David-L Posted June 26, 2020 Posted June 26, 2020 Armbianmonitor: http://ix.io/2qgc The module ds2490 seem to be missing in the new release. Should be: /lib/modules/4.19.62-sunxi/kernel/drivers/w1/slaves/w1_ds2490.ko
Werner Posted June 27, 2020 Posted June 27, 2020 May have been removed while merging upstream config. I'll take a look. Aight there are two options for you: - Replace the legacy with the current kernel which contains this module or - Use the build script to create your own legacy kernel package which then will be up-to-date as well 1
