Debian_jessie locks up with 4th network interface
xinumike
I am using: Armbian_5.14_Odroidc2_Debian_jessie_3.14.71
I am a bit stumped....if I run with 3 network interfaces, everything is fine.
If I add a fourth interface...the system locks up...even if the 3rd and 4th interface have no ip address.
They just need to be live!
I have tried 4 drastically different interfaces in case the device driver can't handle it.
Anybody have any thoughts or suggestions??
THank you!
Good thinking! Thank you.
Anybody see anything like this now?
Jun 21 14:35:26 localhost kernel: [  243.223660]
Jun 21 14:35:26 localhost kernel: [  243.223781] ERROR::assign_and_init_hc:1264: assign_and_init_hc: Failed to allocate memory to handle non-dword aligned buffer case
Jun 21 14:35:26 localhost kernel: [  243.223904] ERROR::assign_and_init_hc:1264: assign_and_init_hc: Failed to allocate memory to handle non-dword aligned buffer case
Jun 21 14:35:26 localhost kernel: [  243.224028] ERROR::assign_and_init_hc:1264: assign_and_init_hc: Failed to allocate memory to handle non-dword aligned buffer case
Jun 21 14:35:26 localhost kernel: [  243.224153] ERROR::assign_and_init_hc:1264: assign_and_init_hc: Failed to allocate memory to handle non-dword aligned buffer case
Jun 21 14:35:26 localhost kernel: [  243.224278] ERROR::assign_and_init_hc:1264: assign_and_init_hc: Failed to allocate memory to handle non-dword aligned buffer case
Jun 21 14:35:26 localhost kernel: [  243.224403] ERROR::assign_and_init_hc:1264: assign_and_init_hc: Failed to allocate memory to handle non-dword aligned buffer case
Jun 21 14:35:26 localhost kernel: [  243.224528] ERROR::assign_and_init_hc:1264: assign_and_init_hc: Failed to allocate memory to handle non-dword aligned buffer case
Jun 21 14:35:26 localhost kernel: [  243.224653] ERROR::assign_and_init_hc:1264: assign_and_init_hc: Failed to allocate memory to handle non-dword aligned buffer case
Jun 21 14:35:26 localhost kernel: [  243.224778] ERROR::assign_and_init_hc:1264: assign_and_init_hc: Failed to allocate memory to handle non-dword aligned buffer case
Jun 21 14:35:26 localhost kernel: [  243.224903] ERROR::assign_and_init_hc:1264: assign_and_init_hc: Failed to allocate memory to handle non-dword aligned buffer case
Jun 21 14:35:26 localhost kernel: [  243.225028] ERROR::assign_and_init_hc:1264: assign_and_init_hc: Failed to allocate memory to handle non-dword aligned buffer case
