I'm new to building the toolchain so sorry if I missed something basic.
I installed Virtualbox greater than the version noted on the instructions page. (https://docs.armbian.com/Developer-Guide_Build-Preparation/)
Used the mini image at http://archive.ubuntu.com/ubuntu/dists/focal/main/installer-amd64/current/legacy-images/netboot/mini.iso per above page.
During the install I did not check any options for system software.
Started the os and installed git using sudo per the instructions page in the second line above.
After it completed I changed to the build directory and issued the compile
sudo ./compile.sh
and seems to run as expected. I select Full OS Image -> Show a kernel configuration menu -> (select ANY board) -> Current, and it seems to run fine until it gets to the following error -
2013??
This is the roadblock every time for me. What step did I miss or err?
After a few tries I noticed it has a very brief error on boot -
but I don't see how that would cause a download error or use a file from 2013?
Guidance would be awesome at this point ;]
Confirmed.
Okay, seems like a general issue, not torrent related. USE_TORRENT=no leads into the same issue.
The minimal installation seems lacking gpg.
apt-get install gpg
This fixes it.
About 2013: Some boards, especially older ones need older toolchain to compile older sources...sometimes stuff breaks in upstream ¯\_(ツ)_/¯
I could compile a kernel package for a randomly selected board and kernel so I assume everything works as expected now.
Completed without error thank you again ... although I think I will allocate more resources to the VM it took all night hihi. I understand the next run will be much faster since it doesn't have to download and build those toolchains.
Thanks again
