Ethernet USB gadget not working on legacy
Go to solution Solved by sgufa,
Hi. i tried to use g_ether module on legacy 3.4.112 kernel but without success.
Could anyone help me?
this is what i have when i run modprobe g_ether:
[sw_udc]: [sw_usb_udc]: binding gadget driver 'g_ether'
[sw_udc]: alloc request: ep(0xc0a8b7e8, ep0, 64), req(0xef3c8940)
WRN:L2728(drivers/usb/sunxi_usb/udc/sw_udc.c):ERR: usb device is not active
<4>g_ether gadget: using random self ethernet address
<4>g_ether gadget: using random host ethernet address
<6>usb0: MAC 5a:1d:b8:22:02:7f
<6>usb0: HOST MAC 6e:49:95:27:67:f7
ep_matches, wrn: endpoint already claimed, ep(0xc0a8b834, 0xeeb62480, ep1-bulk)
ep_matches, wrn: endpoint already claimed, ep(0xc0a8b880, 0xeeb62480, ep2-bulk)
[sw_udc]: alloc request: ep(0xc0a8b8cc, ep3-bulk, 512), req(0xee6b2000)
<6>g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
<6>g_ether gadget: g_ether ready
WRN:L2762(drivers/usb/sunxi_usb/udc/sw_udc.c):ERR: usb device is not active
Suggestions?
The fex is the cubieboard2 included in lib.
Thank you
Can you please ensure that no gadget module is referenced in /etc/modules, then reboot and show us the output of
cat /sys/bus/platform/devices/sunxi_usb_udc/otg_role
In case this is 2 then please do an
echo 0 >/sys/bus/platform/devices/sunxi_usb_udc/otg_role
modprobe g_ether
echo 2 >/sys/bus/platform/devices/sunxi_usb_udc/otg_role
ifconfig usb0 192.168.99.99 netmask 255.255.255.0 up
and report back.
yeah, i followed all the steps. Now i'm trying with debian legacy on sd (i was on trusty on nand). I'll let you know in a while
with debian i get this:
 modprobe g_ether
[sw_udc]: alloc request: ep(0xc0a8b7e8, ep0, 64), req(0xee670680)
<6>usb0: MAC ee:0d:e6:46:d2:05
<6>usb0: HOST MAC 82:f9:1f:a7:f2:35
ep_matches, wrn: endpoint already claimed, ep(0xc0a8b834, 0xee707b80, ep1-bulk)
ep_matches, wrn: endpoint already claimed, ep(0xc0a8b880, 0xee707b80, ep2-bulk)
[sw_udc]: alloc request: ep(0xc0a8b8cc, ep3-bulk, 512), req(0xee0d6bc0)
[sw_udc]: CONFIG_USB_GADGET_DUALSPEED
[sw_udc]: usbd_start_work[sw_udc]: IRQ: suspend
[sw_udc]: ERR: usb speed is unkown
[sw_udc]: IRQ: reset
[sw_udc]: irq: reset happen, throw away all urb
<6>ADDRCONF(NETDEV_UP): usb0: link is not ready
[sw_udc]:
[sw_udc]:  usb enter high speed.
[sw_udc]:
[sw_udc]: Set address 17
<6>g_ether gadget: high-speed config #2: RNDIS
[sw_udc]: ep enable: ep3(0xc0a8b8cc, ep3-bulk, 128, 8)
[sw_udc]: ep enable: ep1(0xc0a8b834, ep1-bulk, 128, 512)
[sw_udc]: ep enable: ep2(0xc0a8b880, ep2-bulk, 0, 512)
[sw_udc]: alloc request: ep(0xc0a8b834, ep1-bulk, 512), req(0xeea51700)
[sw_udc]: alloc request: ep(0xc0a8b834, ep1-bulk, 512), req(0xeea51f40)
[sw_udc]: alloc request: ep(0xc0a8b834, ep1-bulk, 512), req(0xeea51f00)
[sw_udc]: alloc request: ep(0xc0a8b834, ep1-bulk, 512), req(0xeea51d80)
[sw_udc]: alloc request: ep(0xc0a8b834, ep1-bulk, 512), req(0xeea51dc0)
[sw_udc]: alloc request: ep(0xc0a8b834, ep1-bulk, 512), req(0xeea51740)
[sw_udc]: alloc request: ep(0xc0a8b834, ep1-bulk, 512), req(0xeea51cc0)
[sw_udc]: alloc request: ep(0xc0a8b834, ep1-bulk, 512), req(0xeea51a40)
[sw_udc]: alloc request: ep(0xc0a8b834, ep1-bulk, 512), req(0xeea51d00)
[sw_udc]: alloc request: ep(0xc0a8b834, ep1-bulk, 512), req(0xeea51bc0)
[sw_udc]: alloc request: ep(0xc0a8b880, ep2-bulk, 512), req(0xeea519c0)
[sw_udc]: alloc request: ep(0xc0a8b880, ep2-bulk, 512), req(0xeea51900)
[sw_udc]: alloc request: ep(0xc0a8b880, ep2-bulk, 512), req(0xeea518c0)
[sw_udc]: alloc request: ep(0xc0a8b880, ep2-bulk, 512), req(0xeea515c0)
[sw_udc]: alloc request: ep(0xc0a8b880, ep2-bulk, 512), req(0xeea51b80)
[sw_udc]: alloc request: ep(0xc0a8b880, ep2-bulk, 512), req(0xeea51c40)
[sw_udc]: alloc request: ep(0xc0a8b880, ep2-bulk, 512), req(0xeea51800)
[sw_udc]: alloc request: ep(0xc0a8b880, ep2-bulk, 512), req(0xeea51ac0)
[sw_udc]: alloc request: ep(0xc0a8b880, ep2-bulk, 512), req(0xee9fd900)
[sw_udc]: alloc request: ep(0xc0a8b880, ep2-bulk, 512), req(0xee9fd880)
nuke: ep num is 0
WRN:L1041(drivers/usb/sunxi_usb/udc/sw_udc.c):ERR: Operation not supported
WRN:L1355(drivers/usb/sunxi_usb/udc/sw_udc.c):handle_ep0: ep0 setup end
<6>ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
<7>usb0: no IPv6 routers present
and on my pc i see a serial port but not an ethernet card
Thank you tkaiser. Now the problem is that i have windows 10 x64 and cannot find a compatible rndis driver. is there a way to change the usb vid and pid of the usb gadget on the cubieboard2?
  • Solution
Hello zador, i've found an unsigned driver under linux source documentation and installed it bypassing the digital signature verification at boot. All is working well with Jessie. I'll try to understand why it doesnt work on Trusty. I'm downloading a pre-compiled trusty image and gonna test in short time. Thank you all
