi t3g,
I heard newer DVBSky devices cause some problems.
probably yours have not be backported to 3.14 yet
But, have you also got and put all firmware files?
I've crosscompiled them with Ubuntu 16.04 x64 in VM
At the moment, i don't have access to my compiling PC
Hope that i can compile and push a newer version in Oct
I need this V4L/DVB drivers for 3.4.113 kernel
Anybody can tell me how to compile this?
Or maybe someone has already compiled binary?
1 hour ago, mihai.aldea said:
No updates yet? Does that means that we can't use the generic DVB-T tuners (eg. Astrometa ID 15f4:0131) with 3.4.113?
Most of developers are dealing with mainline kernel, which is slowly emerging / getting ready on H3 devices too. There you have more chances for such hardware to work. I am using Nanopi neo for my tvheadend with 4.10.x - no problems:
 _   _                   ____  _   _   _
| \ | | __ _ _ __   ___ |  _ \(_) | \ | | ___  ___
|  \| |/ _` | '_ \ / _ \| |_) | | |  \| |/ _ \/ _ \
| |\  | (_| | | | | (_) |  __/| | | |\  |  __/ (_) |
|_| \_|\__,_|_| |_|\___/|_|   |_| |_| \_|\___|\___/
Welcome to ARMBIAN 5.26 stable Debian GNU/Linux 8 (jessie) 4.10.0-sun8i
System load:   0.19             Up time:       34 days
Memory usage:  28 % of 243Mb    IP:            xxxxxxxxxxxxxx
CPU temp:      32°C
Usage of /:    19% of 7.2G
It's still in development, so you are on your own.
I'm trying to get MythTV or tvheadend working on my UDOO Quad with Armbian Jessie with kernal 4.4.102
glen@udoo:~$ uname -a
Linux udoo 4.4.102-udoo #2 SMP Fri Nov 24 18:49:01 CET 2017 armv7l GNU/Linux
I thought that dvb drivers were included in version 3.19 of the kernel and up?
Anyway I copied dvb-usb-af9015.fw to /lib/firmware and rebooted.
But nothing shows up under /dev/dvb/
I would expect there to be adapter0 and adapter1
Here is my lsusb:
glen@udoo:~$ lsusb
Bus 001 Device 004: ID 13d3:3226 IMC Networks DigitalNow TinyTwin DVB-T Receiver
Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
and my dmesg:
[ 8904.731820] usb 1-1.2: USB disconnect, device number 3
[ 9150.501583] usb 1-1.1: new high-speed USB device number 4 using ci_hdrc
[ 9150.616876] usb 1-1.1: New USB device found, idVendor=13d3, idProduct=3226
[ 9150.616899] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 9150.616915] usb 1-1.1: Product: DVB-T 2
[ 9150.616928] usb 1-1.1: Manufacturer: Afatech
[ 9150.616940] usb 1-1.1: SerialNumber: 010101010600001
[ 9150.630673] input: Afatech DVB-T 2 as /devices/soc0/soc/2100000.aips-bus/2184200.usb/ci_hdrc.1/usb1/1-1/1-1.1/1-1.1:1.1/0003:13D3:3226.0002/input/input1
[ 9150.682765] hid-generic 0003:13D3:3226.0002: input: USB HID v1.01 Keyboard [Afatech DVB-T 2] on usb-ci_hdrc.1-1.1/input1
